Results 51 to 67 of 67
Thread: Soulution 511 monos unboxing
January 24, 2017, 02:11 PM #51
Re: Soulution 511 monos unboxing
Don't know as I installed the 511's as a mono pair from the beginning....
March 17, 2017, 04:10 AM #52
- May 2016
- 27
System: Magico S1 MkII, DCS Puccini Player & Clock, Aurender N100C, SME Mod 15, SME IV, Lyra Etna, Nagra VPS
Headfi: Violectric HPA V281, Sony Z1R, Kimber Axios Cu
Cables: Transparent Premium USB, Gen5 Reference 75 Ohm, Ultra interconnects, phono and speaker cables
Power: Shunyata EU7, Alpha NR, Furutech Powerflux-18E
Accessories: Finite Elemente 600 APS, several Cerabases, Ceraballs and Cerapucs
March 17, 2017, 08:26 AM #53
Yes. The 511's seem to be the overwhelming solid state amp favorite in my store with all the Magico's - including the M3's (but I don't have my new Vitus SM-103 monos yet). They get warm when pushed, but never "hot" like a class A or tube amp. You can put your hand on them for several seconds.
March 18, 2017, 04:43 AM #54
- May 2016
- 27
March 18, 2017, 08:51 AM #55Le Roy
Foundation:
March 18, 2017, 09:21 AM #56
An additional note about sound quality and heat. The Soulution 500 Series are Class AB amps but are heavily biased into Class A. This means they will be operating in Class A mode most of the time for maximum sound quality except for very dynamic passages. This also means they run near maximum warmth while at idle. While my 501 monoblocks were very warm at idle, they were never too hot to touch and they didn't get appreciably warmer at higher volumes. Compared to my Pass XA-100.8 monoblocks, the 501's put out significantly less overall heat. The Soulution amps do need adequate ventilation, so I wouldn't recommend anything above them or too close to the sides.
Best,
March 18, 2017, 02:29 PM #57
March 18, 2017, 03:16 PM #58
- May 2016
- 27
March 18, 2017, 04:03 PM #59
Soulution , Pass , Vitus ... Ohhhh Mike's wary head ..
March 18, 2017, 06:33 PM #60Le Roy
Foundation:
March 18, 2017, 07:14 PM #61
Rockport Lyra speakers; TotalDac Amp-1 mono blocks; four box CH Precision L1/X1 pre/power supply monos; CH precision P1/X1 phono/power supply; TotalDac d1-driver monos; Pacific Microsonics Model 2 DAC; TotalDac d1-12 MkII DAC with two reclockers; Kodo The Beat Turnatable with LT Schroder magnesium tonearm and Lyra Atlas cart; Taiko Extreme server; Kalista Dreamplayer CD Transport; Taiko Audio Daiza Platforms; Nordost Odin2 Power Cords and Analog ICs; 512 Engineering/Tim Marutani Balanced Transformers (30 amp for sources; 50 amp for amps); Rives designed dedicated room.
January 27, 2018, 06:31 PM #62
- May 2017
- Guildford, UK
- 123
Any update on how these are sounding? Any idea how these would compare to the 7-series stereo amp which probably comes in around the same price?
January 27, 2018, 07:27 PM #63
January 27, 2018, 10:49 PM #64
So not the solution you were looking ....
January 27, 2018, 11:58 PM #65
The 511 stereo amp was retailing for $35,000 USD and the 711 stereo is around $60,000 USD.
I have never had the 511 in my system but I currently have the 711 in one residence and the 501 mono blocks in another.
The 511 is said to have a similar power supply to the 7 series. This may be a benefit of "trickle down" technology.Le Roy
Foundation:
January 28, 2018, 12:09 AM #66
January 28, 2018, 01:10 PM #67
- May 2017
- Guildford, UK
- 123
The point on pricing is that when you double the 511 up to run them as monos, they are about the same as the 711 stereo.
Unfortunately I was not able to hear the Auditoriums at AXPONA 2024. Based on what I did hear, the Piccolo, the Auditorium must be stupendous. The amps are the WestminsterLab Rei monoblocks (I've...
Going active in Washington State
