Results 1 to 50 of 50
  1. #1
    New Pass Labs XA25
    Just saw this on Pass facebook page. New XA25 amp. Wondering if Mike or anyone knows more info on this.
  2. #2
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: New XA25
    Output power:
    2x 25 Watts Class A @ 8 ohms
    2x 50 Watts Class A @ 4 ohms
    2x 100 Watts Class A/AB @ 2 ohms
    - Distortion: 0.1% @ 25 Watts, 8 ohm, 1 KHz, 0.1% @ 50 Watts, 4 ohms, 1 KHz
    - Freq. Response: DC to -3 dB @ 200 KHz
    - Gain: 20 dB gain
    - Noise: Output 100 uV unweighted 20 to 20 KHz
    - Damping Factor: 200
    - Slew: 100 V/uS
    - Input Impedance: 47 Kohm
    - Peak Current: 10 Amp output (200 Watts into 2 ohms)
    - Independent of loudspeaker load phase.
    - Idle Power draw: 200 Watts total.
    - Dimensions: 17”W x 17.375”D x 6”H
    - Weight: approx. 55 lbs
  3. #3
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
  4. #4
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: New XA25
  5. #5
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    New XA25
    As you are all very aware Pass Labs build amplifiers with excessive output stages, lots of heat sinking and impressively capable power supplies. They are reliable, measure well and sound great.
    Nelson says the Xa-25 embodies all these attributes and less, and in Nelson-esq that really is an impressive accolade to bestow upon a product.
    The lower power application allows for an elegantly simpler "singe ended" front end, with fewer parts in the signal path, improving both speed and stability. The Xa-25 is stable into very low impedance's as well as reactive loads.
    The circuit operates with less feedback, deeper into class A. with enhanced thermal stability. There are no DC servos or frequency compensation anywhere in circuit; design details that are strictly in service of the listening experience.
    Where the Xa-25 really deviates from our larger wattage amps is the output stage, itself. Rather than requiring many parallel devices, each channel has a single robust industrial FET rated for 700W and 40A of current. This singe device allowing for a direct couple to the speaker without any bias resistors, for the lowest possible distortion figures and the highest possible damping factor. The result is dynamic impact and contrast well beyond what the 25W rating would suggest.
    In a world where great specs are often followed by dry and boring, the Xa-25 breathes new life into music. But having said that, it's metrics are pretty stunning, too.
    2 X 25 Watts Class A into 8 ohms at 0.1% THD + noise
    2 X 50 Watts Class A into 4 ohms at 0.1% THD + noise
    At lower wattage output levels the figures are better still, significantly!
    Input impedance 47k-ohm
    Bandwidth DC to -3dB @ 200 kHz
    Gain 20 dB
    Damping factor 200
    Idle current 200 Watts
    Physical size approx 17" x 17" x 6"
    weight approx 55 lbs
    Projected MSRP of $4995
  6. #6
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    Re: New XA25
    An XA25 and a pair of Uno XD's anyone?
  7. #7
    Re: New XA25
    Me like!
  8. #8
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Re: New Pass Labs XA25
    Looks like Nelson Pass might be breaking new ground again. I wonder if we'll see some trickle up technology into their higher end models?
    Ken
  9. #9
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Just when I thought I didn't need/want any more amps, damn.
  10. #10
    Senior Member
    Join Date
    Nov 2015
    Western NC
    Posts
    157
    Sort of reminds me of a First Watt, all grown up.
    Sent from my Nexus 5X using Tapatalk
    Digital: LH Labs Source (someday...) + LH Labs Geek Pulse SFi
    Analogue: Audio Technica OC9ML/ii + Technics 1200SL + Nikko Beta 40 (phono only)
    Wyred 4 Sound STP-SE
    First Watt F6
    Focal 816VW Special Edition
  11. #11
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Anyone have this yet or are you thinking about buying one? I'm so curious how it compares to my Accuphase A-36 (which I love dearly and have been using for the past month or so).
    I'd like to get an idea of how it sounds. Might be time for a demo.
  12. #12
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Bump
    Anyone buy the Pass XA25 yet, or at least hear it?
  13. #13
    Junior Member
    Join Date
    Dec 2013
    springfield mo
    Posts
    17
    I agree to me this seems kind of like Nelson is taking one of his First Watt designs and bringing it to the Pass name, Not sure if this is the case as I haven't studied the design yet. With the Audiophile community getting back into the high sensitivity speaker game an amp like this one seems to be good timing, they should sell well
    System:
    (2-channel)>Nuforce P-8 preamp>Pass Labs X150.5 Power Amp >Spatial Audio M3 Turbo S main speakers>Custom Built sealed sub for low end>Modified Dell i660 pc with Fidelizer for digital music source>PS Audio NuWave DAC
    (Theater)
    Marantz Pre processor>Adcom 545II rear channel power amp
    >Crown XLS1000 power amp for theater sub>Modified JBL sub for theater
  14. #14
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    This looks to be almost exactly a First Watt F6 with a fancier case. Nelson has said that many times Pass Labs benefits from designs he comes up with in his personal playground (First Watt)... this looks to be the case... judging from the First Watt F6 I am listening to right now I would say this amplifier will sound amazing!
    ― Neil deGrasse Tyson
  15. #15
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    Just wanted to add that Nelson told me that the Pass XA25 and the First Watt F6 are not related and were designed separately. They are very similar is design, looks, features, and specs; therefore I do feel that performance should be similar as well however.
  16. #16
    Junior Member
    Join Date
    Dec 2013
    springfield mo
    Posts
    17
    Good to know. They do look a lot alike though
    Sent from my SM-G930V using Tapatalk
    System:
    (Theater)
  17. #17
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    Yea, and I would be think that they probably sound virtually identical as well. Even though the Pass was designed separately I would believe that the design perfected in the F6 was generously borrowed upon for the XA25 ...
  18. #18
    So even after Nelson Pass said they were designed separately, you still think they sound "virtually identical"?
  19. #19
    New Pass Labs XA25
    The more I think of it, the more I like the idea.
    Tube pre with that, any suggestions?
  20. #20
    Quote Originally Posted by Kuoppis View Post
    ARC LS28 or Ref 6.
  21. #21
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    The XA25 has only RCA inputs so maybe a PS Audio BHK pre or Conrad Johnson preamp. OMG!
  22. #22
    Something Japanese?
  23. #23
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Something Japanese?
  24. #24
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    I agree with Joe, PS Audio or CJ... ARC would not be out of the picture either in my view... but at this point the STP-SE is working very nicely for me!
    And yes, I would think that the two amps would be very similar sounding. The features, many special parts being used and talked about, specs, SE inputs, heat sink designs, power, etc., etc. are similar if not exactly the same. I also assume both are designed by Nelson and the F6 was completed and in the market first. On several occasions it has been written by Nelson and others that design developed and optimized in the First Watt line get passed on to Pass Labs. So yea, I feel that they would sound extremely similar...
    By the way, here is Nelson's description of the F6 to me:
    "I found that it had many of the charms of the
    other amps, but a nicely soft top end that forgives a lot of the top
    end artifacts you get in today’s recordings."
  25. #25
    New Pass Labs XA25
    I had the ARC PH6 and was a bit underwhelmed. There was nothing wrong with it, it was just a bit boring. The mono setting was nice though.
    That's why I am thinking Japanese or maybe again an EAR would be nice. Have not heard CJ or the BHKs though.
  26. #26
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    One nice thing about the STP-SE is that it has two XLR and two RCA outputs... so can do whatever I need ....
  27. #27
    Any experience with the Air Tight pres anyone?
  28. #28
    Junior Member
    Join Date
    Dec 2013
    springfield mo
    Posts
    17
    I have heard that ARC preamps are a little like that. I had a friend that tried one and has since moved on and said the same exact thing. Its is probably not all their products just a couple of their preamps.
    I am a bit surprised to see that a Pass amp only have RCA inputs seeing that the other amps in the Pass lineup have the balanced and I can attest that the other Pass amps sound much better using the Balanced inputs as I found out with mine.
    I second the PS Audio preamp as it has some great reviews and I have always like PS Audio products.
    System:
    (Theater)
  29. #29
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Yes! EAR (and Air Tight) make(s) great preamps.
  30. #30
    Junior Member
    Join Date
    Dec 2013
    springfield mo
    Posts
    17
    Being that it only accepts RCA inputs does open up many more possibilities as far as preamps go especially in the tube world as most of them are only RCA outputs anyway. I would be interested in knowing how the XA25 sounds compared to the other XA amps in their lineup
    System:
    (Theater)
  31. #31
    New Pass Labs XA25
    A Dutch review of the XA25 (with some comparison to the X30.5) - English translation at page 6:
    http://www.moremusic.nl/reviews/pass...ic-emotion.pdf
    PS: link corrected.
  32. #32
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    The more I read about and research this amp the more I am convinced that it was taken from the First Watt F6, reworked and repackaged in the Pass case. And why would Nelson not do this? He owns and designs both. The First Watt is not designed for his commercial line, but his play ground to explore new designs. Naturally what is "discovered" in his experimenting and proven as examples of excellent designs would be made available through the commercial line.
  33. #33
    Anyone have any impressions on this amp? Could be great paired with the correct speakers.
    Industry Disclosure: Owner Epiphanic Audio. Bespoke 2 channel resource in Virginia Beach VA. Dealer for darTZeel and other great brands.
  34. #34
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    I want it for my AG's. You thinking one for your Avantgarde Uno XD's?
  35. #35
    Yes.
    I tried the First Watt F-2J very nice but think a little more juice would be nice.
  36. #36
    Stout ! Notice the lower the impedance gets the more power output - 100 watt rated at 2 ohms, I like that. Should be a prime candidate for Open Baffles / Pure Audio Project style / Spatial, etc.
  37. #37
    Senior Member
    Join Date
    Jan 2016
    Solana Beach, CA
    Posts
    199
    Reviews and measurements starting to come out. The current issue of Tone Audio has a sterling review although it isn’t listed in the TOC. Starts on page 52.
    http://www.tonepublications.com/MAGPDF/TA_086.pdf
    Herb Reichert also reviewed it in the Feb 2018 Stereophile. I usually enjoy Herb’s writing, but I can’t say the review helped me understand what the XA25 sounds like. Interestingly, JA measured it and it puts out a LOT more power than claimed: 80W into 8 ohms and 130W into 4 ohms.
    The Audio Beatnik also reviewed it:
    http://theaudiobeatnik.com/pass-labs...-hpa-1-preamp/
    The last English review I am aware of is from Steve Guttenberg
    https://www.cnet.com/news/the-audiop...att-amplifier/
    6 moons has had a preview up for quite awhile. That review ought to be available very soon.
    Analog source: AMG Viella 12; Ortofon Anna cartridge, van den Hul Crimson Stradivarius XGW
    Digital source: Totaldac d1-twelve Mk2 DAC, Totaldac d1-player, Totaldac d1-streamer, Totaldac Live Power supply
    Pre amp: VAC Master with phono
    Phonostage: ​Constellation Andromeda
    Amps: VAC 200iQ monoblocks
    Speakers: Magico M3 with MPods
    Cables: Synergistic Research Galileo SX speaker, phono, analog and digital interconnects
    Power products: Synergistic Research Galileo PowerCell SX and Transporter Ultra. Galileo SX and SRX power cords. Keces P3 LPS for cable modem and router.
  38. #38
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Thank you for the additional links and thoughts. I am looking forward to hearing the XA25. I’m sure it’s a wonderful amp.
  39. #39
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
  40. #40
    Senior Member
    Join Date
    Jan 2016
    Solana Beach, CA
    Posts
    199
    Thanks Joe! I love my VAC 200iQ amps, but I’ve been looking intermittently for 10 yrs for a solid state amp that I could live with so I could give up replacing tubes. But I’ve never found a solid state amp that even slightly tempted me to give up tubes. Still thinking that one of these days I’ll make it to Mike’s store and listen to the Gryphons on the M3s.
    But the XA25 sounds promising (pun intended). It may be slightly under-powered for my room and speakers.... Hmmmmm.....Only one way to find out......
  41. #41
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    I’m dying to try one now, even more than before.
  42. #42
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    And you have the same preamp to put in front of it plus the Luxman.
  43. #43
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Yes, I have a feeling it’s a great little amp.
    Quote Originally Posted by Jack View Post
  44. #44
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    I really enjoyed the First Watt F6, which was basically the same amp. It just didn't have quite enough for the new KEF's.
  45. #45
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Randy
    This one seems to have a bit more juice though still maybe not enough for the KEF's. It's tempting though I have no complaints with the BHK. Any time frame on your Stellar amp?
  46. #46
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,951
    Hey Jack... the F6 was very good for normal use, but didn't have any reserve with the KEF's... great sounding amp though... specs identical to the new Pass...
    The new PS Audio arriving Friday.... should be fun... so most all amp flavors in rack for whatever mood ...
    Still thinking of the DirectStream.... being that I am such a DSD fan... May have to talk with Ted and Paul in Chicago ....
  47. #47
    Senior Member
    Join Date
    Jan 2016
    Solana Beach, CA
    Posts
    199
  48. #48
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Awesome, thank you for posting.
  49. #49
    I've had this amp paired with Avantgarde Uno XD's for several months now.The bass is tighter and more refined than SET. The mids/highs while not SET are made up for with more of everything else. It takes the AG's to another level. Highly recommend a listen.
  50. #50
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    I have one on order. Will get it next week.
New Pass Labs XA25
Posting Permissions
  • You may not post replies
  • You may not edit your posts
