Results 1 to 24 of 24
  1. #1
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Tube Noob, seeking education
    Greetings all, hope everyone had a blessed Christmas. I have been lurking around here for a while now. I have finally put together a somewhat modern system that is pretty nice I think but I am running into a few things that are unfamiliar to me and I was hoping I could get some guidance.
    So I have acquired a couple of fine pieces of Balanced Audio Technology tube gear. So far, everything is going pretty well, but I am still wandering about in the dark a bit when it comes to tube gear in general and what to expect. A bit of background info is in order. The first component was the VK-P5 phono stage. When I got it, I was driving the system with a Yamaha AX-900u integrated. It was dead quiet at idle. I didn't have balanced inputs on the 900 so I made an XLR to RCA adapter cable using the wiring instructions given to me by Victor Komenko. It worked fine but I noticed that the phono stage was a bit noisy. I figured out I had a bad 6922. Bought a quad of nos Phillips 7DJ8's and all was well. Next I pick up a BAT VK-3i. It came to me with Electroharmonix 6922eh tubes installed and a quad of JJ 6922's in the box. According to the seller, the EH 6922's had about 100 hours on them. It sounded very good but I noticed that it was a bit noisy and anytime I touched the knobs or casing of the preamp, I heard it through the speakers. Just for giggles I rolled in the JJ's. The are still noisy and microphonic but they did sound better to me than the EH 6922.
    So my question. When it comes to tube gear, how quiet is quiet? As I said, the Yamaha was silent. I had read that the BAT gear was very quiet. The BAT gear out performs the Yamaha amp hands down in sound quality but should I hear noise in my speakers at idle and if I should, how much? The noise is not dependent on the volume setting. With no signal present, it is about the same no matter where the volume knob is set. I know that when buying a used unit that you never know what conditions the tubes might be in. But, if I put a couple of Franklins into a new set of tubes, will it correct the problem?
    Next question, Microphonics
    I have read that all small tubes in a gain stage will be microphonic to some degree. How much is generally considered acceptable? Should touching the cabinet transfer into the speakers? Will replacement reduce this?
    Sorry for the long post but I know that I would rather learn first and the spend accordingly.
    Thanks
    Tim
  2. #2
    Re: Tube Noob, seeking education
    Good tubes shouldn't be microphonic or noisy. You also have a pair of 6V6 tubes in the preamp. Do you know how old they are in terms of hours of use? Kevin Deal has some good 6922 type tubes at a reasonable cost and he has some killer 6V6 tubes also.
  3. #3
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    If the preamp can take 7DJ8s too I would put the Phillips in it or for a mellower sound the National branded Mitsubishi's that Kevin carries. Another excellent choice is the Tungsram 7DJ8. You can get better prices on them from Tubemonger.
  4. #4
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    Hi Tim - welcome to AS! As to your post, a lot has to do with the amplifier design, transformer, tube type and tube brand (NOS vs Chinese/Russians new).
    Some tube gear is very quiet, others, not so much.
    BAT gear is typically very quiet due to its balanced design. I would call Andy at Vintage Tube Services and ask his advice for tubes.
    http://vintagetubeservices.com
  5. #5
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Quote Originally Posted by mep View Post
    The 6v6 are NOS JAN Sylvanias. No idea about the hours. Also have a set of Tung Sols and what appears to be the originals, black glass. I tried all three and there is not a lot of difference.
    Quote Originally Posted by Jack View Post
    My understanding is that the VK-3i doesn't do well with the 7DJ8. The work very well in the phono stage. Kevin has the Tungsram 6922 and I was considering it or the 6H23 type 3. On his website, Kevin recommends the EH 6922 for the VK-3i, I would just like to try something a bit better if I am going to spend the money.
    Thanks Mike, I suspect that the noise stems from the tubes. I was just not sure how much noise might be just normal operating noise.
  6. #6
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Either of the tubes you mentioned is better than the EH. The best of the new production would probably be the Genalex. Like Mike said I would take the time and call Andy Bowman at VTS his testing is the most extensive and his pricing will better than Kevins. I have the Tungsrams in 7DJ8's and the Reflector Grey Shield 6H23's both very good and somewhat similar sounding tubes. I have tried them both in a DAC and the input stage of the BHK amp.
  7. #7
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Well let's complicate things a bit. While listening to some records today, I noticed a crackling sound. It was the same sound that I heard when a tube went bad in the VK-P5 before. So to isolate the noise, I opened up the VK-p5 and removed the Phillips 7DJ8's that I put in about a month ago and installed the EH 6922's that I removed from the VK-3i. The crackling went away, and the EH tubes didn't seem to exhibit the microphonics that they did in the VK-3i. Hmmmm.......... with the EH 6922's and the JJ's in the VK-3i, just touching the cabinet can be heard through the speakers with the volume on. Even touching the glass of the tubes with a pencil in the P5, there is no sound transmitted to the speakers. I have three sets of the 6v6 tubes for the 3i, I have tried all 3 and there is no change in relation to the microphonics. Can a tube be microphonic in one device and not in another?
  8. #8
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Quote Originally Posted by Try1256 View Post
    ... Can a tube be microphonic in one device and not in another?
    The short answer is yes it can. Tubes are biased differently in various circuits and can be utilized moderately or pushed harder towards their maximum operating range. As such they can be more sensitive to any residual noise and/or microphonics in some applications than in others.
  9. #9
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    IMO either a tube is microphonic or it isn't. What you describe sound like the tube BUT the pins in the socket could be a bit too loose or very dirty also creating that symptom (been there done that). A cold solder joint on the socket can also do the same. If you want to attempt to tighten or clean the pins make sure the unit is OFF and UNPLUGGED. Little tubes usually have a plate voltage of 200+ volts. Large output tubes can have 400+ volts (my Octave V110 had 620 volts). Before attempting anything I would contact the manufacturer ask ask how long it takes for the high voltage to bleed off or the best way of discharging the hv. Depending on the design it could take days or weeks for the hv to bleed off by itself. My Octaves took a couple of hrs which is why I highly recommend contacting the manufacturer.
    Now that said I had what seemed to be a microphonic little tube but it turned out to be a loose pin for the grid on an output tube. And YES I am trying to scare you regarding the voltages because they can be lethal. Did I mention contacting the manufacturer or repair center that knows BAT regarding bleeding off the high voltages. I ONCE touched a -2000v supply (all voltage but no current) and couldn't spell my name for about 2 hrs. Very scary. That was about 40 yrs ago and never did anything like that again.
    George
    Aavik U300 - Borresen 03 with optional Supreme D-TC feet - Naim unitiserve 2tb - Ansuz DTC digital cable with power box - Ansuz Mainz8 D-TC with 1 Ansuz Supreme D-TC and 1 Ceramic V2 power cords - Ansuz Ceramic V2 speaker cables - Ansus X Ethernet - pARTicular Novus full suspension rack.
  10. #10
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    Audio.Bill brings up another good point but my loose pins were due to a lot of tube swapping
    George
  11. #11
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Thanks George. So once the high voltage is bled off, what is the prescribed method for cleaning and tightening the tube sockets? Thanks again
  12. #12
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    I had used pipe cleaners that had some hard things on it (non conductive). Another thing I would do scrape the pins with a dental pick. Just be careful not to get shavings falling into the chassis when scraping with the dental pick.
    George
  13. #13
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    For tightening I use the dental pick to manually push the ping together. Just start slow because you can push the pins together too close and bend them too much. Too much bending can weaken them.
    George
  14. #14
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    Sorry I was on the phone and not paying attention
    For tightening I use the dental pick to manually push the 'pins' together.
    George
  15. #15
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    A small jewelers type screw driver would also work just fine instead of a dental pick for tightening pins. Just make damn sure the high voltage is bled/shorted out.
    George
  16. #16
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Thanks George. Yes, I am well aware of the voltage they carry. I spoke with Victor Komenko today. I explained the symptoms to him and he seemed to think it could be oscillation. I tried everything he told be to do to try to isolate it but it persisted. I believe I may have accidently come across a possible cause. The built in phono board. I notice that when I switch to and from the internal phono, there is a pop in the speakers and when turning the volume knob, it clicked at every step. That only happened when the internal phono was selected. I decided to remove it to see what happened. Once I took it out and the preamp back in, the majority of the microphonics went away. I think one of my 6v6 tubes may be microphonic but the whole unit didn't pick up touch. The only problem was that when I removed the phono board the right channel went away. I am not sure if that was a result of removing the board thought. When I put it back in, the right side was still out. I switched the left and right outputs and it came back. I may have not seated the connector well when I put it back in. I am going to try and speak with Victor again tomorrow and see if removing the board has an adverse effect on the preamp.
  17. #17
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    The fact when you touch anything and duplicate the problem to me indicates a bad connection somewhere. Which is why I mentioned even a cold solder joint. A loose connection could also do the same. Pins in the tube sockets tend to loosen up with a lot of tube swapping. Did the microphonics come back when you put the phono board back in?
    Well I hope when you get to speak with Victor again you can isolate the problem(s?).
    Best of luck
    George
  18. #18
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Yes, when I re-installed the phono board, the microphonics came back. Victor was very helpful. I know it is difficult if not impossible to really diagnose problems with electronics over the phone. If it is ok to operate the unit without the factory installed phono board, I will probably remove it again to see if that completely solves the problem. It will be much less expensive to ship just the phono board to BAT for repair so if they will repair it, I will probably send it to them. I am glad that I got online and asked a few questions before ordering a new set of 6922's. Not that having more tubes isn't a good thing, but I would have been very frustrated had I spent the money and the problem didn't go away.
  19. #19
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    Agreed it's hard to troubleshoot over the phone or internet. Does the phone bd plug into what looks like a connector board for a computer or is connected via cables? I have a hard time trying to figure out how an oscillation would occur or get worse when touching something.
    George
  20. #20
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    The board plugs into a connector on the main board. 2 wires plug into the input connector board on the back.
  21. #21
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    Thanks those connectors/connections have the potential of causing your symptom.
    George
  22. #22
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    How would I proceed to identify if it is a connector or a component on the board?
  23. #23
    Senior Member
    Join Date
    Aug 2013
    Burb of Chi-town
    Posts
    588
    That's hard but I would be looking for cold solder joints (usually very dull colored) or a bad crimp on a wire. As far as a component you would need a scope or possibility a meter if you know what the purpose of that component is. Still it's the touching of anything that makes me believe it's a bad connection somewhere.
    George
  24. #24
    Join Date
    Oct 2015
    Winter Springs, Fl
    Posts
    60
    Well it seems that I have found the culprit. One of the JAN Sylvanias was microphonic in a grand way. The gentleman that I purchases the unit from led me to believe that they had been replaced fairly recently but didn't say exactly when. I guess the other 2 pair I have are bad too. I replaced them with a pair of Tung Sol re-issues. No longer microphonic to touch. They really tightened up the sound a lot. Cleaner lows and a generally much better presentation. I wiil probably replace the 6922's soon as well but for now the are working well and sound good. Thanks for all of the input and guidance.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
