Results 1 to 27 of 27
Thread: Subwoofers for muddier bass
September 26, 2016, 09:15 PM #1
- Apr 2016
- Bay Area
- 760
Hi Folks,
I am currently using a pair of AZ Crescendo MkII in a 15'x20'x8' room. The Crescendos are powered with Nords One up monoblock. The problem I have in the room isn't the lack of or boomy bass but the bass is muddier. Most of the time its difficult to hear or differentiate between notes in the bass line and they presents as a one note tone. The same speakers in other places I have listened to works wonderfully and very musical. I have GIK monster bass traps in the corners behind the speakers and tried several different speaker position but without luck. The back of the speakers are about 6' from the back wall.
I have been thinking of getting a pair of REL subwoofers to handle this problem but not sure if it would help in my situation. What are your thoughts on this ?
Appreciate any response and thanks in advance.
-- Dev
September 26, 2016, 09:32 PM #2
Re: Subwoofers for muddier bass
Dev, once I put too many bass traps in my media room and my bass became one note and very overbearing. Removing two of them cured that issue for my room. Just given as an information point. As a suggestion, perhaps you could remove your current bass traps and measure the room's response and then treat to respond to the measurements.
Regards,
Steve
https://www.audionirvana.org/forum/t...geezr-s-system
I only do what the voices in my wife's head tell her to tell me to do.
September 26, 2016, 11:21 PM #3
- Apr 2016
- Bay Area
- 760
Thanks Steve. I had earlier started with 4 of them (based on GIK's recommendation from the REW measurements I had sent them) and now down to 2. It helped in making the room a bit more lively. I would certainly remove the remaining and re-measure this coming weekend. My impression from reading various forums, especially from Realtraps, is that every room needs a minimum of 8 bass traps to tame the room modes. I can't put those many numbers traps, so was looking for a solution with the subs.
September 26, 2016, 11:36 PM #4
- May 2013
- 3,242
If you are using them in the corners behind the speakers have you tried moving them to the corners on the other end? Don't know how you came up with the 6' from the rear positioning but have you tried moving them back to a starting point of 2' from the front baffle and coming forward 6" at a time. I usually start with divisions of the room by odd numbers as recommended by Vandersteen and then an inch at a time. In this room I use fifths and it has worked for every speaker with minor adjustments.
September 26, 2016, 11:56 PM #5
- Apr 2016
- Bay Area
- 760
Jack,
the 4 traps was in the front corner (behind the speakers) stacked one on top of another. I can't move them to the other corners since these corners are occupied to other stuff - one had a sliding door and other has a cabinet.
I think I have tried most of the speaker placement available - cardas method, Wilson method, Vandersteen method, rule of 1/3rd, rule of 1/5th, and several others which I don't remember. Started with the back against the wall (for bass reinforcement) and quickly realized that it needs to moved forward - a typical problem that usually one faces is the best position for bass is not the position for a great soundstage. The current distance gets me an excellent soundstage and good bass, its just that the bass lacks quality or isn't musical enough and sounds like a one note.
Any other possible experiments could you think of ? The other part I wanted to understand is what causes these kind of problems ? Too much ringing ? If we understand that, then it might be easier to find a solution ?
September 27, 2016, 12:19 AM #6
- May 2013
- 3,242
Was the bass trap design before the AZ's, if so they may not be necessary at all with that particular speaker. Like was suggested earlier take them all out and see what you get. When I had TL based Reynauds in this room I didn't use any bass traps, same with the the sealed Vandersteen's. I only had to get bass traps when I went to rear ported speakers to alleviate a 70-80 Hz hump. In the interest of full disclosure all of those earlier set ups included Vandersteen 2WQ's which may have alleviated the problem. When I put the KO's in the room I never could get the 2WQ's to blend with the Nola's so I took them out. Then the obvious hump was hard to avoid. It was then that I had to look for other solutions.
September 27, 2016, 04:34 PM #7
- Apr 2016
- Bay Area
- 760
Ok, so I removed all the traps and the results are surprising. The sound stage opened up quiet a bit and now I stated to feel the musicality in the bass but its a bit bloated which I guess is expected after removing the bass traps. This weekend I would take some measurements and see what gives. I also think I might need to redo the speaker placement.
Now that I think back, apart for the audio shows, the two personal rooms (one is of Robert's itself) I heard the Crescendos did not have any bass traps either. So may be it was fault on my part and overthinking that every room needs some. Now that I have bloated bass, how do I go about solving this ?
Btw Jack, how did you solve the 70-80 Hz hump ? Its been a long time since I took measurements of my room but as far as I can recollect, I have a deep suck out in 30-40Hz range and few humps in the 80Hz and 120Hz range.
September 27, 2016, 04:39 PM #8
Dev - what you are hearing now, is it with your Pass amps or your NORD amps?
30-40hz + 80-120hz is a big range.
MikeMy Systems: http://www.audioshark.org/showthread...481#post158481
September 27, 2016, 04:53 PM #9
- Apr 2016
- Bay Area
- 760
Sorry Mike, I might not been clear - One big suck out closer to 37Hz and two peaks - one closer to 87Hz and another one closer to 120Hz. These were taken a long time back and at the time I was using the Pass X250.5. Since then I have changed speaker position multiple times. I will redo this weekend and repost. Sorry for the confusion.
Right now I am using the Nords.
September 27, 2016, 04:56 PM #10
September 27, 2016, 05:04 PM #11
- Apr 2016
- Bay Area
- 760
September 27, 2016, 05:16 PM #12
September 27, 2016, 05:46 PM #13
Well it will be a little easier to solve this problem since you have REW and can see as well as hear the results. Check out the waterfall plots in addition to the frequency response ones. Look for modal ringing in the range of 50 -300Hz and for 300mS or more.
It takes trial and error and patience. Establish a centerline in the room and a way to mark the positions of the speakers and proposed listening position. Start moving the speakers fore or aft in 6" increments measuring as you go. Then move the listening position if you can once you've got the speakers and measurements sounding/looking good as that'll make an even bigger difference most likely. Once you've got the placements down try adding the bass traps.
Of course you could buy Jim Smith's book "Get Better Sound" if none of this makes sense. It's chock full of other good stuff as well.
Using subs adds a whole other level of complication but it does allow you to optimize sound stage separately from bass. I bet this is fixable without them.
Good luck!
September 28, 2016, 01:37 PM #14
Thanks for the comment, Barry!
FWIW - I am currently writing a series on correct subwoofer set-up with "full-range speakers" over at the Copper e-magazine. But it won't be quite what most audiophiles expect, especially if they suffer from ACK.
ACK:
http://www.psaudio.com/article/the-a...mon-knowledge/
Subwoofery:
http://www.psaudio.com/article/subwo...rick-or-treat/DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
September 28, 2016, 01:59 PM #15
- Apr 2016
- Bay Area
- 760
Some updates:
After removing the traps, I felt something was missing with the sound. So I tried playing with the speaker positioning and re-adjusted to move it by a 1ft closer to the wall. I also had to move forward my listening position a bit. Bass is much better & taut but still a bit bloated.
I am getting the TWL Digital American high current power cords for the Nords tomorrow. Will update the thread after it has settled down.
@Mike, I tried the Pass, same results.
@Barry, will do measurements over the weekends.
@Jim, I have your DVD set for a while now. Is there anything in the book that is not covered in the video ? I am very much looking forward to the subwoofer setup series. I don't have any ACK whatsoever, can I get my hands on earlier ?
September 28, 2016, 02:03 PM #16
Dev - does it sound like the bass lingers longer than the rest of the music or is the bass just flabby and uncontrolled? Also, are the speakers spiked?
September 28, 2016, 02:13 PM #17
Seat position first - then, speaker position. Always.
There are 202 tips in the book, so yes...
But first, are you receiving the FREE Quarter Notes newsletters for GBS owners?
There have been several installments already. Issue 14, 15, & 16.
Sorry, unsure what you are asking.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
September 28, 2016, 02:31 PM #18
- Apr 2016
- Bay Area
- 760
Mike, the answer seems to be both. For some freq, it lingers a bit longer than others. I have listened to it briefly yesterday but I guess the only way to tell for sure is to take measurements. What I can say now is I can hear the bass but its not strong enough compared to the rest of the audio spectrum.
I have hardwood floors. Currently the speakers are not spiked. I am using Herbies speaker decoupling gliders. I had Stillpoints Ultra SS on them sometime back but there was some good bit of resonance coming from the lower part of the speaker base. Maybe I wasn't doing it right. I can put it back or try the stock cones one more time.
September 28, 2016, 02:38 PM #19
- Apr 2016
- Bay Area
- 760
So this is what confuses me - so help me understand. How can I hear the bass and soundstage without putting the speakers in the right place ? In other words, in order to determine the seat position, do I need to put the speakers in a predetermined location ?
Ok, sounds good.
Nope. I bought the DVD set from Amazon.
I wasn't aware of all the installments. How can I get them ?
September 28, 2016, 05:53 PM #20
Sorry!
I am on a RoomPlay voicing session.
Will reply on Friday when I return.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
October 1, 2016, 11:53 AM #21
I'd get them generally as far into the room as seems possible.
Send me an e-mail requesting them and I will add you to the mail list and send you links to all of the 19 QNs so far.
jim@getbettersound.com
Its easiest to simply subscribe - there's a lot of interesting info.
Here are links to the various issues in which I have contributed:
http://www.psaudio.com/issue/issue-12/
http://www.psaudio.com/issue/issue-14/
http://www.psaudio.com/issue/issue-15/
http://www.psaudio.com/issue/issue-16/
As you can see the issue links are predictable - I am writing for Issue # 17 now.DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
October 2, 2016, 07:23 PM #22
- Apr 2016
- Bay Area
- 760
October 2, 2016, 07:30 PM #23
- Apr 2016
- Bay Area
- 760
I did some quick REW measurement this morning after playing with the listening and speaker position. The bass has been a lot better but still not there. The speakers are very much into the room about 1/3rd of the length measuring from the back wall to the back of the spkr and my listening position is also about 1/3rd (a bit less) from the wall behind. In this position, all ratios of speaker to listening distance doesn't seem to apply but I felt has the best soundstage and bass.
Here is the SPL graph with 1/12 smoothing.
Here is the waterfall
October 2, 2016, 07:43 PM #24
Devg, have you tried starting over completely from the front wall with the speaker positioning?
I believe you said you moved them back 1 foot from their original position.... but not sure what that equates to.
I guess what I'm asking is have you started with the back of the loudspeakers a distance as close as you can to the front wall whether that be 1 foot or 2 foot and then go forward toward the listing position from there?
Maybe your room and set up simply needs more coupling of the loudspeakers to the room?Avanti Audio
October 2, 2016, 07:54 PM #25
- Apr 2016
- Bay Area
- 760
Mike, yes, I started from 1ft from the back wall but the sound is too harsh and hard. The bass is also more muddier. With this speaker, I haven’t heard any setup sounding good when they are close to back wall. The soundstage looses dimensionality and sounds flatter the closer the speakers are to the back wall.
October 2, 2016, 08:01 PM #26
Avanti Audio
October 2, 2016, 08:23 PM #27
- Apr 2016
- Bay Area
- 760
There is no bass traps in the room now. The problem with my room is the listening position changes with the speaker position. The listening position from the smoothest bass response when the speaker position, say 3ft from the back wall is no longer valid when the speaker position is say 5ft from the back wall. This is the exact question I asked Jim in the earlier post and he suggested to move the speaker as far away from the back as possible. My speaker designer, Robert, suggest to first find the speaker position and the decide the listening position which is opposite of what Jim suggests but I find they are kind of chicken-egg problem
Thank you for making me feel less tech challenged.:whew: FYI, The 866 works great as a straight, no nonsense integrated with DAC.
Boulder 866 app
