Results 51 to 97 of 97
Thread: Entreq Ground Boxes & Cables
October 2, 2016, 02:06 PM #51DPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
www.getbettersound.com
October 2, 2016, 02:08 PM #52
Re: Entreq Ground Boxes & Cables
April 11, 2017, 12:31 AM #53
- Jan 2016
- Australia
- 24
Another endorsement of Entreq grounding boxes. My tube power amp and tube preamp are connected to a Poseiden via Apollo cables. What I have heard in my system is a larger & fuller soundstage, more tonal colour and a more engaging sound - with no loss of dynamics. I consider the money well spent.
April 11, 2017, 07:02 AM #54
October 8, 2017, 03:58 AM #55
- Dec 2015
- Forest of Dean UK
- 134
Reading through this thread, there seems to be confusion as to using Entreq with Vitus, as far as I know Vitus owners are using Entreq without problems? Can somebody clear this up.
My own experience with using Entreq on a one day trial, was very positive. We started at the digital end with a Olympus Maximus connected to the fidata server and then went through upgrading the cables. Every stage was a positive. Moving to the Tallus 2 was slightly better I think, but I need to double check this? We then introduced the Poseidon, connecting the Mola Mola pre/dac to the centre post and the negative amp terminals separately to the two outer terminals. All the positive aspects of a clean back ground, more space around the instruments, more natural top end, better bass definition, were intensified with this set up. Highly recommended.
PS Should add that the Everest’s had a positive result as well.UK audio dealer for: Mola Mola, Cube Audio, Boenicke, Lumin, Fidata, Sablon, SteinMusic, Ingress www.toetapaudio.com
October 8, 2017, 08:20 AM #56
- Apr 2013
- 61
Hi , I use the Poseidon with my Vitus amp , have hid no problem . Only positives.
October 8, 2017, 11:35 AM #57
- May 2017
- Cleveland, Ohio, USA
- 531
October 9, 2017, 04:01 PM #58
Francisco
October 11, 2017, 08:08 AM #59
- May 2017
- 531
If the three terminals are all independent, then it will be safe. Just like connecting 3 independent insulated wires. Although some audiophiles call that 'Groundside Electronics'. All a wire connected at only one end can do is act as an antenna.
October 20, 2017, 05:57 PM #60
What they tell you from Vitus, is exactly like what the Constellation technical service told me: If I plugged the negative terminals of my amplifier into two Silver Minimus boxes, the amplifier, "kaputt".
Frankly I did not understand it, but I still did not dare. Until a guy from WBF sent a picture of his stereo Centaur, with the terminals connected to two Silver Minimus boxes, then I decided to do it. And ... nothing happened. Well, something happened, my system sounded better. Many manufacturers hear the word Earth, and they no longer want to hear anything more than you explain, say NO.
On the other hand I have to say that in my experience with Entreq boxes, the connection of these to free signal outputs (RCA, XLR, USB, RJ45), has always improved the sound. However, this has not been the case when I have connected the chassis ground terminals (on those devices that have them).Francisco
October 20, 2017, 06:53 PM #61
October 21, 2017, 11:12 AM #62
I wonder how many people have blown up their gear because they grounded things that should have never been grounded? We probably don't hear those stories just like gamblers only tell you when they win.
October 21, 2017, 02:34 PM #63
- Jan 2014
- Los Angeles
- 1,775
October 21, 2017, 04:23 PM #64mauidanGuest
October 21, 2017, 07:09 PM #65
Anyone opened up one of these boxes to see what is inside? Seems like hoo-do-voodoo
Sent from my iPad using TapatalkPreamp/Digital: Meitner MA3
HT Processor: Bryston SP3
Amps: Bryston 14b3, Bryston 4b3
Speakers: Kef Reference 5, Kef Reference 4c
Sub: REL Carbon Special
Power: Shunyata Denali, Bryston BIT15
Wires: Wireworld Silver Eclipse XLR & SC, Ethernet - WW Platinum USB
Other: Stillpoint Ultra SS, ISO-Acoustics ISO Pucks
-Kyle
October 21, 2017, 11:13 PM #66
October 22, 2017, 02:52 AM #67
- Aug 2014
- east of Seattle
- 821
you can kill or maim yourself with a hammer. but you'd have to be pretty stupid. it's a tool that requires proper use....and basic common sense.
Entreq gear is not a problem to use, it does require common sense....and it is not just casually plug and play. but used properly in an appropriately sorted out system, it does improve performance.....in my personal experience. YMMV.
I use my Entreq Poseidon and -3- Atlantic Minimus boxes (as boosters) to ground the negative terminals of my dart mono blocks, plus ground my bass tower amps. makes a significant contribution to performance.
as I recently got a Tripoint Elite for my sources, and moved my Tripoint Troy Sig to chassis ground my dart mono's + ground my passive main speaker towers, i'll be moving my Entreq Silver Tellus across the room over to my Studer RTR decks.....as the Silver Tellus is redundant on my other sources now with the Tripoint Elite in that spot.
October 22, 2017, 07:28 AM #68
[QUOTE = mauidan; 218792]
[/ QUOTE]
Well, there seems to be exactly what Entreq says there is; a mixture of minerals whose formula obviously do not publish.Francisco
October 22, 2017, 06:46 PM #69
A plywood box filled with dirt. Magic!!
-Kyle
October 22, 2017, 06:52 PM #70
- Aug 2014
- east of Seattle
- 821
October 23, 2017, 09:37 AM #71
- May 2017
- 531
Well the best simple definition of 'ground' is:
That 'ground' acts as a common reference point.
From the descriptions of these boxes that I have read, they don't act as a common reference point.
In fact the boxes don't meet any definition of 'ground'.
So it's hard to image a way for them to blow anything up.
In the cases where they are connected to RCA chassis jacks that have plastic insulator rings, the box & wire can act as an interference antenna.
October 23, 2017, 10:43 AM #72
I wasn't strictly speaking about the Entreq boxes, but more to the point that we have some people who are bereft of electrical knowledge who now think everything should be grounded. And if the Entreq boxes aren't really grounded to ground, what are they doing? Are we floating ground now?
October 23, 2017, 12:36 PM #73
- May 2017
- 531
From an electrical engineering perspective, they arn't doing anything.
Yes, we can float an audio circuit common from an AC power circuit Safety Ground.
But the basic definitions for ground are:
a] Common reference point.
b] Path to such a point.
Most of the boxes don't meet these definitions, but I recall seeing one box that did. (it functioned as a terminal strip for several ground wires)
October 23, 2017, 01:51 PM #74
October 23, 2017, 02:17 PM #75
I don't know if we are arguing semantics now. Voltage is referenced to ground and you either have a true ground or you don't. So I don't understand how people are connecting a ground wire to a device that is not truly grounded and somehow they think they have now established a "better" ground.
October 23, 2017, 02:29 PM #76
- May 2017
- 531
October 23, 2017, 02:32 PM #77
- May 2017
- 531
October 23, 2017, 02:42 PM #78mauidanGuest
There is a warning on the Stillpoints website:
"You must use one Ground box and one ground cable per channel! Never use a single ground box to connect both channels. You will likely damage your amplifier."
You can use one Poseidon which has three independent ground terminals.
October 23, 2017, 03:00 PM #79Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
October 23, 2017, 05:05 PM #80
Nordosts’ brand Q Kore is similar and provided an amazing change in sound for me. The unit provides two paths; distribution and components. I have only installed this on the component side, but will do the distribution side this upcoming weekend.
I can only assume Entreq is similar in nature, and if it does close to what Nordost accomplished, it was worth the investment. Louder with a clear soundstage. I am really focused on power products to the various gear and room treatments as I have heard the difference; now my newest part of the hobby.Source Analog: Kuzma Stabi R w/4point 11 arm | Kuzma 50 Cartridge
Speakers: Wilson Alexias
October 23, 2017, 06:20 PM #81
These might be worthwhile, after your system is working with the room, rather than against it - in other words, when you have optimized the acoustic wave-launch into the room and you are receiving it optimally at your seat. If not, then some part of your investment has been wasted, IMO.
Sent from my iPhone using TapatalkDPT4ME - Dynamics, Presence & Tone for Musical Engagement; MBP (3) - stripped down for music only; Shunyata Omega & Sigma USBs; ISO REGEN w/short Curious USB links; Berkeley Alpha USB; Aqua La Scala II Optologic DAC; Schiit Yggdrasil - fully updated; Ayre Codex dac - updated; Pass Labs INT-60 integrated amp; Wyred 4 Sound STP-SE-2 preamp, Quicksilver Mono 120 amps w/Tung-Sol KT150s; Quicksilver Mid Mono amps w/Gold Lion KT77s; Fyne Audio 703s; Symposium Svelte Plus & Ultra Platforms; REL S-812 subwoofers; Duelund DCA12GA speaker cables; AV Room Service EVPs, Stein Music Harmonizers, Duelund DCA16GA & 20GA ICs; Shunyata Denali 6000S/V2; Tripp Lite PCs; Wyred 4 Sound power cords; AudioDharma cable cooker; dedicated custom room; various GIK & ASC room treatments; etc.
October 23, 2017, 07:33 PM #82
That to me applies to most aspects of building a system, for best results I have learned that having the room treated for acoustics is key and actually much cheaper then buying gear. However, tradeoffs can enter into the equation; aesthetics, “must have nows”, education/experience and similar lead back to a reduction of optimization, but in the end, it’s all about you and what makes you happy in this CRAZY hobby.
October 23, 2017, 08:50 PM #83mauidanGuest
October 23, 2017, 10:09 PM #84
I said they might be helpful, but they cannot provide even 10% of the impact of getting the acoustic wave-launch optimized.
If you’ve not experienced the power of unlocking your music’s emotional engagement, I can understand your skepticism.
Rather than engage in the typical forum argument, you can have the last word.
October 23, 2017, 10:20 PM #85
I certainly agree that having the room treated for acoustics is helpful, especially when the proper location for seating position (always the first step) has been accomplished, and you are working to locate the optimum speaker location to create the best acoustic wave-launch.
Room treatments alone? Not so much...
IMO/IME, of course.
October 23, 2017, 10:29 PM #86mauidanGuest
This isn't a question of having the last word.
You haven't heard the product.
I'm not worried if my system has had its "acoustic wave-launch optimized."
IMO, anyone that's familiar with the sound of their system should be able to tell if this product makes an improvement.
October 23, 2017, 10:30 PM #87
- Aug 2014
- east of Seattle
- 821
+1.
these type products are not universally plug and play. it's always easy to be negative on things you don't understand.
I use both Entreq and Tripoint grounding products in my system. and it was not until I completed my room tuning that these products really made significant differences in performance. these products are not a band aid on room issues, they are enhancements and accents in a mature finely tuned system. they lower noise floors, enhance note development, add bass articulation, and increase degrees of musical cohesion.
if you feel you have your system sounding 'right'; then these grounding products can take you further.
October 23, 2017, 11:21 PM #88mauidanGuest
Mr.Smith and Mike,
If I evaluated this product in a high-end headphone system, what does the "impact of getting the acoustic wave-launch optimized/room tuning," have to do with anything?
October 24, 2017, 12:20 AM #89
- Aug 2014
- east of Seattle
- 821
having owned a high end headphone system a few years ago (the BHSE and Stax 009's along with some other stuff) no doubt grounding products improving source and amplifier performance would matter; but it would be a complete guess as to how much. obviously the whole 'wave launch' thing is solved with headphones up front.
room<-> system synergy problems and acoustic issues cloud the musical nuance benefits of grounding products, and headphones should eliminate that clouding, but without a soundstage to take advantage of, it's unknown whether the full benefit of improved grounding would be heard.
so my take would be of a somewhat diminished benefit with headphones, but any possibility is possible. you might hear more benefit depending on exactly what overall room-amp-speaker system you compared it to.
October 24, 2017, 08:42 AM #90
I think Dan's response was a bit tongue in cheek. Why are we talking about "acoustic wave-launch" in a thread about Entreq Ground Boxes & Cables? They either make your system "better" or they don't and reducing or eliminating the effects of a "bad" ground scheme is independent of what Jim's business model is all about.
October 24, 2017, 08:44 AM #91
October 24, 2017, 09:42 AM #92
- Aug 2014
- east of Seattle
- 821
I did not read Dan's comment that way. it seemed he was wondering whether Entreq grounding products related to headphone listening, since obviously Jim's 'wave launch' comment was not relevant to headphones. and as I had had considerable experience with higher end headphones and grounding I felt I had a contribution to make.
these grounding products are not about fixing bad ground schemes. they are about enhancing the degree of grounding's benefit to circuits. you take a circuit ground and provide it a more effective ground. it's about lowering EMI/RF in degrees, and calming power supplies.
a mature system working well in a room can be tweaked in various ways, whether it's better resonance control, or better power grid tweaks, or grounding enhancements. this is not to say any of these issues show that something is broken to begin with, only that there is more progress than can be made in certain areas......if your mind is open to these possibilities and you are in the mood to try them. and if you would rather leave well enough alone, then no worries.
and Jim's comments, which I completely agree with, is that tweaking the signal path of a system which has significant room-speaker set-up and acoustic issues is a bit chasing your tail as you don't know what is causing what. a certain maturity needs to be achieved in a system for deeper tweaking type benefits to be revealed. the lower the noise and higher the resolution of a system, the more ROI one gets from any tweaking. sure; Jim's business is the whole system set-up stuff, so he does know about the order of approach and priority pretty good. he was just trying to be helpful.
October 24, 2017, 09:43 AM #93
- Aug 2014
- east of Seattle
- 821
October 24, 2017, 10:23 AM #94Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
October 24, 2017, 11:34 AM #95
That type of exchange is what makes AS "The friendliest audio forum"!
October 24, 2017, 05:05 PM #96mauidanGuest
Mark,
Here's an old thread with some good info on this subject:
https://forum.audiogon.com/discussio...ghlight=Entreq
Pay close attention to atmasphere (Ralph)'s posts.
October 25, 2017, 08:52 AM #97
Dan-I tried to slog through it all and I think I read everything that Ralph posted. I understand Ralph's position as it's grounded (pun intended) in science. I really need to bow out of this thread because I don't own these products and nor have I heard them in my system.
One of our Clarisys dealers installing the active crossover and 6 amps for a customer in Washington State Clarisys Auditoriums.
Going active in Washington State
