Results 1 to 48 of 48
Thread: Rockport Lyra
August 15, 2016, 04:39 PM #1
Rockport Lyra
http://www.theabsolutesound.com/arti...oics-in-maine/
Rockport's first time using aluminum. Following in Magico's footsteps? Hmmm...My Systems: http://www.audioshark.org/showthread...481#post158481
August 15, 2016, 05:35 PM #2
Re: Rockport Lyra
Wow, they are following Goldmund, Krell, Magico and YG footseps with aluminium enclosure.
Adam
Speakers: Magico M3
August 15, 2016, 06:07 PM #3
Re: Rockport Lyra
Hmmm, has a nice ring to it
August 15, 2016, 06:40 PM #4
- Jan 2014
- Los Angeles
- 1,775
Re: Rockport Lyra
wow- 150k!
August 15, 2016, 10:59 PM #5
- Apr 2016
- 139
Re: Rockport Lyra
Wow 150K! I guess I won't be putting my poor little Cygnus up for sale any time soon towards an upgrade!
Actually Mike, Andy used aluminum for the front baffle in both the (ahem, my ) Cygnus as well as the Atria, but you are right, the Lyra is the first Aluminum Enclosure from Rockport, albeit in a constrained layer construction with an inner and outer aluminum shell with the middle layer filled with an epoxy granite co-polymer, so no ring Joe . The construction is called DAMSTIF. I think this construction is unique thus far in the high end. I can hardly wait to hear them! I've had my Cygnus for less than a week and I'm already pining for another beau.
Kerry
August 16, 2016, 10:40 AM #6
- Jan 2014
- Los Angeles
- 1,775
Re: Rockport Lyra
does Rockport exhibit at RMAF?
August 16, 2016, 10:41 AM #7
Rockport Lyra
Typically yes
Cyril
August 16, 2016, 10:49 AM #8
- Apr 2016
- 139
Re: Rockport Lyra
Smart Money says that the Lyra will be there, but Rockport has not yet taken a room. Perhaps Andy will be exhibiting with Doshi electronics.
August 16, 2016, 11:34 PM #9
- Apr 2013
- Lower Provo River
- 208
August 17, 2016, 12:17 AM #10
Re: Rockport Lyra
These?
https://youtu.be/sU7rugLhgyI
Seriously?
From the Magico website: "MAGICO has pioneered the use of aluminum in loudspeakers design. We built our first aluminum enclosure back in 1994 and have never looked back. Extremely stiff yet easy to damp, a properly designed aluminum enclosure is the ideal platform for high-performance loudspeakers. So inert, the enclosures have no discernible coloration of their own-allowing the drivers to operate with the utmost clarity and dynamics. Though costly to implement, the use of aluminum in our enclosures plays a vital role in our design philosophy."
Me thinks there's a difference between:
And
August 17, 2016, 12:20 AM #11Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
August 17, 2016, 12:42 AM #12
- Apr 2013
- Lower Provo River
- 208
Re: Rockport Lyra
Actually quite seriously. 1994 is pretty late to the party.
Braun Output C was the original mid module in the original WAMM in the late 70's. The enclosure was cast just as the new Rockport is. They were hardly the first.
Aluminum is not new on any level. There were others back then as well.
As I said, what's old is new again.
August 17, 2016, 01:47 AM #13
Rockport Lyra
Avanti Audio
August 17, 2016, 01:52 AM #14
Re: Rockport Lyra
August 17, 2016, 07:32 AM #15
Re: Rockport Lyra
Wow, didn't know that those Brauns had the aluminium enclosure. Do you know what is the exact model name ? I would buy a pair myself, just for fun.
I thought it was Goldmund, in the early 80s, who pioneered the use of aluminium in a speaker design in their Apologue model.
Adam
Speakers: Magico M3
August 17, 2016, 08:40 AM #16
- Apr 2016
- 139
August 17, 2016, 09:11 AM #17
- Apr 2013
- Lower Provo River
- 208
August 17, 2016, 09:14 AM #18
- Apr 2016
- 139
Re: Rockport Lyra
I think its worth repeating that the Lyra, to the best of my knowledge is the first aluminum - polymer layered composite enclosure, this is another method to achieve a tremendous reduction in the natural tendency of aluminum to 'ring out', the other being the heroic internal bracing employed by Magico. Which method is 'more' Heroic is up to you.
August 17, 2016, 09:45 AM #19
Re: Rockport Lyra
Thanks for the info.
I believe the full name of the Braun speaker is Output Compact:
http://www.radiomuseum.org/r/braun_output_compact.html
The one with the mounting bracket is C8 or L100.
http://www.hifido.co.jp/KW/G0201/J/2...2441-76100-00/Adam
Speakers: Magico M3
August 17, 2016, 09:55 AM #20
- Apr 2013
- Lower Provo River
- 208
Re: Rockport Lyra
I owned both, including a couple of pairs mounted on the back deck of BMWs (2002, 320i, 528i) in the 70s/early 80s. At the same time, ADS was building active car speakers with Braun drivers - the 2001 and 2002. Had both of those as well - mounted in a 66 Mustang convertible.
August 20, 2016, 10:00 AM #21
Re: Rockport Lyra
That is right. However I don't believe Magico was the first in using aluminum housing in a high-end speaker though. As an example Piega from Switzerland is building high-end, superb quality speakers for more than 25 years.
http://www.theabsolutesound.com/articles/swiss-jewel/
The Piega MLS2 was reviewed in the August edition of Audio magazine and ended on top just behind the Gauder Berlin RC9. I know this is just an opinion but it says something coming from a highly respected magazine.
Hans
Bowers & Wilkins 805 D3 /alternatively JM Lab Point Source Aria 5 (self modified)/ 2x SVS 3000 SB, Audionet AMP (2x), dCS Bartók used as streamer / DAC / preamp, Pro-Ject RPM 9 with Speedbox S and Orthofon MC Vivo Blue, KEF LS50 Nocturne / Sunfire Atmos(kitchen). Patio: Bluesound Node 2i and Focal CMS50.
RoonServer on Nucleus.
November 11, 2016, 03:08 PM #22
- Mar 2016
- 144
Re: Rockport Lyra
Any further news on these? For such a significant product introduction it´s been awfully quiet since the initial August impressions.
November 29, 2016, 11:11 AM #23
- Jul 2014
- 45
Re: Rockport Lyra
There is a video on YouTube detailing the construction methods of the Lyra. Because I do not have 10 posts (moderators, are you freaking kidding me?!!!!!) I cannot post the link, but its on YouTube.
November 29, 2016, 11:22 AM #24
Re: Rockport Lyra
True, Magico was not the first, they have taken it to a different level
thou ...
https://m.youtube.com/watch?v=f-TjOCuFZcU
November 29, 2016, 11:56 AM #25
- Jul 2014
- 45
Re: Rockport Lyra
At A.Wayne- That's the video, thank you.
On a seperate note,Rockport must be increasing their production capability. I see that they are being carried in more stores than in the past (which was Goodwins pretty much).
November 29, 2016, 12:52 PM #26
Re: Rockport Lyra
Lyra DAMSTIF
Some who have heard this speaker report this to be Andy Payor's best effort to date!
https://youtu.be/f-TjOCuFZcULe Roy
Foundation:
November 29, 2016, 01:06 PM #27
Re: Rockport Lyra
Alloy speaker shoot out next ... Rockport vs Magico vs YG
December 7, 2016, 04:10 AM #28
- Apr 2016
- 139
December 7, 2016, 05:22 AM #29
Re: Rockport Lyra
Rockport Lyra speakers; TotalDac Amp-1 mono blocks; four box CH Precision L1/X1 pre/power supply monos; CH precision P1/X1 phono/power supply; TotalDac d1-driver monos; Pacific Microsonics Model 2 DAC; TotalDac d1-12 MkII DAC with two reclockers; Kodo The Beat Turnatable with LT Schroder magnesium tonearm and Lyra Atlas cart; Taiko Extreme server; Kalista Dreamplayer CD Transport; Taiko Audio Daiza Platforms; Nordost Odin2 Power Cords and Analog ICs; 512 Engineering/Tim Marutani Balanced Transformers (30 amp for sources; 50 amp for amps); Rives designed dedicated room.
December 7, 2016, 06:59 AM #30
Re: Rockport Lyra
Wow, congrats. Are you gonna drive it with the Ayre integrated you have ?
Adam
Speakers: Magico M3
December 7, 2016, 12:35 PM #31
- Apr 2016
- 139
December 7, 2016, 06:11 PM #32
- Jan 2014
- Los Angeles
- 1,775
Re: Rockport Lyra
Lots of new Rockport owners. Congrats
April 16, 2017, 03:59 PM #33
- Mar 2016
- 144
Re: Rockport Lyra
I´m surprised how very little info there is available on the Lyra´s sound as of now, has anyone listened to them? Is Rockport going to be showing these at Munich? No news is probably good news for Rockport since it probably means the speakers sell themselves.
May 25, 2017, 11:16 AM #34
- May 2015
- Orchard Lake, MI
- 23
May 25, 2017, 12:58 PM #35
Re: Rockport Lyra
They sounded wonderful in Munich. #1 room for me.
Adam
Speakers: Magico M3
May 25, 2017, 01:25 PM #36
Re: Rockport Lyra
+1 .. one of the best rooms for me as well
.2 Channel Stereo :
May 25, 2017, 03:09 PM #37
- Mar 2016
- 144
Re: Rockport Lyra
Thanks guys, there seems to be very good synergy between Absolare and Rockport every year at Munich.
August 11, 2017, 08:01 AM #38
- Apr 2013
- 654
Re: Rockport Lyra
Red Lyra at HK show 2017.My blogs Wizard High-End Audio Blog & Wizard Ultimate
August 11, 2017, 08:13 AM #39
Re: Rockport Lyra
Odyssey did an audition of the Rockport Lyra at a U.S. dealer. Perhaps he will comment on his impressions of the speakers.
August 11, 2017, 02:14 PM #40
Re: Rockport Lyra
I heard them today at the HK hifi show. They still sound like Rockports - slightly dark and smooth
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
August 11, 2017, 09:11 PM #41
- Nov 2013
- 318
Re: Rockport Lyra
Yes XV Fair comment --I've owned Rockports(Syzygy's) and concur on the sound evaluation--I drove them with Jadis Monos that alleviated 99% of that trait quite comfortably.
I did enjoy the speaker, however the Eton Drivers suffered from foam Rot as they aged-and with no original components still available I sold them.
They were a fine product though.
Further to your HKG experience can't say I'm surprised--seeing the choice of VTL's driving --those amps always give me the impression they are struggling to keep up with the music
I'd pass on those!
Bruce
August 11, 2017, 10:11 PM #42
- Jul 2015
- 115
Re: Rockport Lyra
I wonder what does dark sounding mean? I see reviewers sometimes use that description.
August 11, 2017, 11:34 PM #43
Re: Rockport Lyra
August 12, 2017, 07:09 AM #44
Re: Rockport Lyra
Le Roy
Foundation:
August 13, 2017, 03:27 AM #45
- Sep 2016
- 901
Re: Rockport Lyra
I find Stereophile's Audio Glossary an invaluable resource for brushing up on audiophile terminology.
August 13, 2017, 03:37 AM #46
- Sep 2016
- 901
August 13, 2017, 10:58 AM #47
Re: Rockport Lyra
Or the Celestion SL600 from 1983:
sl600.jpgMicro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
November 10, 2017, 05:52 PM #48mauidanGuest
Re: Rockport Lyra
Upgrade on the way...
