Results 51 to 63 of 63
Thread: Vitus SIA-025 dream gear
October 20, 2016, 02:50 AM #51
- Sep 2016
- 901
October 20, 2016, 07:12 AM #52
October 20, 2016, 07:56 AM #53
- Sep 2016
- 901
October 20, 2016, 08:06 AM #54
Re: Vitus SIA-025 dream gear
Speakers - Magico S5mk2 Integrated - Vitus SIA-025 Analog - Vpi Prime Signature/Ortofon Cadenza Bronze Digital - Lumin A1
Power - Shunyata Denali 6000S/Alpha HC/Alpha Digital Cables - Kimber KS-6063/Nordost Frey IC
April 3, 2017, 05:27 AM #55
- Sep 2016
- Germany
- 54
So Stillpoints are a must, right? But the contact face of three (or four) Ultra SS is very small when I look at the pictures. This is no problem with a 42kg heavy SIA 025?
April 3, 2017, 05:41 AM #56
- Sep 2015
- 60
April 3, 2017, 05:58 AM #57
- Sep 2016
- Germany
- 54
Right now I am using Shun Mook Ultra Diamond Resonators. They have a huge diameter. I also have an Ensemble Honeyplate with three little cones. Did not try it by now. The contact area is also very small.
April 3, 2017, 08:24 AM #58
- Sep 2016
- 901
May 11, 2017, 04:37 AM #59
- Sep 2016
- Germany
- 54
Has anyone tried an PS Audio PerfectWave Powerplant P10 oder similar with the SIA-025?
May 11, 2017, 04:59 AM #60
- Nov 2013
- 96
I tried the SIA-025 with the PS Audio PerfectWave Powerplant P10 .I now run the SIA-025 direct to the power point on its own power line.No real difference sound wise and didn't want to risk starving it of power..
Stump
May 11, 2017, 05:00 AM #61
- Sep 2016
- 901
The PS Audio PerfectWave Powerplant P10 is a regen which is supposed to re-build the original signal, remove contamination and produce a perfect sine wave according to PS Audio. I haven't tried a regen in my system, but I have had great success with the Gigawatt PC-3 SE Evo conditioner.
The Gigawatt has a double buffering circuit with compensation cells with enhanced capacity and levels the difference between input and output power, dramatically improving impulse response for non-linear loads (eg: power amplifiers). It provides over-voltage protection and extremely robust surge protection provided by a hydraulic-magnetic switch made by Carling Technologies & has an accurate voltmeter which displays input voltage in 'true RMS' via an LED display on the front panel. It also has a dedicated high current branch for amplifiers & is one of the few conditioners where a power amp sounds better connected to the conditioner than direct to wall. An added bonus is that the product's footprint allows it to be placed on a normal height rack shelf which I find useful.
Here is a review fyi which has detailed pics of the internals and parts. Note: Gigawatt have slightly improved the design since this review.
September 25, 2017, 02:19 AM #62
- Jan 2017
- 19
Hi there, looking at getting a used Vitus SIA 025. Any idea what is the difference between the MKI and MKII? Is it upgradable by the local dealer or Vitus themselves?
September 25, 2017, 05:29 PM #63
- Sep 2015
- 60
Congratulations on the Borresen X1 acquisition. Did you buy the X1 to replace something else? If so, what? Audio Group Denmark design and build all speaker drivers (cones and ribbon)...
Borresen Acoustics Loudspeakers
