Results 1 to 17 of 17
  1. #1
    Senior Member
    Join Date
    Apr 2013
    Scenic Idaho
    Posts
    283
    ModWright LS 36.5
    After spending the past couple of years with the ModWright LS100 in my system, I have decided to give the LS 36.5 a demo. Immediate impressions are very positive - a dead quiet noise floor and I like that I don't have to have it turned on to use the HT Bypass. It also has a lower output impedance which I believe matches better with my MC501s. I will miss the terrific phono stage and to a lesser extent the headphone amp in the LS100, but overall the LS 36.5 is a better sounding unit and better fit for my system. Pictures and more listening impressions to come...
    McIntosh MC501s, XRT29s, XR27, WS350s
    ModWright LS 300 preamplifier
    ModWright PH 9.0XT phono stage
    Oppo UDP-205 with ModWright Signature Truth Tube Modifications
    Cambridge Audio CXNv2 with ModWright Truth Tube Modifications
    Clearaudio Performance SE TT with Hana ML MC cartridge
    Outlaw 7000x HT Amplifier
    Denon AVR-X4700H HT Receiver (pre-amp mode)
    JL Audio F113 subs with CR-1 Crossover
    ASC & RealTraps Panels; APS PurePower 2000; Daedalus Audio DiDs
    WyWires, LAT International, Wireworld Cables
  2. #2
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Re: ModWright LS 36.5
    Nice looking unit!
    Glad you're happy. I am eyeing his phonostage.
  3. #3
    Senior Member
    Join Date
    Apr 2013
    Scenic Idaho
    Posts
    283
    Nice looking unit!
    Thanks Mike! The two preamps are surprisingly very different sounding. Given that my system already leans to the warmer side, I like the fact that the LS 36.5 is more neutral and detailed. I'd love to hear the Dual Mono LS 36.5 in my system sometime, but would have to do a complete rack reconfiguration to accomplish that. I still might at some point.
    The PH150 just received a very positive review in the latest issue of TAS. I'd like to see you give it an evaluation and find out your feedback!
  4. #4
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by JJinID View Post
    My reservation is that a friend of mine has it and loves it, but he says the XLR sounds way better than the RCA. I'm all RCA.
  5. #5
    Senior Member
    Join Date
    Apr 2013
    Scenic Idaho
    Posts
    283
    Very interesting to hear that Mike. I would have reservations also if that were the case. It might be worth reaching out to Dan and asking him directly about that.
  6. #6
    I also went from the LS100 to a 36.5. Both are superb preamps but the LS36.5 is is clearly superior. I have also had the DM at home for review when it launched in the UK along with the KWA150SE power amp. My thoughts HERE
    Preamp: Aesthetix Calypso Signature
    Power Amp: Aesthetix Atlas Signature
    DAC/CDP: Aesthetix Romulus Signature
    Phono: Aesthetix Rhea Signature
    TT: Kuzma Stabi Ref 2, Kuzma 4Point 11, Hana ML
    TW Acustic Raven One, Raven 10.5, Shelter 5000
    Speakers: Acapella High Violin MkIII
  7. #7
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    I've been with the LS36.5DM for quite a while now jumping to it from ARC LS2B and LS16. It made quite a big leap forward in all sonic terms comparing to those two mentioned preamps. Also I've been playing a bit with rectifier tubes and the best results I got when inserting NOS Mullard GZ34 instead of stock Sovtek.
  8. #8
    Senior Member
    Join Date
    Apr 2017
    Central FL
    Posts
    793
    I've been using an LS36.5DM for many years as well.
  9. #9
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    yes I had the 36.5 for about a year and a half . beautifully built . in the last 6 months been using the 2 box dm . it sounds just as good rca or xlr to my ears . I like the support and back up that modwright give . it has a lovely midrange .
  10. #10
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    Quote Originally Posted by hifinutt View Post
    I sign on the statement above. Mike is really a great guy who takes honest and sincere care about his customers!
    LS: Vienna Acoustics Klimt "The Music"
    PowerAmp: Nagra VPA
    PreAmp: Tobian Soundsystems SC12
    DAC: LampizatOr Horizon
    Server: LDMS Maximus Music Server
    CDT: CH Precison D1
    Switch: Edison Creation Silent OCXO Extreme, FiberBox
    Power: LampizatOr Kraftwerk 10
    Cabling: Signal Projects loom
  11. #11
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    would that be dan ?
    I must try that tube swap with some mullards one day
    1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
  12. #12
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    would that be dan ?
    Sorry, yes Dan!!
    After I swapped the tubes out of the blue my wife asked: "Did you again change something?"...so I would say change was well noted
    PowerAmp: Nagra VPA
    CDT: CH Precison D1
  13. #13
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by Golum View Post
    Sorry, yes Dan!!
    Maybe Paul was right.
  14. #14
    Senior Member
    Join Date
    Apr 2017
    Central FL
    Posts
    793
    I had Mullards (believe it said Amperex - still have them) made in Holland. Using Create Audio Synergy HiFi 5AR4s for quite a bit and like them.
  15. #15
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    my dm 36.5 been out of action for a few weeks and been trying various products . last couple of days its been back . its singing beautifully , the texture and delicacy of this pre is delightful. playing max richter the blue notebooks sounds so natural
    https://youtu.be/Nfy2fs01ZkI
    so pleased to have it back . the grandinote proemio may have deeper bass that this dm but the dm is so balanced and controlled and organic its more than a match for the proemio
  16. #16
    I've owned an LS 36.5 DM for some time now. There is no other preamplifier I would rather own (However, I do wish it had 2 more balanced inputs). Anyone that says a preamplifier is not significant to a systems sound quality has never heard one of Dan's preamps!
    It really responds well to tube rolling in the 6DJ8/6922 slots. I've settle on a strong pair of bugle boys that really augment my current system perfectly. I have a nice pair of Mullard DD GZ34 rectifiers that work perfectly in the power supply but I'm trying to save them as they are getting very pricy. I'm probably being over cautious because I have never worn out a Mullard GZ34! Instead I use a pair of RCA 5AS4A tubes which I have found to be exceptionally good rectifiers. Don't tell anyone though as it will just make their price go up...
  17. #17
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    mmm I must remember that , I am afraid to fiddle in case I mess up the warrenty , and its sounding fabulous anyway
ModWright LS 36.5
Posting Permissions
  • You may not post replies
  • You may not edit your posts
