Results 1 to 50 of 2097
February 29, 2016, 09:15 PM #1
Nord One Up Ncore NC500 amps, Class D ready for prime time .....
A few weeks ago I bought a pair of Nord One Up NC500 amps with the Sparkos Class A op amp. Needless to say I am impressed. This is not the Class D that I remember.
These are powerful, have 3D, a big sound stage and are sweet with the vocals. Break in seems to take forever on all Class D. But after a few weeks of continuous play, wow, I am impressed.
http://www.iqspeakers.co.uk/#!hypex-amps/avuyk
February 29, 2016, 09:18 PM #2
Re: Nord One Up Ncore NC500 amps, Class D ready for prime time .....
Joe - can you tell me how the Class A works with this amp?
February 29, 2016, 09:30 PM #3
- May 2013
- 3,242
Joe
Anymore changes since we talked about them the first of last week? Has another 150 hours seen any changes. The Nuprime Class D amp came in this morning. I am going to let it cook for a couple of weeks in the family room before trying it with the KO's. Still o.k. here for the tubes for a while.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
February 29, 2016, 09:31 PM #4
According to the website:
An onboard 8 pin DIP socket allows different Op Amps to be easily swapped in the future to tailor sound and upgrade their Amplifier as required. The Upgrade delivers the ultimate sound with the ability to tune and further upgrade with a sound Menu of OP Amps via the onboard socket enabling easy changes of Op Amps, its called OP Amp Rolling.
February 29, 2016, 09:32 PM #5
February 29, 2016, 09:40 PM #6
- May 2013
- 3,242
There are supposed to be in the process of testing two more brands of Op Amps to see if they will make them available. I imagine you can buy any of them from PE, Mouser and other places. I am curious to see how it breaks in. Stephen Stone with TAS sure liked it as well as several owners I talked to.
February 29, 2016, 09:41 PM #7
February 29, 2016, 09:50 PM #8
- May 2013
- 3,242
Op Amps for the Nord. If you want to try the Bursons, Chris at Parts Connexion carries them. The new ones they are testing are from Sonic Imagery and Audio GD.
February 29, 2016, 09:51 PM #9
March 1, 2016, 07:02 AM #10
I thought I'd move this here ...
Yes, the truth always gets out. These amps are wonderful. I put them back in tonight from almost a week of being away. Other than running as cool as a cucumber (I need some heat - my room is cold), they are great, absolutely love them.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
March 1, 2016, 02:12 PM #11
Very cool stuff Joe, I'd love to hear them!
Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
March 1, 2016, 02:20 PM #12
March 1, 2016, 03:12 PM #13
What are the high level specs and pricing Joe? Thx
Cyril
March 1, 2016, 03:43 PM #14
Cyril,
Mine were just under $2300 delivered.
• Silver Finish Mono Block Case
• Single Hypex NCore NC500 Module
• Single Hypex SMPS1200A700 Power Supply
• Nord Input Buffer Board with Choice of Burson V5 or Sparkos Labs SS3602 Op Amps
• Distortion: THD+N - - 0.001 % 20Hz
• Frequency Response: 0 - 50k Hz +0/-3dB
• Low Distortion: THD+N - - 0.001 % 20Hz
• Low Input Impedance 47K
• 26 dB Gain
• Ultra High Damping Factor
• High Current Output Capable of driving 2ohm for the
Most Demanding of Speakers.
550W 2ohm
700W 4ohm
400W 8ohm
• 2.5Kg Case W 240mm D 280mm H 80mm
With Feet and Binding Posts W240mm D340mm H95mmFleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
March 1, 2016, 06:10 PM #15
Very nice looking stuff there Joe and reasonably priced. I'm not surprised you like them, Bruno Putzey is the best Class D designer in the business, the output filtering scheme is brilliant and more importantly, load invariant. Definitely not your grandpas Class D.
Oodles of power. Should work with a wide variety of speakers. Including mine.
Throw in a nice tube pre and you're enjoying some fine sounds...
cheers,
AJ
March 1, 2016, 06:26 PM #16
March 1, 2016, 06:48 PM #17
Thx for info Joe. Very reasonable price. What speakers are you driving with these bad boys? Let us know how they sound with the GAT pre. Thx.
Cyril
March 1, 2016, 07:06 PM #18
March 1, 2016, 07:19 PM #19
March 1, 2016, 07:20 PM #20
Cyril,
For the first 2 weeks I ran them non-stop with my LS-50 speakers and it sounded great. Now my Strads are hooked up and it sounds even better.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
March 1, 2016, 07:42 PM #21
Cyril
March 1, 2016, 07:46 PM #22
Thanks! They seem tonally more dense and fuller than other Class D amps. More meat on the bone as they say.
March 1, 2016, 09:35 PM #23
- Oct 2013
- Sacramento
- 1,128
I checked today and the conversion rate is 1 British Pound (GBP) = 1.3959 USD
Here is a converter to check the latest or other currencies.
http://finance.yahoo.com/currency-co...D;to=EUR;amt=1
March 1, 2016, 09:45 PM #24
- May 2013
- 3,242
If any of you guys want to try out an NC500 based amp and don't want to order from a "new guy on the block", Merrill has one for $2500 using his own designed buffer board. There are a couple of reviews online. Only draw back for some may be that it is stereo only. I think the Nord looks better and has higher quality connectors but that's just me.
March 1, 2016, 10:23 PM #25
I think I had to pay UPS a small duty fee of $30 or so and I forget if PayPal took a little extra too. I think I was all in for $2250 maybe. Well worth it.
March 5, 2016, 02:53 PM #26
Somehow found out about Nord not that long ago and it got my interest. Not a ton of info on the web so it's nice to hear from someone who has one and likes it.
Currently running a Gato which uses Pascal class D tech. Would love to compare it to Ncore someday.
March 5, 2016, 03:04 PM #27
Hi,
I have to say my Nord amps now are outstanding. Love them. Extended break in on any Class D is a must, and these are no different that way, but these are performing better than I had hoped. They seriously kill some amps at 10X (maybe not quite ten times) the price. The Sparkos op amp is supposed to warm up the sound and add some tone and body. I don't know how it would sound with the stock or other op amps but I am enjoying what I have now and absolutely zero regrets. Just wonderful.
Another forum member has been talking to me about the Gato and loves the sound but is not 100% happy although the company has been awesome to deal with and is very responsive.Last edited by joeinid; March 5, 2016 at 03:11 PM.
March 5, 2016, 04:03 PM #28
Joe,
Which opamps are you using ?Adam
Speakers: Magico M3
March 5, 2016, 04:15 PM #29
The Sparkos.
http://sparkoslabs.com/discrete-op-amps/
Specifications
- Full Data Sheet Available Here
- 140 dB Open Loop Gain
- 415nV RMS (2.9nV√HZ) Noise to 20KHZ
- +/- 18 Vcc Max
- 15mA Class A Ouput Current
- 65mA Max Output Current
- 14mA Supply Current
- < 300µV Typical Offset
Features
- Optimized For High Performance Audio
- Available In Single Or Dual
- DIP8 Compatible Package
- Circular Machined Gold Plated Pins
- Smallest Discrete Op Amp On The Market
- 100% Class A Biasing
- Two Pole Compensation
- NPO Capacitors
- 1% Metal Film Resistors
March 5, 2016, 04:31 PM #30
The ability to pick the op-amp is a nice option.
Looks like Atsah 500 and the Bel Canto e.One REf600M monos are also using the NC500 / SMPS1200 combination. Wonder if other companies will try it too, as it seems like the performance is close to amps using the much more expensive NC1200.
How is the finish on the Nord? The Atsah and the Bel Canto seem pretty utilitarian design-aesthetic-wise.
March 5, 2016, 04:48 PM #31
Fit and finish is great. The amps are very light but all Class D are light. Heavy cables could tip the unit a little but the whole package is rock solid. Colin from Nord/IQ speakers does a great job on the amps.
March 5, 2016, 07:05 PM #32
I'm reading about Nord, you got me interested
March 5, 2016, 07:13 PM #33
March 5, 2016, 09:21 PM #34
- May 2013
- 3,242
Mate
If you are walking away from the Gato situation you might want to look at Abrahamsen. Integrated and then get the DAC of your choice that you can change with technology changes.
http://www.iqspeakers.co.uk/#!abraha...mplifier/c1vfy
You would buy direct from Abrahamsen in your country.
Another option is the Nuprime IDA-16. It is a 200wpc all in one integrated/DAC like the Job and Devialet. Has voltage switch on the back so you can buy from any dealer that has the best currency exchange rate for you.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
March 5, 2016, 09:30 PM #35
Thanks Jack, I'm still between several scenarios... Abrahamsen did cross my mind a few times, but I'm trying something even better - to convince my friend to order Abrahamsen for himself as his first ever amplifier; that way I'll be able to audition it. I'm familiar with Electrocompaniet, which is somewhat popular here and basically the same thing as Abrahamsen. I like it, but didn't exactly blow me away.
March 6, 2016, 07:56 PM #36
Would someone be willing to summarize how the NC500 differs from the NC400 modules? I built an NC400 stereo amp several years ago and had it for about a year. It was very accomplished in some areas (midrange and resolution) and lacking to my ear in others (high frequencies and bass) in my system and in my opinion of course.
Sent from my iPhone using TapatalkLiving Room System: Mac Mini > PS Audio PWD MKII/ Marantz TT-15 Turntable w/ Ortofon Cadenza Bronze> Musical Fidelity LX2LPS> Primaluna Dialogue Premium> Klipsch Forte III
March 6, 2016, 08:08 PM #37
While the 500 has a bit more power and current capability compared to the 400, I believe that the most significant difference is that the 500 is better setup to accommodate custom input stage designs which can be substantially better sounding than the stock input stage. Many designers are using discrete class A circuits for the input stage with 500 modules. Also many of the 500 designs (like the Nord) make use of the much higher current 1200 series power supply instead of the standard 500 series version which allows for much better dynamic performance and more headroom. The Nord design is also setup to allow you to easily select or change the input stage op-amps of which there are at least a few discrete drop in options.
March 6, 2016, 08:15 PM #38
Awesome! Thanks
March 6, 2016, 08:16 PM #39
I just built the NC400 mono amp kits from Hypex. Deceptively good and very neutral.
Marty
MSB Premier
PS Audio Powerplant 15
March 6, 2016, 08:31 PM #40
- Oct 2013
- Sacramento
- 1,128
How many op-amps/monoblock chassis? What is the price range on op-amps?
The solid state version of tube swapping.
March 6, 2016, 08:46 PM #41
http://www.iqspeakers.co.uk/#!produc...a-4db51ca43bd9
I think the amps take one op amp each and that price is for a pair as an example.
March 7, 2016, 02:28 AM #42
Joe, I don't know how i missed this thread. Man those amp looks great ! What do you pair with ? your Kef Bookshelf ?
Nice.Paul
March 7, 2016, 02:56 AM #43
Hi Paul
I started breaking them in with my LS50. Now I am using them on my Strads and I have to say that they are wonderful. Surprised the heck out of me.
Sent from my SM-N910P using TapatalkFleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
March 7, 2016, 03:03 AM #44
Thanks Joe. Meantime I read the whole thread. You already mentioned earlier. Sorry about that.
Nice stuff.
March 7, 2016, 03:06 AM #45
No problemo.
March 24, 2016, 03:34 AM #46
- Mar 2016
- 414
Hi Joe have you heard about the recent revision plans for the Nord input buffer boards? Expect a very large improvement in sound available out of your amps very soon.
March 24, 2016, 03:35 AM #47
- Mar 2016
- 414
It will be very easy to install as well.
March 24, 2016, 03:36 AM #48
- Mar 2016
- 414
All of the details are on here if you read the last couple pages on this thread posted in the next post. I'm bavmike BTW.
March 24, 2016, 03:36 AM #49
- Mar 2016
- 414
March 24, 2016, 03:44 AM #50
Thanks Mike, I'll check it out.
I am shocked at just how awesome the amps are now.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
Yes, and it does. Room costs (we had 3 rooms, including a large ballroom), materials, marketing, brochures, banners, all the staff, shipping, meals, hotel rooms, flights, etc. Figure on $40k. ...
Clarisys - Axpona 2024
