Results 1 to 6 of 6
February 28, 2016, 01:31 PM #1
Anyone listen to the new Auditorium 23 EMT step up?
How does it compare to the T2 or the less expensive SUT.
February 28, 2016, 01:47 PM #2
Re: Anyone listen to the new Auditorium 23 EMT step up?
It is supposed to be better for the EMT than the regular A23 SUT for the denon. But not as good as the T2 Hommage.
Sent from my iPad using TapatalkChris
Garrard 301, SME 2012r, EMT TSD15, A23 T2 Hommage SUT, Shindo Montille, Shindo Aurieges, Shindo ICs and Auditorium Speaker Cables, Auditorium A23 Hommage 755a Speakers.
February 28, 2016, 03:07 PM #3
I have heard the T2 at shows over the last few years when Devore was using it. Always sounded good.
My concern is the amount of total gain. My MM stage has 48dB, so how much more does the A23 EMT provide, for their 1.0mv carts. I am worried of too much gain.
February 29, 2016, 10:08 AM #4
February 29, 2016, 11:01 AM #5
I had the denon first, with a denon 103. Then I used it with my tsd EMT 15. Then. I stepped up to the A23 T2 - no regrets. Nude version.
October 24, 2016, 02:43 PM #6
- Mar 2016
- 161
Great listening experience, Greg.
Has a K-01XD SE actually been announced by Esoteric?
