Results 1 to 14 of 14
Thread: New Preamp
November 25, 2015, 11:07 PM #1
New Preamp
I'm happy to be finishing up my next project, a zero-gain preamp using Tortuga's LDR and Broski's Aikido tube buffer.
RDavidson helped with design and is getting one of them, his is made with spalted maple and natural aluminum metal parts, mine is maple burl with brushed copper front and top panels.
I needed a buffer preamp and this one turned out great, I'm super happy with the way it sounds.
Industry Affiliation:
I own ZenWave Audio LLC
zenwaveaudio.com
"Integrity and Excellence in Audio"
November 25, 2015, 11:07 PM #2
November 25, 2015, 11:45 PM #3
Re: New Preamp
Me like. Very nice looking gear.
Paul
November 26, 2015, 12:31 AM #4
Re: New Preamp
I can't seen anything.
November 26, 2015, 12:33 AM #5
November 26, 2015, 12:45 AM #6
Re: New Preamp
No balanced outs?
I love the appearance. I am so tired of black and silver. Did you design it, or build it from a schematic?Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
November 26, 2015, 05:39 AM #7
Re: New Preamp
Nice job!
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
2 Channel: Wyred 4 Sound STP-SE, Wyred 4 Sound DAC-2, Manley Mahi Monoblocks, DIY SEOS Waveguide/Dipole Bass Towers
HT: Marantz AV7005, Wyred 4 MMC5, DIY SEOS Towers, DIY 7CF Sealed 18" Subs
PC: Wyred 4 Sound mINT, KEF Q100, Hifiman HE-6
November 26, 2015, 09:11 AM #8
- Jun 2013
- St Louis, MO
- 145
Re: New Preamp
It looks amazing. Like Bud said above, it's nice to see something other than black and silver.
November 26, 2015, 09:22 AM #9
Re: New Preamp
Very nice Dave! Can you talk about the USB port on the back? Is there a DAC in your new preamp too?
November 26, 2015, 09:36 AM #10
Re: New Preamp
WOW a real beauty!
Brian
November 26, 2015, 11:35 AM #11
Re: New Preamp
Thanks guys!
No balanced outs, it's a SET preamp. If using a balanced source I'd use something like a Jenson isomax balanced to single ended converter, but I didn't want to build it into the preamp or simply short pin 3 to ground.
There's no DAC, the USB input is to update the Tortuga LDR firmware.
The electrical design is simply a Tortuga LDR to Broski's Aikido tube buffer. It also uses Broski's 12V linear regulated PS to power the LDR, and there are separate PS for the heaters, which can be set at either 12V or 6V so it can run 6SN7, 12SN7 or 12SX7, which Broski recommended so I have a pair to try out. The three power trafos are on the top sheet, the wood boxes are covers for a 12V and a 234V toroid. The center one is the 12V trafo for the tube heaters.
The chassis is a variation on previous components I've built using figured maple and walnut corners, but it has been significantly improved by Ryan Davidson, who is responsible for industrial design and CAD. I did all the CAM, woodwork, final assembly, finishing, and wiring.
The little wood box right in front of the filament trafo houses the remote sensor, having a remote control is awesome...Industry Affiliation:
zenwaveaudio.com
December 17, 2015, 05:38 PM #12
Re: New Preamp
dave, I missed this, lovely bit of gear & great workmanship, really like the look of the copper aesthetics
December 18, 2015, 01:01 AM #13
Re: New Preamp
zenwaveaudio.com
January 26, 2017, 03:30 AM #14
- Jan 2017
- 16
Re: New Preamp
good work
Upgrade on the way...
