Results 151 to 164 of 164
Thread: Audio Research REF 6 Preamp
January 19, 2017, 11:03 AM #151
Re: Audio Research REF 6 Preamp
Avanti Audio
January 20, 2017, 03:26 PM #152
- Oct 2015
- New York City Metro Area
- 443
Hi Ken,
Glad your experience with the Ref 10 is similar to mine. I do believe with use these components benefit from burn in and settle down to their in age character but the difference is subtle. Sounded great from day one and only better now. The Ref 6 now has a place in my reference system.
Best always...
February 2, 2017, 09:43 AM #153
- Oct 2013
- 60
Hello ,
I’m a proud owner of Audio Research Reference 6 Preamplifier. I want to combine this unit with SS Amplifier the Vitus Audio SM-011. The only question I have will it electric drive the SS- monoblocs via the XLR connection?
The Sterophile test of my Reference 6 says in the measurement: The balanced output clipped at 2.7V into 600 ohms; like the Ref 5, the Ref 6 should not be used with power amplifiers having an input impedance of less than 10k ohms.
Read more at http://www.stereophile.com/content/a...XSulREJtzz2.99
The XLR impedance of the SS Amplifier the Vitus Audio SM-011 is 10KΩ 10KΩ
Read more at: http://www.vitusaudio.com/files/4405...28-10-2016.pdf
And here the predecessor SM-010 was even tested with the Reference 5 Preamplifier with good results.
http://www.tonepublications.com/review/heavy-metal/
Speakers/Amp/Preamp: DIY closed 3-way/ AMP:???? / ARC Ref 6
Sources: DAC Aqua La MKII , Marantz SACD SA11S1
Cables/Power/Other: Transparent Audio Reference XL , DIY XLR Western Electric WE16GA
February 2, 2017, 09:45 AM #154
The REF5SE with my Vitus SS-103 worked beautifully.
February 2, 2017, 09:52 AM #155
- Oct 2013
- 60
Thanks Mike for the quick response. I think I will go “blind” for the SM-011 after you and many more people who have advised me this brand in Class-A amplifiers. I hope this will be major step up from my XA-160.5
February 2, 2017, 09:53 AM #156
February 2, 2017, 04:56 PM #157
This is a joke right? Unless you hold IPC solder certifications and have a really good soldering station which includes a desoldering tool, you stand a good chance of causing damage to the circuit board. You will most certainly void your warranty and your value on the used market if you disclose your shenanigans (which would also prove beyond a shadow of a doubt that you are a crazy audiophile) would drop faster than a used prophylactic.
February 2, 2017, 05:20 PM #158
- Oct 2013
- 60
Hi Mep.
I was jest asking myself and also here if anyone has tried this. The outcome by cocking Duelund capacitors after one year of use was beyond my belief! I'm just thinking about speed up this process in Reference 6 and even my thinking is that good capacitors can never been broken in without this peace of treatment! Really! Voodoo equipment!
I will after this reactions not do this to Ref 6.
March 30, 2017, 09:04 AM #159
After chasing and thinking of swapping my long time companion in form of ModWright LS36.5DM with REF5SE and unsuccessful chase for it across Europe I've stumbled on almost new REF6 which I could not resist to, so as of today I finally have an ARC preamp from REF series. Previously I had LS2B and LS16mkII so this should be, from my point of view, a big come back to the ARC family. Unfortunately I'll have to wait for a few weeks to plug it in due to planned trips, but the longer you wait for something to happen the sweater it gets when you get it .
LS: Vienna Acoustics Klimt "The Music"
PowerAmp: Nagra VPA
PreAmp: Tobian Soundsystems SC12
DAC: LampizatOr Horizon
Server: LDMS Maximus Music Server
CDT: CH Precison D1
Switch: Edison Creation Silent OCXO Extreme, FiberBox
Power: LampizatOr Kraftwerk 10
Cabling: Signal Projects loom
March 30, 2017, 10:34 AM #160My Systems: http://www.audioshark.org/showthread...481#post158481
May 6, 2017, 03:10 PM #161
interesting , I absolutely adored my ref 5 and ref 5se [ couriers lost my ref 5!] it had a beautiful textured sound . sadly had to sell for financial reasons but gradually working my way up again . had the 36.5 modwright for a while and then most recently got the 36.5dm . its good and beautifully made but aiming for the ref 6 . now they are VERY rare s/h in uk so waiting for the se to come out . anyone know when that is ?
however a well meaning dealer lent me a grandinote proemio [Italian ] pre and my word that is easily up to the dm level so might persue that as well as the ref 6 as the proemio is SS and no valves to worry about
an engineer I know is currently working on an arc anniversary pre which I saw last week , fabulous engineering !
May 7, 2017, 08:49 AM #162
- Sep 2014
- 766
Phil, see if you can find the Ref 40 used. It has a separate power supply and if the ref 10 was anything to go by, it will be the dog's bollocks. Just one thing, if you are driving a SS amp (in case you still have your MSB) you might want to check impedance match and the VTL will be better to drive a SS amp.
May 7, 2017, 09:05 AM #163
thanks kedar . yes ref 10 are still extortionate prices and having seen the complexity of the anniversary I am a bit nervous if it needs repair . yes still using the amazing msb s200 , it really does sound good . I bet the high end grandinote would give arc pre amps a real run for their money . have you ever heard any ?
good to know re the vtl powering the ss amp
May 7, 2017, 09:21 AM #164
- Sep 2014
- 766
The ref 40 is similar to 10 and discontinued so available cheaper. 10 is more user friendly and a couple of caps. There is an article on audiobeat describing sonic differences but I understand they are minimal. VTL 7.5 mkII and III have low impedance and put out a lot of current to drive SS amps. I personally haven't compared VTL to ref 10 but you will see that in Roy Gregory's review.
