Page 2 of 2 FirstFirst 12
Results 51 to 75 of 75
  1. #51
    Re: Aurender N100H Review
    180 does seem like a low number based on my experience so far.
    Anthony
    Analog: VPI Clearaudio Innovation Wood/Kuzma 4Point/Ortofon A95> ASR Basis Exclusive HV---->
    Digital: Antipodes CX (Oladra Upgrade)> Cary DMS-600 DAC/Streamer---->
    ...........Cary 306 SACD Professional Disc Player---->
    ===> Cary SLP-05 (Ultimate Upgrade edition)----> Clayton M-300----> MARTIN LOGAN SPIRES/REL 212SX x2
    [Synergistic Research/Nordost/Wireworld/Furutech/SRA/Adona/Stillpoints/Track Audio/GIK Acoustics]
  2. #52
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    you are more than correct, maybe I should keep quiet until I learn how to use it.
    Jeff
    Main System-Mola Mola Tambaqui-Antipodes K50-WW Plat 8 ic-Esoteric Grandioso S1 Esoteric C-02x Verity Amadis S-Shunyata Triton V3-Shunyata Typhon QRT
    Shunyata AlphaNR V2 for Tambaqui-Elrod Statement Gold for S1, Elrod gold SCs Shunyata Sigma for Triton. Tubulus Concentus I2S.
    Second System: URC streamer-Wadia 151 Power Dac, MIT Speaker Cables, Wilson Audio Watts and REL sub.
    Third System: Denon AVR, URC Controller and network streamer, Netstreams Musica multi room-True Audio ceiling speakers
  3. #53
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Quote Originally Posted by JGlacken View Post
    Nah...how else will you learn? That's what forums are for bud
    CD
    DAC/Pre-amp - PSAudio DsJ > Power-amp - > Speakers - PMC TwentyFive 23s
  4. #54
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    Thanks Chris, definitely heard a difference with files moved to Aurender local drive. Clearer, more forward and a bit more channel separation. Now to go back and clean up my iTunes library on my mac mini. Going to try the scripts that Chris C recommended on CA only in later versions. Will let you know.
    Jeff
  5. #55
    Thanks Chris. It would appear you are correct as I have searched for more info and found Chris from Computer Audiophile with an article that describes going from iTunes on mac to Aurender S10 or any Linux machine. Yikes!
    Here is the link: http://www.computeraudiophile.com/co...-music-server/
    oops, sorry, don't know how to add link here.
    Not sure why some people are trying to complicate this. I've always used iTunes to rip (AIFF format). It integrates perfectly with the Aurender. All you need to do is drop in the cover art file then upload the folder to the Aurender.
    Are people having other issues with this (am I missing something)?
  6. #56
    Quote Originally Posted by bobwah View Post
    A lot would depend on if you need/want a cd ripper or not.
    I yet to rip 80% of my cd collection thats the only reason I didn't pull the trigger on a n100h.
    Ive got a Antipodes arriving tomorrow so ill find out what software it uses then.
    Most people don't realise that you can in fact plug in a USB CD-rom drive into an Aurender and rip directly. The cost is under $50 these days for a suitable drive. This is nice because you can then remove once done and you don't have a redundant drive sitting there afterwards.
  7. #57
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Quote Originally Posted by Arcade View Post
    I sure didn't! How does it handle tagging?
    CD
  8. #58
    Never tried it, I imagine it may connect to a database if connected to the internet, otherwise you'd have to do it manually. I think you'd be far better off ripping on your computer. I just mention it because I think the lack of a CD drive on the Aurender is a pro, not a con like some people suggest. Many work-arounds so that it's a non-issue.
    The other benefit of ripping on your PC is that you have a backup of your music by default.
  9. #59
    I don't know why that would make a difference. I thought the N100H buffers everything to the internal SSD regardless of where the files are stored.
    Speakers: Vandersteen Model 7 XTRM, 4 M&K ST-150Ts, 1 VCC-5; Amplification: 2 Vandersteen M7-HPAs, CI Audio D200 MKII, Ayre V-6xe; Preamp: Doshi Audio Line Stage v3.0; Phono Pre: Doshi Audio Phono Pre; Analog: Wave Kinetics NVS with Durand Tosca arm; SME 3012R arm, Ortofon Diamond Anna; Reel to Reel: Technics RS-1500; Doshi Tape Pre-Amp; Studer A810, Studer A812, Tascam BR-20; Multi-channel: Bryston SP-3; Digital: Taiko Audio Extreme> Lampizator Horizon, Oppo UDP-203;
  10. #60
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    A little update and a question:
    I have moved all music from NAS to Aurender local drive, I have cleaned up and added album covers and for the most part I am thrilled with the improvement in SQ. Still breaking in, but more room arrow d the instruments, female vocal are in the room and dead quiet background.
    Question, I have about 55 albums that do not show an artist under the album title in the album view. They seem to be set up the same way ones that have artist are set up. Aurender help has suggested I use XLD to tag these. I have used XLD to convert from air to flac, but don't know what they mean by tagging??? Would someone please tell me how to set XLD preferences so that I don't screw up the file already there. Not sure where the artist would go to get it to display on my iPad. Thanks.
    Jeff
  11. #61
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Jeff...I don't use XLD; so I can't speak to it...but I can't imagine tagging programs, are that different.
    If you have XLD installed...I would suggest, you should be able to right-click on the file (or better yet...select all files, of a particular album for example)
    For me...I select Edit ID Tag (but your option, with XLD installed...should be there instead)
    And then your tagging options, should look...more or less...like this; where you'd enter meta-data information.
    If you're still stuck, let me know; I can walk you through it real quick.
    CD
  12. #62
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    Huge help Chris, I think I've got it!
    Jeff
  13. #63
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Cool Jeff
    Let us know.
    CD
  14. #64
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    Well, it works sometimes and sometimes it only tags the first track on the album and names only that track. On XLD it has a spot for track ____ to track____ and I put in the numbers. Could not seem to insert the image here.
    Jeff
  15. #65
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    Has anyone tried this?
    http://www.tuneupmedia.com
  16. #66
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    No Mike; as my tagging is pretty tight But if someone has a TON of files...and is trying to do mass conversion, and/or tagging; looks like a good solution.
    It's not the only one; but perhaps it'll turn out to be better or easier.
    CD
  17. #67
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    Chris,
    I bought dbpoweramp for mac and am using it now. Seems to be the ticket.
    Jeff
  18. #68
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Chris,
    Yeah; dbpoweramp is the gold standard, AFAIC. Good luck!
    CD
  19. #69
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    Hey Chris, anything I need to do differently with DSD or DVD files?
    Jeff
  20. #70
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Well...by DVD, do you mean DVD-A? What's the codec (file format) you've ripped to? As for DSD; if they're "native" .dsf, like mine...my understanding is, they can't be tagged.
    Now, Aurender will read Artist, track #, and track title from the file (like 01 - Artist - Song Title.dsf); but my understanding, is the dbpoweramp tagger...cannot tag .dsf (at least I don't get the option to...and it's one of the reasons, some guys are for converting DSD/DSF to FLAC).
    That being said...a) it's been a while since I checked, and I need to (so if I find anything out, I'll pass it along); b) might just need a plug-in at this point, and c) some other taggers...might do .dsf.
    CD
  21. #71
    Quote Originally Posted by CDLehner View Post
    Tag & Rename will tag .dsf files. All my DSD albums are tagged with cover art.
  22. #72
    Senior Member
    Join Date
    Nov 2013
    Eastern Shore, MD
    Posts
    1,312
    Quote Originally Posted by dminches View Post
    Yeah...as I said to JG; it had been a while, since I looked into it...and I was pretty sure there was a tweak at the time, and likely a pretty straight-forward solution by now.
    I actually had/have Tag & Rename, because I read it was the best mass re-tagger; at a time where I was contemplating that (though Mike's suggestion, seems like it has a lot of potential too).
    Also...mp3tag, does .dsf; so there are definitely options now. I'll admit; I've been using, whatever is "built-in" to dbpoweramp for so long...I don't really want to change it up much. I tried to see, if there was an update, or .dsf plug-in; or even really, what dbpoweramp uses.
    Can't really tell, though I'll probably just post at Illustrate and figure it out. It might even be, a stripped down version...of mp3tag.
    CD
  23. #73
    Senior Member
    Join Date
    Jan 2015
    Bluffton, SC, USA
    Posts
    192
    Is it only windows based?
    Jeff
  24. #74
    Hello Folks
    I am still not being able to correctly tag Aiff files (already tagged in windows via properties etc..)
    Example
    Album : Cartography
    Artist : Arve Henriksen
    12 tracks in aiff
    The Aurender still does not see it as a whole album
    One of the tracks is "Unknown"
    Weird ?
    Some other FLACS , ripped from dbpoweramp , have the cover not recognised
    Weird ?
    Any solutions ?
    Cheers
  25. #75
    Mp3tag has windows and Mac versions. It is excellent for tagging.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
