Results 51 to 75 of 75
Thread: Aurender N100H Review
October 17, 2015, 02:03 PM #51
Re: Aurender N100H Review
180 does seem like a low number based on my experience so far.
Anthony
Analog: VPI Clearaudio Innovation Wood/Kuzma 4Point/Ortofon A95> ASR Basis Exclusive HV---->
Digital: Antipodes CX (Oladra Upgrade)> Cary DMS-600 DAC/Streamer---->
...........Cary 306 SACD Professional Disc Player---->
===> Cary SLP-05 (Ultimate Upgrade edition)----> Clayton M-300----> MARTIN LOGAN SPIRES/REL 212SX x2
[Synergistic Research/Nordost/Wireworld/Furutech/SRA/Adona/Stillpoints/Track Audio/GIK Acoustics]
October 18, 2015, 07:32 AM #52
- Jan 2015
- Bluffton, SC, USA
- 193
you are more than correct, maybe I should keep quiet until I learn how to use it.
Jeff
Main System-Mola Mola Tambaqui-Antipodes K50-WW Plat 8 ic-Esoteric Grandioso S1 Esoteric C-02x Verity Amadis S-Shunyata Triton V3-Shunyata Typhon QRT
Shunyata AlphaNR V2 for Tambaqui-Elrod Statement Gold for S1, Elrod gold SCs Shunyata Sigma for Triton. Tubulus Concentus I2S.
Second System: URC streamer-Wadia 151 Power Dac, MIT Speaker Cables, Wilson Audio Watts and REL sub.
Third System: Denon AVR, URC Controller and network streamer, Netstreams Musica multi room-True Audio ceiling speakers
October 18, 2015, 10:25 AM #53
October 18, 2015, 10:30 AM #54
- Jan 2015
- Bluffton, SC, USA
- 193
Thanks Chris, definitely heard a difference with files moved to Aurender local drive. Clearer, more forward and a bit more channel separation. Now to go back and clean up my iTunes library on my mac mini. Going to try the scripts that Chris C recommended on CA only in later versions. Will let you know.
Jeff
October 21, 2015, 06:48 PM #55
- Apr 2013
- 43
Not sure why some people are trying to complicate this. I've always used iTunes to rip (AIFF format). It integrates perfectly with the Aurender. All you need to do is drop in the cover art file then upload the folder to the Aurender.
Are people having other issues with this (am I missing something)?
October 21, 2015, 06:50 PM #56
- Apr 2013
- 43
Most people don't realise that you can in fact plug in a USB CD-rom drive into an Aurender and rip directly. The cost is under $50 these days for a suitable drive. This is nice because you can then remove once done and you don't have a redundant drive sitting there afterwards.
October 21, 2015, 08:31 PM #57
October 21, 2015, 08:45 PM #58
- Apr 2013
- 43
Never tried it, I imagine it may connect to a database if connected to the internet, otherwise you'd have to do it manually. I think you'd be far better off ripping on your computer. I just mention it because I think the lack of a CD drive on the Aurender is a pro, not a con like some people suggest. Many work-arounds so that it's a non-issue.
The other benefit of ripping on your PC is that you have a backup of your music by default.
October 21, 2015, 10:54 PM #59
- Dec 2014
- 254
Speakers: Vandersteen Model 7 XTRM, 4 M&K ST-150Ts, 1 VCC-5; Amplification: 2 Vandersteen M7-HPAs, CI Audio D200 MKII, Ayre V-6xe; Preamp: Doshi Audio Line Stage v3.0; Phono Pre: Doshi Audio Phono Pre; Analog: Wave Kinetics NVS with Durand Tosca arm; SME 3012R arm, Ortofon Diamond Anna; Reel to Reel: Technics RS-1500; Doshi Tape Pre-Amp; Studer A810, Studer A812, Tascam BR-20; Multi-channel: Bryston SP-3; Digital: Taiko Audio Extreme> Lampizator Horizon, Oppo UDP-203;
October 28, 2015, 05:51 PM #60
- Jan 2015
- Bluffton, SC, USA
- 193
A little update and a question:
I have moved all music from NAS to Aurender local drive, I have cleaned up and added album covers and for the most part I am thrilled with the improvement in SQ. Still breaking in, but more room arrow d the instruments, female vocal are in the room and dead quiet background.
Question, I have about 55 albums that do not show an artist under the album title in the album view. They seem to be set up the same way ones that have artist are set up. Aurender help has suggested I use XLD to tag these. I have used XLD to convert from air to flac, but don't know what they mean by tagging??? Would someone please tell me how to set XLD preferences so that I don't screw up the file already there. Not sure where the artist would go to get it to display on my iPad. Thanks.Jeff
October 28, 2015, 07:03 PM #61
Jeff...I don't use XLD; so I can't speak to it...but I can't imagine tagging programs, are that different.
If you have XLD installed...I would suggest, you should be able to right-click on the file (or better yet...select all files, of a particular album for example)
For me...I select Edit ID Tag (but your option, with XLD installed...should be there instead)
And then your tagging options, should look...more or less...like this; where you'd enter meta-data information.
If you're still stuck, let me know; I can walk you through it real quick.CD
DAC/Pre-amp - PSAudio DsJ > Power-amp - > Speakers - PMC TwentyFive 23s
October 28, 2015, 07:54 PM #62
- Jan 2015
- Bluffton, SC, USA
- 193
Huge help Chris, I think I've got it!
Jeff
October 28, 2015, 09:31 PM #63
October 29, 2015, 09:37 AM #64
- Jan 2015
- Bluffton, SC, USA
- 193
Well, it works sometimes and sometimes it only tags the first track on the album and names only that track. On XLD it has a spot for track ____ to track____ and I put in the numbers. Could not seem to insert the image here.
Jeff
October 29, 2015, 09:40 AM #65
Has anyone tried this?
http://www.tuneupmedia.comMy Systems: http://www.audioshark.org/showthread...481#post158481
October 29, 2015, 12:53 PM #66
CD
October 29, 2015, 12:55 PM #67
- Jan 2015
- Bluffton, SC, USA
- 193
Chris,
I bought dbpoweramp for mac and am using it now. Seems to be the ticket.Jeff
October 29, 2015, 01:05 PM #68
October 29, 2015, 02:34 PM #69
- Jan 2015
- Bluffton, SC, USA
- 193
Hey Chris, anything I need to do differently with DSD or DVD files?
Jeff
October 29, 2015, 03:21 PM #70
Well...by DVD, do you mean DVD-A? What's the codec (file format) you've ripped to? As for DSD; if they're "native" .dsf, like mine...my understanding is, they can't be tagged.
Now, Aurender will read Artist, track #, and track title from the file (like 01 - Artist - Song Title.dsf); but my understanding, is the dbpoweramp tagger...cannot tag .dsf (at least I don't get the option to...and it's one of the reasons, some guys are for converting DSD/DSF to FLAC).
That being said...a) it's been a while since I checked, and I need to (so if I find anything out, I'll pass it along); b) might just need a plug-in at this point, and c) some other taggers...might do .dsf.CD
October 31, 2015, 08:44 AM #71
- Dec 2014
- 254
October 31, 2015, 12:06 PM #72
Yeah...as I said to JG; it had been a while, since I looked into it...and I was pretty sure there was a tweak at the time, and likely a pretty straight-forward solution by now.
I actually had/have Tag & Rename, because I read it was the best mass re-tagger; at a time where I was contemplating that (though Mike's suggestion, seems like it has a lot of potential too).
Also...mp3tag, does .dsf; so there are definitely options now. I'll admit; I've been using, whatever is "built-in" to dbpoweramp for so long...I don't really want to change it up much. I tried to see, if there was an update, or .dsf plug-in; or even really, what dbpoweramp uses.
Can't really tell, though I'll probably just post at Illustrate and figure it out. It might even be, a stripped down version...of mp3tag.CD
October 31, 2015, 06:43 PM #73
- Jan 2015
- Bluffton, SC, USA
- 193
Is it only windows based?
Jeff
October 28, 2017, 04:11 AM #74
- Jan 2017
- 115
Hello Folks
I am still not being able to correctly tag Aiff files (already tagged in windows via properties etc..)
Example
Album : Cartography
Artist : Arve Henriksen
12 tracks in aiff
The Aurender still does not see it as a whole album
One of the tracks is "Unknown"
Weird ?
Some other FLACS , ripped from dbpoweramp , have the cover not recognised
Weird ?
Any solutions ?
Cheers
October 28, 2017, 08:33 AM #75
- Nov 2014
- 2,104
Upgrade on the way...
