Results 101 to 139 of 139
Thread: Gauder RC7 MK2
October 9, 2017, 05:35 PM #101
- Aug 2014
- 82
Re: Gauder RC7 MK2
at Audiophon,
Max with the "combo" Domino & Demone" (Genesi ?!) have a stunning high end system!
The Gauder are too very great but you have listen what can a Demone vs a Xa100.5......
greetings
October 27, 2017, 05:59 AM #102
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
Has anyone tried the Gauder Clearwater speaker cable that are used inside the speakers? They are rather inexpensive.
November 11, 2017, 05:45 PM #103
Re: Gauder RC7 MK2
A small surprise and small coverage before world premiere - Gauder Akustik Darc 5 prototypes
Marcin
November 11, 2017, 08:09 PM #104
Re: Gauder RC7 MK2
Hi Marcin,
thank you for sharing! Can you already say something about the price point?
How do they compare to the other Gauder speakers?
Will they premier at the Warsaw show?Speaker: Gauder Akustik Berlina RC7 Diamond Black Edition DV
Power-Amp: Grandinote Demone
Pre-Amp: Grandinote Domino
Digital: TAD D1000 MkII; Auralic Aries G1 with modified LPS; QNAP HS 251+ (via Wifi)
Cables: Wireworld Gold and Platinum Eclipse
Power: Dedicated power line and dedicated grounding; Furutech wall socket; Furman IT Ref 16 IE; HMS Energia SL/OV
Rack: Bassocontinuo Reference Line Accordeon
November 11, 2017, 08:16 PM #105
Re: Gauder RC7 MK2
I used the Clearwater speaker cables with my Isophon Europa II speakers some time ago. As well in single wiring as in Bi-wiring and Bi-amping configuration. They are similar to the Kimber cables and are good value for the money. They may lack some transparency compared to some silver cables and the best of the pack, but for the money you should not worry...
I am quite sure that in the MK II versions of the Cassiano and Berlina they now use different cables, but can't tell you which ones.Speaker: Gauder Akustik Berlina RC7 Diamond Black Edition DV
November 11, 2017, 08:22 PM #106
Re: Gauder RC7 MK2
November 12, 2017, 06:22 AM #107
November 12, 2017, 09:50 AM #108
Re: Gauder RC7 MK2
November 12, 2017, 06:10 PM #109
Re: Gauder RC7 MK2
November 13, 2017, 07:42 AM #110
Re: Gauder RC7 MK2
Ok., I've got official Darc 5 price - standard version - 40 000 €, with diamond tweeters 46 000 €.
Marcin
November 13, 2017, 01:26 PM #111
Re: Gauder RC7 MK2
If the Darc 5 is size-wise an equivalent to the Berlina RC7 then it is upwards in the range, isn’t it (judging by the price)?
November 15, 2017, 06:38 AM #112
Re: Gauder RC7 MK2
Thanks Marcin, that’s quite hefty...
Inviato dal mio iPhone utilizzando TapatalkSpeaker: Gauder Akustik Berlina RC7 Diamond Black Edition DV
August 30, 2018, 03:58 AM #113
Re: Gauder RC7 MK2
Meanwhile in Poland - Gauder Darc 100 arrived :-D
Unboxing coverage
Marcin
August 30, 2018, 04:15 AM #114
Re: Gauder RC7 MK2
I like the fact that Dr. Roland Gauder consistently boycotts the new Accuton drivers. They are 'garbage' according to him.
Adam
Speakers: Magico M3
September 4, 2018, 04:05 PM #115
Re: Gauder RC7 MK2
And after Darcs ... came Berlinas RC9
Marcin
September 4, 2018, 05:15 PM #116
Re: Gauder RC7 MK2
Beautifully finished speakers... which did you like most and why??
September 5, 2018, 04:46 AM #117
Re: Gauder RC7 MK2
Marcin
September 17, 2018, 11:00 AM #118
Re: Gauder RC7 MK2
Marcin
October 7, 2019, 04:26 AM #119
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
There is now the "black edition" update? What is being done? I know that the RC7 gets the bass booster and new biwiring terminals. New crossover?
October 7, 2019, 04:37 AM #120
Re: Gauder RC7 MK2
Correct, they also have changed the cross-over circuit layout and they now use even better parts quality by Mundorf.
My dealer told me that the step forward is audible but less significant than the step from them original to the Mk II version.
However, I very much appreciate the house-policy to offer upgrades over the whole lifetime at a reasonable price and extending the manufacturer’s warranty.
October 20, 2019, 10:49 AM #121
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
The black edition update is here. Now I have a Gauder Akustik Berlina RC 7 Mk II Diamond Biwiring black edition. I prefer it without the bass Booster (in my room). The speaker is definitly better, the sound is more colourful and detailed. The bigger terminals are better. Worth the money.
Vitus Audio SIA-025Mk2 + SS-025 (biamping), Gauder RC7 Diamond black edition, Vitus Audio SCD-025Mk2, Simon Yorke S9+Jan Allaerts MC1 Boron+Dr. Fuss power supply+AS Phonolab, Amazon 1+SME V+Ortofon Rohmann+Nagra BPS, Oppo BDP-105D modified by Gert Volk Audio, Melco N1Z/2 EX H60+D100B+Sbooster, Copulare Grand Porto, Magnan Signature speaker cable, Magnan Vi XLR + RCA, Göbel Lacorde Statement XLR, Göbel Lacorde Statement USB, AQ Diamond + Vodka RJE, Buffalo BS-GS2024 Switch, modified 10Gtek+Startech 1000Base Fiber, Wireworld Starlight 8 CAT8, Vitus Andromeda power cable, Aural Symphonics Magic Gem power cable, Aural Symphonics Cubed v3 power bar, Stillpoints Ultra SS + Ultra mini, Ansuz Darkz, Shun Mook Mpingo Discs, Hifi tuning supreme 3 fuses, ahp Klangmodul 4g fuse module, HMS wall socket, Block Audio C-Lock lite, Furutech NCF Booster. Room 40 m2.
October 24, 2019, 03:27 PM #122
Re: Gauder RC7 MK2
Congratulations! I very much like the approach of Gauder to continuously offer updates at reasonable prices.
Have you heard the RC7 Black against the DARC 100?
October 26, 2019, 04:08 AM #123
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
No, have not heard any other Gauder speaker.
October 28, 2019, 08:10 AM #124
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
Tried Ansuz Darkz ( old A with new titanium balls) under the floor protectors. Much better than Harmonix RF-900 Mk2, but sucked all the life out of the speakers. Sounded precise but dead. Does not work for me on my floor (concrete-screed-parquet).Vitus Audio SIA-025Mk2 + SS-025 (biamping), Gauder RC7 Diamond black edition, Vitus Audio SCD-025Mk2, Simon Yorke S9+Jan Allaerts MC1 Boron+Dr. Fuss power supply+AS Phonolab, Amazon 1+SME V+Ortofon Rohmann+Nagra BPS, Oppo BDP-105D modified by Gert Volk Audio, Melco N1Z/2 EX H60+D100B+Sbooster, Copulare Grand Porto, Magnan Signature speaker cable, Magnan Vi XLR + RCA, Göbel Lacorde Statement XLR, Göbel Lacorde Statement USB, AQ Diamond + Vodka RJE, Buffalo BS-GS2024 Switch, modified 10Gtek+Startech 1000Base Fiber, Wireworld Starlight 8 CAT8, Vitus Andromeda power cable, Aural Symphonics Magic Gem power cable, Aural Symphonics Cubed v3 power bar, Stillpoints Ultra SS + Ultra mini, Ansuz Darkz, Shun Mook Mpingo Discs, Hifi tuning supreme 3 fuses, ahp Klangmodul 4g fuse module, HMS wall socket, Block Audio C-Lock lite, Furutech NCF Booster. Room 40 m2.
December 31, 2019, 01:33 AM #125
- Jun 2015
- 1
Re: Gauder RC7 MK2
Hi I am running RC7II Diamonds fed from an Antipodes DX3/Mola Mola Makua DAC/AVM SA8.2. The Gauders replaced my B&W 803N and were a massive improvement but also a challenge as initially I was getting an etched sound that was fatiguing. The B&W were much easier on the ear but a bit fat and lazy.
I changed the speaker cable from silver to 9guage copper and that certainly helped smooth things. Next I moved the speakers around in my room (15’ x 23’ x 10’ ceiling) and angled the speakers in only 3 degrees. This helped further. Then I reduced the bass output to -3dB (pulled out the bass selecter pin).
Then I used the services of home audio fidelity in the Netherlands to provide room correction filters that I applied in Roon with excellent results. Read the review below.
It cost me about $100 for the Dayton microphone and $200 for Thierry’s services. So for $300 all up I was able to get a massive improvement. See the review in HiFi-advice for a nice run down on Thierry’s services.
The Gauders now brought an amazing tautness to the bottom end and instruments took up firm images in the room with amazingly fast transients. And I can listen for hours with no fatigue.
Diasoft I am interested to understand the audible differences you have found between RC7MkIID and the black version. If you share your experience that would be great.
January 7, 2020, 04:50 PM #126
Re: Gauder RC7 MK2
Welcome to the forum Mark P., sorry for the delay in approving you.
January 16, 2020, 02:59 AM #127
- Jan 2020
- Bangkok
- 1
Re: Gauder RC7 MK2
I bought the RC7 mk ii Black edition on Oct 19. Almost give up on them after 2 months. The speakers are really hard to tame in lower region. Bass is blur due to room size and speaker placement (my room size is 4.5x5.5 btw). However, I have no complain about their speed. These are the most accurate and resolution with natural sense speakers to me. I think they require quite space and special room treatment to shine.
After flipping my room around and play with the placement. They sound better and better but still not at their full potential. Thinking about sending an email to the manufacturer to ask about their perfect reference room size for these speakers. I plan to build one just for them in the future.
My equipment
Intel NUC > Auralic Aries G1 > Chord Hugo M Scaler > Chord Dave > A Arts Tube Preamp II MK II > AVM Ovation SA8.2
January 18, 2020, 06:25 PM #128Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
January 27, 2020, 06:56 PM #129
Re: Gauder RC7 MK2
Hi,
The first thing to do is to put the bass selector in the rear of the speakers to -1.5 dB. In addition you can put some absorber material in or under the bass reflex tunnel.
When our second kid was born and after a moving, I moved with my stereo into one of our basement rooms. Quite the opposite of an ideal listening room: 17 square meters with a low ceiling.
I found a good compromise for the speaker positioning and did some heavy room treatment including bass traps. Now the sound is great again.
The best receipt is a mixture of speaker positioning and room treatment
I hope you’ll be happy with them!
February 2, 2020, 04:02 AM #130
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
Anyone tried an REL subwoofer with Gauder RC7s?
RC11+REL No.25 stack: https://www.youtube.com/watch?v=SQ1Slm2rCj0Vitus Audio SIA-025Mk2 + SS-025 (biamping), Gauder RC7 Diamond black edition, Vitus Audio SCD-025Mk2, Simon Yorke S9+Jan Allaerts MC1 Boron+Dr. Fuss power supply+AS Phonolab, Amazon 1+SME V+Ortofon Rohmann+Nagra BPS, Oppo BDP-105D modified by Gert Volk Audio, Melco N1Z/2 EX H60+D100B+Sbooster, Copulare Grand Porto, Magnan Signature speaker cable, Magnan Vi XLR + RCA, Göbel Lacorde Statement XLR, Göbel Lacorde Statement USB, AQ Diamond + Vodka RJE, Buffalo BS-GS2024 Switch, modified 10Gtek+Startech 1000Base Fiber, Wireworld Starlight 8 CAT8, Vitus Andromeda power cable, Aural Symphonics Magic Gem power cable, Aural Symphonics Cubed v3 power bar, Stillpoints Ultra SS + Ultra mini, Ansuz Darkz, Shun Mook Mpingo Discs, Hifi tuning supreme 3 fuses, ahp Klangmodul 4g fuse module, HMS wall socket, Block Audio C-Lock lite, Furutech NCF Booster. Room 40 m2.
January 21, 2021, 04:15 PM #131
Re: Gauder RC7 MK2
After a short break ... Darc 140 unboxing :-D
There were rather cold outside so ... ;-)
Marcin
January 21, 2021, 07:50 PM #132
Re: Gauder RC7 MK2
Congrats Marcin, beautiful speakers! Hope you held off on the celebratory whiskey until after the setup was completed.
January 22, 2021, 02:30 AM #133
January 24, 2021, 12:47 PM #134
Re: Gauder RC7 MK2
Hi Marcin,
Wonderful speakers! For me they are the sweet spot of the DARC range. My dealer even prefers them over the DARC 200 due to their smaller and quicker bass drivers.
I am curious about your impression.
Regards
MartinSpeaker: Gauder Akustik Berlina RC7 Diamond Black Edition DV
January 24, 2021, 05:35 PM #135
Re: Gauder RC7 MK2
By the way and back to the title of this thread...
In January I met Dr. Gauder at a dealer presentation of the DARC 100 and 200 with the new top of the line T+A Electronics. As I was considering trading in my Berlina RC7 D MKII with a pair of DARC 100, I asked Dr. Gauder about his opinion.
He told me that a large number of Asian customers still prefer the Berlina series to the DARC series to to their fuller sound. However, he told me that with the Black Series update, the Berlina RC 7 would make a big step towards the transparency and bass performance of the DARC series.
Due to the lockdown it took me until June to bring my Berlina speakers to Gauder Akustik. The good thing about such a small and customer oriented manufacturer is that you can ask for any kind of customization. I therefore asked Dr. Gauder to go beyond the update to the Black Edition version and get me the best available sound from my Berlina RC7... and Dr. Gauder had already some speciall tweaks in mind.....
When I went to pick-up my upgraded Berlina speakers, me and Dr. Gauder had a test run in their listening studio and the big leap forward in sound quality was clearly audible - even in this unknown environment. The clarity and soundstage was just stunning! The Berlina Black Edition speakers are a kind of mix between the Berlina MkII and the DARC speakers: transparency with body and weight.
The official name of my speakers is now: Berlina RC7 Diamond Black Edition Double Vision
Another great feature of the Black Edition speakers is the Bass Extension which boosts the low bass (I measured below 60 Hz +3-4 db). If you don‘t need this boost (like me), the amplifier even sees a simpler load which is great for my Grandinote monos.
So I heavily recommend the Black Edition Upgrade!
February 2, 2021, 06:27 AM #136
Re: Gauder RC7 MK2
RC9 price:€96000 they can clean a house for this price???
March 11, 2021, 04:03 AM #137
Re: Gauder RC7 MK2
Gauder Akustik Darc 140 review (English)
Marcin
September 22, 2021, 05:37 AM #138
- Sep 2016
- Germany
- 54
Re: Gauder RC7 MK2
In the price lists there are two extras for the Berlina and DARC series, called VU-meter and musiclight. What are they? I cant find any information on the internet.
October 14, 2021, 08:58 AM #139
Re: Gauder RC7 MK2
VU-meter shows the power value delivered into loudspeakers.
Marcin
Yup, am having trouble streaming now, I just want to hear local files via the L2 - the biggest sonic upgrade in my system is more dynamics and its concomitant sense of "life" that adds to the music.
Lumin L2 not grouping album songs...
