Results 51 to 80 of 80
May 9, 2015, 06:37 PM #51
Re: Vinyl Cleaning - The Dirty Truth Letter from Mat Weisfeld, VPI Industries
I believe we are still on point. The issue is finding that vinyl listening nirvana. Cleaning: is it the machine, the vinyl, both? There is no is "I have the answer - nobody does" but rather, seeking to understand...everyone has something to contribute that may be a great idea in nailing down what works most for the ultimate vinyl experience - cleaning methods.
May 9, 2015, 07:15 PM #52
+10
May 9, 2015, 08:03 PM #53
- Aug 2014
- 685
I bought my first VPI cleaning machine back in the mid '80's (about 30 years ago). IIRC it was a VPI 16 when the suction tube was mounted diagonally on the top. I cleaned all 15,000 of my records with various VPI models, and cleaned almost all of them again (including the many used records I bought from London in the past 18 years) when I switched to Disc Doctor liquids and brushed, still using a VPI to do the suction for the cleaning solution and then the distilled water rinse. When I started my ripping project 5 years ago, I was just ripping records that I had cleaned with the VPI/DD method. At about 2000 records into the ripping, I discovered the Audio Deske System Ultrasonic cleaner and recleaned the last 7500 records (which had all beeen previously cleaned by VPI/DD).
Except for a handfull of records that have only been cleaned by the Audio Deske that I have acquired in the past 3 years - almost all new pressings, all my records have been cleaned at least two, some three time (VPI, VPIDD and ADS). There are are still about 5000 records that have only been cleaned by VPI, VPIDD or just VPIDD, which I do not plan on ripping.
So my experience with record cleaners has been long and very positive, but with almost all records have been cleaned at least twice with two different systems, I don't have good comparisons with the effects of different methods. I haven't tried this but it may be like cleaning the carpet with two different vacuum cleaners. The second one will always pick up something that the first one leaves behind, no matter which one you start with.
BTW, the vast majority of my 15,000 LP's have been purchased used (that however means I still have a few thousand I have purchased new.)
LarryAnalog-VPIClassic3-3DArm,Lyra Skala+MiyajimaZeroMono,2xAmpex ATR-102,Otari MX5050B2, Merrill Trident Tape Preamp, Herron VTPH-2A&BottleheadPhonoPre,
Dig Rip-Pyramix,IzotopeRX3Adv,MykerinosCard,PacificMicroso nicsModel2 AD
Dig Play-Lampi Horizon, mch NADAC Roon/HQPlayer,Oppo105
Electronics-DoshiPre,CJ MET1mchPre,Cary2A3monoamps
Speakers-AvantgardeDuosLR,3SolosC,LR,RR
Other-512 Engineering Tim Marutani Symmetrical Power IsoTrans and cables,AudioDiskVinylCleaner,
Music-2.3KR2Rtapes,1.5KCD's,500SACDs,60TBripped files
May 10, 2015, 10:59 AM #54
- May 2013
- 2,013
May 10, 2015, 12:04 PM #55
May 10, 2015, 12:37 PM #56
- Feb 2014
- 1,861
Larry...After cleaning some 7500+ records with the Audio Desk, how is the machine holding up?
Speakeasy
May 10, 2015, 01:46 PM #57
- May 2013
- 2,013
Good question. If it's holding up well after all that assault, it's safe to say that it is a very well built machine, (little doubt it isn't). With that amount of records there is no doubt about the need for it. It scares me to think about doing that many on my VPI, not that it may not hold up, but I wouldn't and I don't mind taking time to clean records at all. Makes me thankful that I only have a handful of records compared to almost everyone here.
May 10, 2015, 02:29 PM #58
15000 is past a collection , its a library ....
wow ..!!!!
May 10, 2015, 04:49 PM #59
I relocated into the office closet all three vinyl cleaning machines. Next week, I have an electrician coming in to install two electrical outlets into the closet. Later in the month, I will have an L shape desk created to accommodate the machines in a side by side order. This will give me ample room to add a Monks, ClearAudio Double Matrix Sonic and to build and add the V8 too. I'm in heaven - I get to experiment with all the top vinyl cleaning machines.
May 10, 2015, 05:05 PM #60
- May 2013
- 2,013
May 10, 2015, 08:29 PM #61
Someone asked about this article and finally found the issue in a box of audio magazines. From Sounds Like... magazine, Issue #8, 1990.
Who would have thought 25 years later LPs are making a comeback, the number of RCFs on the market has more than doubled and high quality inner sleeves in abundance. Just goes to show how lousy we are predicting the future.
May 10, 2015, 09:45 PM #62
- May 2013
- 2,013
Astonishing when you stop and think about it, then think back to when vinyl was all there was and we had next to nothing in RCFs, RCMs, quality inner sleeves and all that.
Who knew.
May 13, 2015, 12:36 PM #63
David-
You win! You have all the record cleaning machines together in one room. You are able to create a stand alone and various combination cleaning of each of your records. I know this is an invaluable experience because you can test, experiment and make your determinations of what is prefered and not prefered. No moral decisions here, just trade offs.
What you could help us all with is document your standards for clean and dirty. It does not have to be complicated, like "I removed .03 grams of particulate matter from Record X.." - though I am sure some of our astute hobbyists that read this may want to see some true objectivity. (And if you can help David and us on this, please come forward)
For your standard of clean, please take a moment in your own words, document with logical examples of what a clean record is to you. This way the reader has an understanding of what a standard of clean is.
Please do the same for the standard of dirty. It can be that record store find, that Discogs Disc that arrived from Greece, or the effect of pet dander, dust and oily human hands. Something to that effect that makes the record unsatisfactory to play on your turntable.
What is interesting is this cleaning machine, which includes both "Sonic" and "Vacuum" technologies. 1 What do they know that VPI, KLAudio, and Autodesk doesn't? 2 What have they learned? 3 Is this your next machine?
https://www.youtube.com/watch?v=4Dd9k5x2jaU
here is a Youtube search.. https://www.youtube.com/results?sear...r+audio+matrix
Beyond this, 4 what other resource could you use to determine that one record machine is better than the other? 5Who could possible tell you what is what when you have all the RCMs right there in front of you?
First my answers to questions 4 & 5:
4: Myles B. Astor or Michael Fremer are verbose in all thing Vinyl. They are professional reviewers that stand as critics that many trust their judgment. (and I forgot someone, please add them because I don't know everyone or everything.)
5: More people who are either invited your house or has the an agreeably high performing audio system to confirm what you are telling us. I am sure the people in Q4 have seen all this in one shape or another, but have not done the extensive test that you have- for one reason or another.
I conclude that you are doing great things for the art of music, vinyl and music enjoyment. You are not a magazine or a website with financial motives. Your quest is the truth. It may not be the absolute truth, but you have climbed the mountain, looked around and you can see things that many cannot. This reason to be, makes you THE expert, unless someone should challenge your findings. (Then life will get a whole lot more exciting for us in the audience). Keep up your "Audio Philanthropy" and be that maven for all of us to learn from.
May 13, 2015, 01:23 PM #64
- Aug 2014
- 685
My Audio Deske lasted about 6500 records before it bit the dust - motor burned out. I did many of the records with 5 beeps (maximum cleaning time) though they probably only need one beep (normal cleaning). That probably led to an earlier demise. Clearly for most users that wouldn't be an issue. Anyway they replaced it with a new machine for $1500, a little more than 1/3rd the retail price. My dealer, Tim Marutani, handled the transaction. I had considered getting a KLA to replace it, but at the price and my general satisfaction with the AD, I decided to stay with AD. I'm around 1000 records into the new machine with no problems. I am only about 750 records away from finishing my ripping project, so that should be done in a few months! Hurrah!
PS. I had a total of 4 VPI machines over the 25+ years, cleaning my 15,000 records, most of them two different times. Three machines by necessity and one by upgrade.
May 13, 2015, 01:35 PM #65
Larry- Interesting comments and thank you for sharing. Also please feel free to create a thread about your Vinyl Ripping project- It's very interesting to me and I know others would like to learn from what you have learned. (I want to do this with a TASCAM DA-3000 and my current tube phono stage)
Regarding your postscript, have you had the chance to have all 4 VPI machines together, in one room, at the same time? (that just sounds naughty ) It's unclear if you repurchased or had various combination of the four at two different times or ??? thanks.
May 13, 2015, 02:17 PM #66
- May 2013
- 2,013
Thanks Larry.
Wow, gave out after 6500 LPs huh? Although, considering the fact that you did max cleaning on all those records it might have gone to 7500 or more had you cleaned accordingly as you mentioned. Still, that's only about $1.63 per record and you can't put a price on the automation and value of time spent not to mention any wear and tear on your hands or something cleaning that many records by other means.
A replacement for $1500...how do they do that? If these machines were that to begin with sales would be through the roof. Although even at $4k, if I had a collection 1/4 the size of yours, I'd save up for however long it took and whatever to get one rather than try that stunt with my VPI. (Although I would not be putting really dirty records through without a first pass through the VPI or whatever machine already on hand). It would be worth every cent in my opinion. Sure, the VPI is a fraction of the cost, is a fine machine for it's purpose and most everything on it is easily replaced even by the end user, but my hands and the rest of my body and time are not replaceable.
Hmm, seeing that your already 1000 records in on the new one and not a hint of issues, perhaps some improvements were made inside someplace?
~Eric
May 13, 2015, 07:41 PM #67
Myles, thank you for posting the article. Will give it a read asap.
Allen
May 13, 2015, 07:47 PM #68
Yes, Myles. Thank you! I am handy with Photoshop, so I am going to process the images and make my own pdf of this.
May 13, 2015, 08:00 PM #69
- Aug 2014
- 685
Thanks, Myles. I'm sure I read the article way back when. My 4 VPIs were consecutive. I started with the VPI 16, IIRC. then went to a 16.5, then a 17F, and then back to a 16.5. I gave the last 16.5, still in decent condition, to a friend, after I got the ADS. My dealer, Tim, negotiated the replacement ADS - rather than sending my old one back to Germany to be repaired. I don't know how the price was determined, but it seems that it probably is well below wholesale (negotiated to keep both he and me reasonably happy and getting me a replacement to not delay my ripping project.)
I'll do a thread on my ripping project at some point. I have talked about it in different threads and different sites, but nothing comprehensive.
May 13, 2015, 09:01 PM #70
- Feb 2014
- 1,861
David...Perhaps a few pics of grooves under a microscope could be in comparative effectiveness order?
Speakeasy
May 13, 2015, 09:04 PM #71
May 13, 2015, 09:24 PM #72
- Feb 2014
- 1,861
Maybe a Dino-lite will be good enough AM-7013MZT4 is 400x high resolution @ 5MB with polariser function should be good enough to show some level of granularity in the groove walls. Not sure if you could pick up groove damage at that resolution but you will see particulates easily enough.
I would use a scope with a polariser light that can be dialled in.
I haven't had much success using this model for SRA because it is short throw (long distance is better to track a stylus) so I will be buying the cheaper model recommended for that purpose.
If Myles is reading...do you recall what was the Dino-Lite model typically used for SRA measurement?
Speakeasy
May 13, 2015, 09:27 PM #73
May 13, 2015, 09:31 PM #74
For the group, Stylus Rake Angle (SRA)
How to Use a USB Digital Microscope to set 92 Degree Stylus Rake Angle (SRA) | Analog Planet
May 13, 2015, 09:35 PM #75
May 13, 2015, 09:41 PM #76
- Feb 2014
- 1,861
May 13, 2015, 09:54 PM #77
Avanti Audio
May 13, 2015, 09:58 PM #78
- May 2013
- 2,013
May 13, 2015, 10:06 PM #79
Visit our own SRA thread and please contribute your pics!:
http://audioshark.org/all-things-ana...l#.VVQC3SyLW0YAvanti Audio
May 13, 2015, 10:29 PM #80
Myles, I upload the pdf here on AS. Folks, all that I did was take Myles images, remove colour content, straightened and did some text sharpening and packaged into a pdf. Voila.
Nucleus one
