Results 1 to 49 of 49
Thread: Long Tone Arms
February 1, 2015, 03:37 PM #1
Long Tone Arms
I know this is an open ended question with a lot of variables but I see a lot of turntables mentioned that are equipped with 10 -12 " tone arms. Do they make a difference ? Do these longer tone arms improve tracking and distortion ? or will a better designed and constructed 9" tone arm be a better option.
February 1, 2015, 04:11 PM #2
Re: Long Tone Arms
Less headshell offset is one factor resulting in lower tracing disortions. One does have to be a little more careful though with alignment as Bob Graham showed. But that's a minor issue. All things being equal (and mass), I'd go with the 12-inch arm. Even a 10.5 inch isn't the same.
Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
February 1, 2015, 05:21 PM #3
Re: Long Tone Arms
the same Bob Graham will say 12" arms were developed for the 16" LP and have no advantage playing 12" discs. The 'theoretical' advantage is slightly lower 2nd harmonic distortion (over a 9 incher), provided the cart is perfectly aligned. Thats the rub, alignment is more critical in a 12" as miss-alignment is magnified compared to 9 incher. If you ask designers like Allen Perkins and AJ Conti among others they will tell you 10-10.5 inch length for a pivoted tonearm is the sweet spot for playing 12" LPs.
February 1, 2015, 05:29 PM #4
Re: Long Tone Arms
That's the same Bob who went out of his way to knock any and all 12-inch arms for the longest time and was the last (?) to make a 12-inch arm. And speaking as someone who has heard all three lengths, there's simply no comparison; the 12-inch arm is sonically better and the closest in sound to a linear tracker that I've experienced. And now that there's new lighter materials to fashion the arms, the added mass isn't an issue.
February 1, 2015, 06:10 PM #5
Re: Long Tone Arms
I agree with Myles 100% Any of you who ever owned an ET-2 arm at some point in your life knows how pure that arm sounded in spite of it's other flaws that eventually made me leave it. The SME 312S arm is the first tonearm that I have owned that has the same purity the ET-2 had and has allowed me to never look back. Really good 12" tonearms are the bomb and don't let anyone tell you different. You need to hear one for yourself in your own system before you believe when other people tell you that 9" is plenty.
February 1, 2015, 06:38 PM #6
Re: Long Tone Arms
Myles,
Some people will tell you that this happens mainly because the longest arm has the same problems as the linear tracker, mostly a higher mass.
BTW, IMHO the difference between the sound of a 9" and a 12" tonearm can not be due to tracking error, otherwise the 9" and the 12" would sound the same at zero tracking error points. Headshell offset can not be neglected, as you pointed.
February 1, 2015, 06:40 PM #7
Re: Long Tone Arms
I don't want to turn this into Bob Graham against the world thread, FWIW we talked about upgrading my phantom to an elite and he talked me out of his 12". he makes them for certain installations that lack the clearance necessary for the 10."
As far as what the ET-2 is capable of, I recently reacquainted myself with not one, but two of them - hi/low pressure pumps, 5-gal surge tank and all. Its not that it can't sound very good (it's been 27 yrs since i owned one) but once installed its faults snapped into focus more clearly than ever. PM if you're looking for one (two available).
February 1, 2015, 06:49 PM #8
Re: Long Tone Arms
Did you try the latest Carbon Fiber/Aluminum/Teflon constrained layer high stiffness arm wand? I also own one ET-2 and still consider it the best existing value for money in tonearms when bought at the current used price - although I am currently using a SME30/SMEV, as I am a lazy man. But I keep the ET2 for the day I became a more rational audiophile.
February 1, 2015, 06:51 PM #9
Re: Long Tone Arms
So tell us what faults you found with the ET-2 with regards to how they sound in your system. My main issue was the lack of a true signal ground which always caused some degree of a hum issue depending on the associated gear, wiring, the weather, and how strong local FM stations were. Oh, and the ET-2 has to be set up perfectly level or it won't play at all. Gus won't get on the bus if the ET-2 isn't perfectly level. The ET-2 arm is a pain in the ass to set up and if you don't have the metal jig to set up the arm and keep it set up, it may have never been right. The metal jigs were designed to be owned by dealers rather than consumers and they were fairly rare. I owned the metal jig for over 25 years until I finally decided to ditch the ET-2 once and for all.
February 1, 2015, 07:19 PM #10
- Aug 2014
- Canada
- 580
Re: Long Tone Arms
If I have this right the pro about a longer arm is head shell angel thus better tracking angle. The con is more weight anything you do to make the arm lighter can be done to a shorter arm only lighter. Has anyone done a A B with the same arm in different lengths how much improvement do you get. No one gets to caught up in what a cartridge weighs as in the lightest at all costs is a small mass gain that big a deal. I have heard you get more detail and better bass has this proved to be true.
Lyra Atlas, tri-planner, clear audio statement, Burmester 100, Ayre KXR20, Ayre MXR20, Ayre DX5, Adept Response line conditioner, Ayre signature interconnects, Cardas clear power cables,cardas clear speaker cables and Martin Logan CLX with Decenti subs with Cardas hex link.
Not in use Infinity QLS and Ohm F
February 1, 2015, 07:38 PM #11
Re: Long Tone Arms
Unfortunately the ET-2 setup instructions are very poor, even confusing, and IMHO the metal jig should be used only for drilling the fixing hole, although the drilling diagrams included in the manual are very easy to follow. After that, once you understand what is a parallel line, a right angle and the function of each part, anyone owning a good miniature level should be able to set it in less than fifteen minutes.
And yes, any linear arm has to be set to perfect level - if you have the wrong turntable it will be a complete disaster.
Never had any issue with hum, although I remember a particular MC cartridge that could receive short wave radio with the ET.
February 1, 2015, 07:47 PM #12
Re: Long Tone Arms
Understood but mass is really not an issue say with the 10.5 vs. 12-inch VPI 3-D arms. The 12-inch's effective mass is probably less than most 9-inch arms. Of course there might be less SRA/VTA changes with the longer arm but that shouldn't be a huge issue with a clamped LP. Then again we could have less groove jitter as Peter Ledermann calls it going on because the 12-inch is tracing the groove better.
My reference for linear tracking arms was the now sadly discontinued Air Tangent Tonearm. Wonderful arm, low distortion, great resolution and an amazing sense of space. The 12-inch come the closest to capturing those qualities while at the same time surpassing and by a large margin, the AT's low end. That to my ears is always their Achille's heel. (The AT had because of its captured bearing design, a lot less mass issues than the ET).
And Francisco is spot on with the setup of the air bearing arms. The ET was probably the most finicky to get right but Leif even had some optional arm wands to better mate the arm to different cartridges. Plus I always dreamed of the remote control VTA option.Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
February 1, 2015, 08:23 PM #13
Re: Long Tone Arms
February 1, 2015, 09:25 PM #14
Re: Long Tone Arms
February 1, 2015, 10:32 PM #15
Re: Long Tone Arms
the ET-2's high mass in the horizontal plane requires high inertia to move the arm. tracking off center pressed LPs with the slightest warp throws the arm into a tizzy and audible distortion occurs, not to mention the narrow selection of carts that seem to work well in that arm. And yes, i do have the rare-as-hens-teeth metal set-up jig.
February 1, 2015, 10:36 PM #16
February 1, 2015, 10:40 PM #17
February 1, 2015, 10:44 PM #18
Re: Long Tone Arms
February 2, 2015, 09:29 AM #19
Re: Long Tone Arms
So a well designed, constructed and adjusted tone arm when matched to a quality cartridge regardless of the tone arm length should be sufficient for the average home user. I guess I need to go listen to a TT with a 12" arm but the issue is finding a dealer or a person close that has a table with a 12" tone arm.
February 2, 2015, 10:20 AM #20
Re: Long Tone Arms
I don't recall my ET-2 ever being thrown into a "tizzy." I remember somebody on Who's Deaf posted a video of their table with the ET-2 playing an LP and the ET-2 was swaying to and fro like a drunk in the breeze. I told him that I had never seen an ET-2 do that before. He thought it was normal. I subsequently posted a video of my ET-2 mounted on my VPI TNT playing an LP in a manner I considered normal.
Owning the SME 312S has made me forget about ever owning the ET-2 again. No more pumps, surge tanks, air lines, and filters for me.Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
February 2, 2015, 10:25 AM #21
Re: Long Tone Arms
February 2, 2015, 12:52 PM #22
Re: Long Tone Arms
February 2, 2015, 01:41 PM #23
- Aug 2014
- 685
Re: Long Tone Arms
Analog-VPIClassic3-3DArm,Lyra Skala+MiyajimaZeroMono,2xAmpex ATR-102,Otari MX5050B2, Merrill Trident Tape Preamp, Herron VTPH-2A&BottleheadPhonoPre,
Dig Rip-Pyramix,IzotopeRX3Adv,MykerinosCard,PacificMicroso nicsModel2 AD
Dig Play-Lampi Horizon, mch NADAC Roon/HQPlayer,Oppo105
Electronics-DoshiPre,CJ MET1mchPre,Cary2A3monoamps
Speakers-AvantgardeDuosLR,3SolosC,LR,RR
Other-512 Engineering Tim Marutani Symmetrical Power IsoTrans and cables,AudioDiskVinylCleaner,
Music-2.3KR2Rtapes,1.5KCD's,500SACDs,60TBripped files
February 2, 2015, 01:47 PM #24George
February 2, 2015, 08:44 PM #25
Re: Long Tone Arms
Yes, I owned both the 9" SME V and the 12" SME V-12. The latter is much better. I did a direct comparison over a two week period on my SME 30/12 turntable. The V-12 is smoother, more detailed, better bass, more transparent, more extended. The lower offset angle is an advantage as it means there is less skating force. There is obviously less tracking distortion also. SME calculates it as 27% less distortion.
Incidentally, cartridge weight can be quite important. My AirTight Supreme weighs 12 or 12.5 grams which is the perfect weight for the SME V-12 counterweight to balance the cartridge and be very close to the pivot point of the arm. This decreases inertia and makes the arm more responsive.Link to my system thread: https://www.whatsbestforum.com/threa...l-sound.32867/
Analog: Micro Seiki SX 8000 II, 2 NOS SME 3012R tonearms, 2 vdH Colibri Grand Cru, Colibri XPP
Electronics: Lamm LP2.1 Deluxe, Lamm LL1.1 Signature, Lamm ML2
Speakers: Vitavox CN-191 corner horns
Cables: Stock SME phono cables, DIY ICs and speaker cables, Ching Cheng power cords, custom rack and amp stands
February 2, 2015, 08:55 PM #26
- Jan 2015
- 181
Re: Long Tone Arms
Garth...just wondering if you auditioned those Ayre interconnects before you got them...I also have an all Ayre system and was amazed at how much better other cables sounded. I don't mean to disparage your system....its great as you know, just saying that I got rid of my Ayre cables and replaced them IN MY SYSTEM got better sound.
February 2, 2015, 08:59 PM #27
Re: Long Tone Arms
February 2, 2015, 09:15 PM #28
- Aug 2014
- Canada
- 580
Re: Long Tone Arms
Thank you for the reply I had a SME V- 9 inch for many years on a SOTA . I will keep in mind your findings . I have found comparing tables arms and cartridges very hard due to the set up need only to be out a fraction to change so much. Also break in times are variable from product to product . As you say it improves the bass, smoother and more detail is of great interest. The SME 30 is a table I also considered. Thanks again for your time and opinion.
February 3, 2015, 12:30 AM #29
Re: Long Tone Arms
Build one!~
https://www.youtube.com/watch?v=gbAKIOGcwUc
February 3, 2015, 12:34 AM #30
Re: Long Tone Arms
February 3, 2015, 09:05 PM #31
- Sep 2014
- Oklahoma City
- 23
Re: Long Tone Arms
He must've been joshing you, because in this thread
the man himself says they're gonna make one
vpiindustries.com/forum ? View topic - Prime vs C3 vs C4???
FWIW: I think it would look absolutely goofy......and would probably sound
about the same......
February 3, 2015, 10:01 PM #32
Re: Long Tone Arms
Well that info must be dated. That came from when HW first released the 12-inch arm now what 15+ years ago. Maybe the lighter 3D arm and lower mass changes the equation. But thanks for the link!
February 4, 2015, 02:51 PM #33
Re: Long Tone Arms
February 4, 2015, 02:52 PM #34
Re: Long Tone Arms
February 4, 2015, 03:11 PM #35
Re: Long Tone Arms
February 4, 2015, 03:33 PM #36
Re: Long Tone Arms
February 4, 2015, 03:41 PM #37
Re: Long Tone Arms
February 4, 2015, 04:02 PM #38
Re: Long Tone Arms
I have LTA envy.
February 4, 2015, 08:38 PM #39Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
May 29, 2015, 10:00 PM #40
- Mar 2014
- Chicago
- 1,234
Re: Long Tone Arms
I am very curious what people think about Franc Kuzma's latest master piece. Any one hear this yet?
4Point 14 inch- New from July 2015 - Kuzma Professional Turntables, Tonearms and Accessories
July 2, 2015, 03:13 PM #41
July 2, 2015, 03:49 PM #42
Re: Long Tone Arms
I don't 'get' a 14" arm and with an effective mass of 19g, how many carts will actually work with it?
July 2, 2015, 05:07 PM #43
Re: Long Tone Arms
Rob-Did you steal those lines in your avatar from me?
July 2, 2015, 07:10 PM #44
July 2, 2015, 08:52 PM #45
Re: Long Tone Arms
FWIW I asked Jaime Monroy of Pelotone, the Koetsu distributor, about this, especially with regard to the stone body cartridges. He feels the extra 5g of effective mass would be a sonic benefit for sure with the stone bodies, saying they tend to prefer higher mass arms.
Brian Walsh
Music Direct
July 2, 2015, 11:50 PM #46
- Mar 2014
- Chicago
- 1,234
July 3, 2015, 02:27 AM #47
August 26, 2018, 07:06 AM #48
Re: Long Tone Arms
new old 12 inch tonearm onto the TW Acustik table. SME 3012-R aka 1981 - believe the hype, this is one super natural sounding tonearm.
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
August 26, 2018, 11:17 AM #49Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
Tom, you're not in the minority at least when it comes to 'logical thinking' !
Streamer selection
