Results 1 to 24 of 24
Thread: KT-150's in Conrad Johnson amps?
December 28, 2014, 01:55 PM #1
A brave soul from the Audiogon forum mentioned he swapped in KT-150's into his Conrad-Johnson Premier Twelve mono amps. I know one user is not enough of a sample but I am very curious.
Here is the quote:
"Call me a rebel CJ told me flat out NO, but I just replaced the kt120's in my CJ Premier 12's with kt150's, 60 hours in no issues, been monitoring the transformers to see if they get hot, no issues. the sonic difference is astounding in my system. I have had these amps for 18 years, and have run 3 brands of 6550's, 3 brands of kt88's, for almost 3 years kt120's. I switched to kt120's because of better bass and better dynamics, but I always felt they brought a little touch of electronic edge, I didn't know if that was coming from somewhere else in the chain. Back to the 150's, the sound is so dramatically better, I will never go back unless my amps blow up or I do. Dynamics like nothing I have ever heard, no grain or edge, best bass, best and deepest soundstage ever and most musical"Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 28, 2014, 02:19 PM #2
Re: KT-150's in Conrad Johnson amps?
Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
December 28, 2014, 02:24 PM #3
Some people claim they hear an 'edge' with KT-120 tubes. I think the KT-120s are an improvement over currently available 6550/KT-88 tubes (and no, I haven't heard some of the Chinese KT-88s that some people are paying big money for. I don't shop at WalMart and I don't buy Chinese tubes).
December 28, 2014, 02:44 PM #4
December 28, 2014, 02:49 PM #5
December 28, 2014, 03:09 PM #6
Cheap amp stands, unfortunately. With all my gear, I keep moving stuff around. I know that I need to focus on isolation and cables. I'm not getting the most from my gear. I truly need a great rack too. When I start to get some funds up, it ends up going to more gear and not the finishing touches needed.
December 28, 2014, 04:05 PM #7
December 28, 2014, 05:01 PM #8
December 28, 2014, 05:12 PM #9
So how much does an SRA Ohio Class XL+2 base cost?
December 28, 2014, 05:24 PM #10
$4K each and are calibrated to your amps. Prices may have gone up since I had my Burmester monos with these stands.
"Each Ohio Class XL+² is hand built and because of the different parameters involved can range in price from about $1,000 each to as much as $8,000 each"
http://www.tonepublications.com/revi...ent-platforms/Last edited by joeinid; December 28, 2014 at 05:28 PM.
December 28, 2014, 05:54 PM #11
On the left under the Doshi is the less expensive SRA Isobase; under the Classic Direct is the Ohio Class XL+2 base. The Ohio Class base is good down to 0.5 Hz.
DSC_0024.JPGMyles B. Astor, Senior Editor, PF, www.positive-feedback.com
December 28, 2014, 06:03 PM #12
December 28, 2014, 06:21 PM #13
I should have kept my bases and just had them recalibrated.
December 28, 2014, 06:29 PM #14
December 28, 2014, 06:46 PM #15
- Aug 2013
- 398
Joe,
I am with Myles on this one. I do not have the SRA Ohio Class bases, though i am told by many they are stupendous. In my case, i use HRS M3 base with 6 HRS nimbus couplers and 3 HRS large DPX (double thickness) damping plates on top plus an Artesania damping plate. I also use 2 EAT tube dampers. Basically an 'isolation sandwich'...and it really improved the solidity of the sound of the GAT (a lot), also stilled the images and providing a much 'stronger signal' in terms of again that solidity.
One man's experience.Speaker: Wilson Audio XLF + Velodyne DD18+
Source: Zanden 4-Box Digital
Amp: Robert Koda K15EX + Gryphon Mephisto Stereo
__________________________________
Cable: TA Opus (Gen5) + Sablon Audio Prince (Orange)
Power: 7 Dedicated Lines Furutech + Torus AVR 16 + Burmester 948 + NordostQX4
Isolation: Under: SRA+HRS+Stillpoints+Auralex Top: HRS+Artesania+Entreq+EAT+90kg Mass
Ground/Shield: Tripoint Troy Sig & Thor + Entreq Atlantis / Receivus +Everest+Wrap
Room/Tube: Stillpoints Apertures / Amperex + Mullard
Headphone Setup: Sennheiser 650 + Arcam rHead + Apogee Groove
December 28, 2014, 07:36 PM #16
December 28, 2014, 07:48 PM #17
December 28, 2014, 08:54 PM #18
Duh, of course. I just forgot because ordered my EAT tubes without the dampers because the rings were incompatible with my Doshi phono section.
May 4, 2015, 07:22 AM #19
- Aug 2013
- 398
Wow...its been a while since i was on this forum and thread! Glad to hear people are enjoying EAT tube dampers!
May 4, 2015, 08:05 AM #20
Hi Lloyd!
Anything new in your system?
May 4, 2015, 09:23 AM #21
- Aug 2013
- 398
Hi Myles, great to hear from you. I will visit here more often...been quiet lately. Yes, since you and i last spoke, i have a few things:
- 2nd hand Burmester 948 Power Conditioner. At the recommendation of a few manufacturers who personally own them...i got the opportunity and am pleased to have done so.
- Transparent Audio RefMM (MM2) jumpers linking the backside of the Wilson X1s (which currently use a thick copper plate). Adding the jumpers made a big improvement in clarity, particularly bass delineation and keeping pace with details during deep house music. I was pleased to find a fellow X1 owner also tried jumpers and has found similar benefits.
Going forward, i am hoping to work with a manufacturer who owns Alexandrias as his reference on further isolating these speakers from vibration. Stay tuned!Speaker: Wilson Audio XLF + Velodyne DD18+
May 4, 2015, 09:24 AM #22
- Aug 2013
- 398
May 4, 2015, 11:03 AM #23
I also find that the KT-120's sound a little less warm than the KT-88's in my Ray Lumley M-100 mono blocks but they have better bass and dynamics. I would be afraid to try the KT-150's in my amps as the transformers would be difficult to replace should something happen and the amps are relatively rare.
I too monitored the temp of the transformers with a heat gun when I first tried them out and found a negligible increase in temperature over the KT-88. However, as they were not designed for KT-120 I think I will stay away from KT-150. You are a braver soul than I.Main 2ch/HT:Acoustat 2+2,Axiom EP500,Ray Lumley M-100, Bedini BA-803,Threshold T3,JRDG Consumate Phono, Lenco L75, ZYX Universe cart,Oppo BDP 95(transport), Calyx Femto DAC,Bryston BDP-2,Pioneer F-91 tuner,Studer A807 r2r,Consonance d-Linear15 power filter, DVDO Matrix 4x4,Mitsubishi HC-5 projector, Audience Au24e and LectraLine Xe cables,Cullen Power Distribution Box with upgraded cable
Bedroom 2ch/HT:Tetra 406, Forte model2pre,Forte model3amp,TeacUD503,Faroudja DV1000,PioneerCLD-97 ld player,Thorens TD-146,PioneerTX-9800,Mitsubishi HC5 projector,Tetra Artet cables
May 4, 2015, 04:18 PM #24
Hi Albert,
I have not tried the KT-150 in my ARTsa Stereo amp yet. I have to believe there is enough juice available for them to work. It's still $900-1000 to buy a set. I may order a set after the summer for the ARTsa. The KT-150 in my Jolida is outstanding for the money. I expect CJ to update their line sometime but think I'll be out of luck with an official upgrade. It's no big deal really, my CJ gear is amazing already.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
Clarisys Arrives at Puur...
