Results 1 to 13 of 13
December 19, 2014, 01:52 PM #1
Any members here own a CJ Classic Sixty EL-34 amp?
or even the Classic Sixty SE with KT-120's? How do like the way it sounds? Can you describe a little of what you hear and what preamp you are using?
Specifications for Classic Sixty and Classic Sixty SE
Power:
60 watts per channel from 30 Hz to 15 KHz at no more than 1.5 % THD, both channels driven into 4 ohms (also available connected for 8 or 16 ohm loads)
Sensitivity: 0.7 V to rated power
Frequency Response (at 10 watts): 20 Hz to 20 kHz, +/- .3 dB
Hum and Noise: 96 dB below rated power
Input Impedance: 100 kOhms
Tube Complement: 1 x 6189, 2 x 6922, 4 x EL34 (Classic Sixty), 4 x KT120 (Classic Sixty SE)
Dimensions: 13.25D x 17.375W x 6.625H inches
Weight: 41 Lbs.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 19, 2014, 03:43 PM #2
Re: Any members here own a CJ Classic Sixty EL-34 amp?
Uh oh !!!
Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
December 19, 2014, 03:46 PM #3Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 19, 2014, 05:20 PM #4
Joe,
I owned an MV-55 that was the precursor to the MV-60 & Classic Sixty. My understanding is that they really refined the amp along the way through the various models that followed the MV-55. The MV-55 was beautiful sounding!....but had a limit that I could not live with. It played superbly with several different pairs of loudspeakers at Mid-level volumes (70-85db). I do almost 90% of my listening well below that window and 10% above that range. The MV-55 just didn't have the detail and resolution nor punch at the lower level volumes (58db-70db) and it started to get loose in the bass around 85db. With anything above 85db it lost steam really quick. I believe the advances in the MV-60 and Classic addressed the loose base issue?
I ended up finding that solid state amps do better for my kind of listening so that's where I've headed for now. However, that middle range for volume with the MV-55 was glorious and addictive!
Have fun!Avanti Audio
December 19, 2014, 05:47 PM #5
Thanks Mike. I had the MV-60, bought used on Audiogon. It was a little more beat up than I was told but sounded nice. I am thinking the new Classic Sixty (EL-34) for fun, not critical listening. I love my CJ gear and thought this might be nice.
I have been recommended a Primaluna HP with EL-34's also. That may seem more logical because of auto bias and more protections built into the amp, plus a possibly longer tube life. I'm still thinking.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 19, 2014, 07:20 PM #6
Joe, I haven't heard CJ gear but the PrimaLuna HP gear I highly recommend, as with the true bypass in the integrated you can also use any pre-amp with it & that has made my mind up that I will never buy another integrated without this capability. I am really missing my Dialogue HP, they punch way above their weight.
December 19, 2014, 07:44 PM #7
Thanks Kev !
December 19, 2014, 08:25 PM #8
Joe, Joe, Joe
You have the ART monoblocks, ART stereo amp and now looking for cj baby brother.
I love it
If you ever move those ART monos, give me first dibsSource: Technics SP10mk3 - Thales Simplicity II, TW Raven AC-3 - Graham Phantom, SME 3012-R, Exclusive P3,,Linn LP12 - Naim ARO
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
December 19, 2014, 08:36 PM #9
December 20, 2014, 12:56 AM #10
I like to hear the CJ on my system one day .
Paul
December 20, 2014, 01:01 AM #11
Joe I thought you sold MC275's No ?
Paul
December 20, 2014, 01:45 AM #12
December 20, 2014, 05:37 AM #13
Did you get my forwarded email?
Same some powder for the 250s or the other thing if you act fast. HahahahahahahaNORMAN
Congratulations on the Borresen X1 acquisition. Did you buy the X1 to replace something else? If so, what? Audio Group Denmark design and build all speaker drivers (cones and ribbon)...
Borresen Acoustics Loudspeakers
