Thread: Timbernation Rules
January 21, 2020, 04:20 PM #101
- May 2013
- 3,242
Re: Timbernation Rules
The tallest tube in both the DAC and the preamp are 7" so I've got an inch clearance and more would be better but haven't had an issue yet. It does limit which aftermarket footers can be used though. I would get at least two with 10" spacing.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
January 22, 2020, 12:13 PM #102
Thank you Jack. I'm still on the fence about the 8 inch versus 10 inch top space.
Avanti Audio
October 4, 2022, 07:41 PM #103
Just received my this week. I'm going to be doing a video review of it.
October 5, 2022, 09:53 AM #104
- Feb 2016
- west Michigan
- 713
Beautiful. Congrats
My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
October 5, 2022, 03:06 PM #105
Beautiful Racks, congratulation.
October 5, 2022, 03:45 PM #106
- Oct 2013
- Sacramento
- 1,120
I found a local builder who made me two racks from California walnut (Claro). They are gorgeous. Glued and screwed with flat plugs.
To protect the wood from tube amp heat I made heat shields using Aramid insulation sandwiched between the shelf bottom and aluminum flashing. The Aramid material is rated to 600 degrees. The shield is under the second shelf from the bottom and is invisible from any normal position.
This does not solve the ventilation problem for the equipment. It only protects the wood and whatever finish is on it. Of course after doing that for both racks I went to solid state in one system and moved the tube amp to a stand between the speakers in the other system.
McMaster-CarrContributor to stereotimes.com
May 30, 2023, 01:56 PM #107
- Jan 2015
- 6
I just purchased 2 racks from Timbernation and must say they are works of art. The fit and finish is tremendous and their owners were a pleasure to deal with. I highly recommend their racks.
May 30, 2023, 07:26 PM #1082chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
Altaira or Gemini CGS on...
