Thread: What cartridges are you using?
March 1, 2018, 08:45 PM #201
Re: What cartridges are you using?
The Cadenza Bronze (which I currently use) has a touch of warmth with excellent tracking ability, while the Kiseki PH is considered a step up in performance but with an even warmer tonal balance. Depending upon the rest of your system and personal preferences one might be a better suited upgrade to your system than the other, but both cartridges you're considering are superb performers. Another model you may want to consider would be the recently released Ortofon Windfeld Ti.
March 1, 2018, 09:06 PM #202
My new set up is a Clearaudio Ovation with a Universal arm - the Lyra Delos was a carry over from my prior VPI Classic 3 with JMW 3D arm (it sounded better to me in that set up, but I really didn't like the 3D arm). I have an Esoteric E-03 phono pre and Harbeth 30.1 speakers. In the new set up the Lyra is tracking extremely well, is transparent, but I would say it's a touch on the dry side (analytical rather than warm - technical rather than involving/musical). I'm also not particularly impressed with the soundstage. I largely attribute that to my McIntosh MA6600 Integrated which is SS. So I have decided to plunge into tubes and the McIntosh will be replaced with a PrimaLuna Dialogue Premium HP Integrated on Monday - everything else will stay the same. At that point, and after the PrimaLuna breaks in, I'll be in a better position to judge the Lyra. Question then will be whether or not the Cadenza Bronze or Kiseki PH will cause everything to lurch too far to the warm side. I have also been considering the new Windfeld Ti. This is all done somewhat blind as I have no real analog dealers up here where I live in the Rockies - and its impossible to get a loan to try one out on my rig in any event. So any advice given the road I'm heading down would be most appreciated.
March 1, 2018, 09:44 PM #203
I think your plan is a sound one, since the switch of your electronics to the PL is likely to significantly impact the balance of your system. Take it slowly to make valid judgements before moving ahead with a new cartridge if you still deem it necessary. I tend to agree with you about the Lyra's balance but it is system dependent and a subjective call. I believe any of the three cartridges you're considering would be a step up but selecting the best one for your needs can be difficult without an audition. Not many of us are in a position of getting demo cartridges to try out without purchasing them, while other components are more commonly loaned by local dealers. Good luck and let us know how it works out with your new PL!
March 1, 2018, 09:49 PM #204
Audio Bill: Thanks, the process is part of the fun. I have lots of time and will take it slow. I'll let you know where I land. Thanks for the guidance.
March 2, 2018, 05:23 AM #205
- Jan 2017
- Leyden
- 596
Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
March 3, 2018, 05:02 AM #206
I am also using the Cadenza Bronze right now and am happy with it. Yet, I am also pondering over upgrade possibilities.
Here’s a list of carts I find interesting:
- Transfiguration Proteus (might be a tad too cold for my liking)
- Transfiguration Phoenix S (not sure whether it would be an upgrade to the CB)
- Dynavector Te Kaitora Rua (might be too soft)
- Benz Micro SLR Gullwing (older cart, but still great)
- Ortofon Winfield Ti (might not have the slightly warm touch of the CB)
Any views on those alternatives?
March 3, 2018, 10:03 AM #207
I don't have any first hand experience with the Transfigurations but hear good reports on them. I wouldn't consider the Dynavector TKR to be an upgrade from the CB. If I was looking to upgrade from my CB at this point I'd be looking at the Kiseki PH or possibly the Windfeld Ti. Some of the new top models from Grado are reported to be exceptional.
One aspect of the CB that I continue to be amazed by is its absolute silence in the groove. Once I had it properly aligned (which is particularly critical with its Replicant stylus profile) most of the surface noise I experienced on my most played vinyl with other cartridges just disappeared completely. When I initially lowered the stylus and turned up the volume before the music started I thought I must have missed the lead in groove due to the silence I experienced. Unless I go with the Windfeld Ti which also uses Ortofon's Replicant stylus I'd be afraid that I'd lose the black background that I get with the CB.
March 3, 2018, 11:07 AM #208
Still running an Ortofon Cadenza Bronze myself. Absolutely love it.
Also run a Miyajima Zero Mono on a different VPI arm wand for my older mono record listening.
Given my current setup these two cartridges are the perfect match for me. Both are amazing trackers / tracers and like audio.bill says, exceptionally quiet in the groove. The dynamics, detail and timbre that these two carts are able to produce are "just right" to my ears.Avanti Audio
March 3, 2018, 12:05 PM #209
Today's cartridge Benz Gullwing....
038.JPGDealer / Manufacture Disclosure:
Jeff Whitlock
A/V Solutions / Unity Audio Design
www.avsolutionsca.com
March 3, 2018, 01:05 PM #210
Sweet pics, Jeff.
Lumin T2
Gryphon Diablo 333
Magico A3 w/ A-Pods
AudioQuest Hurricane HC
HRS E1
April 25, 2018, 10:45 AM #211
I'm currently using the Lyra Helikon Stereo and Mono Cartridges. I love the both as they have given me many years of listening pleasure.
With that being said I'm looking to upgrade the Helikon Stereo. So far on my short list are the Ortofon Cadenza Black and Bronze cartridges.Paul
Tape Deck Otari 5050B II2
Music Server: Aurender N100H
April 25, 2018, 12:17 PM #212
The Cadenza Black, Bronze are great choices, also the Blue is nice and wouldn't rule out......all three have there own unique flavor and depends what your after. A few others to consider would be the Lyra Delos or Kleos, also the Kiseki Purple Heart or Kiseki Blue......the Blue gets over looked often because of the popularity of the Purple but shouldn't, the Blue is a fantastic cartridge also. The AMG Teatro cartridge which may not be as popular as the other cartridges mentioned as its AMG's only cartridge and paired more often with other tables then VPI but its also a nice player with the HRX. All the cartridges mentioned I own along with the HRX table and all the cartridges are in rotation often along with a few others......the flip side to all this is the phono stage side of things, something that shouldn't be over looked if you want to realize the full potential from any of these cartridges.....
Jeff Whitlock
April 25, 2018, 02:21 PM #213
Jeff - Very helpful post with your perspectives on several different contenders, thanks for sharing! I took a look at your site and noticed you're also a dealer for Soundsmith cartridges and would appreciate your thoughts on how their Paua for example compares. TIA!
April 25, 2018, 02:37 PM #214
Paul
April 25, 2018, 02:45 PM #215
The Paua is a fine contender, its not a cartridge that will high light one particular area more than another, very balance from top to bottom, another that deserves a good phono stage. A great feature they can be rebuilt for reasonable cost compared to others. One thing to note is many of these cartridge mentioned can be fantastic however the phono stage choice is a very important piece of the puzzle IMO.....I typically build around the phono stage, get that part right and you would be surprised in the performance of the many more affordable cartridges that many shy away from! If its a one time buy in and not planning to spend for awhile then I would rather spend on a great phono & good cartridge vs a great cartridge & good phono. As always YMMV.
Jeff Whitlock
April 25, 2018, 03:23 PM #216
Paul.....as mentioned briefly above the SoundSmith's are nice and very capable cartridges, so are the Grado's.....I can't tell you one betters the other that would be your (opinion) decision as it comes down to what your after sound wise, they do differ though. Having the availability of many fine cartridges in the market makes it difficult if your plans are just owning one or two carts.....
Jeff Whitlock
April 25, 2018, 05:10 PM #217Paul
April 26, 2018, 12:30 AM #218
Jeff: You’ve focused on the cartridges I’ve been considering to replace my Delos - which is a fine cartridge but I’ve got the itch. You can see the rest of my system in my signature and my phono pre is an Esoteric E-03. So my question is, what would you recommend to go with the Esoteric?
Clearaudio Ovation turntable/Clearaudio Universal tonearm/Ortofon Cadenza Bronze/Esoteric E-03; Apple Air/Ayre QB-9 DSD; McIntosh MCD500; Pioneer RT-909 reel to reel; PrimaLuna DiaLogue Premium HP Integrated Amplifier; Harbeth 30.1 Monitors; REL S/5 SHO; Shunyata Venom PS8 Power Distributor, Venom Defender, Venom HC and Venom 3 PCs; Cardas Clear USB Cable; WireWorld Silver Eclipse 7 ICs and speaker cables; Steve Blinn Designs Rack; Mapleshade Platform; KLAUDiO RCM.
April 26, 2018, 02:50 AM #219
With out knowing what your after sound wise and just reading from your signature of gear I would consider the Benz Gullwing, works well with your table, arm and will do so with the E-03.....there are other cartridge too but consider one's with a slightly lower output. The 66dB of gain from the E-03 is slightly high for the 0.6mV Delos.
Jeff Whitlock
April 26, 2018, 09:24 AM #220
Thanks Jeff. To answer your question imprecisely I love the detail, black backgrounds and transparency of the Delos but I find it a bit clinical. I don’t want colored but more musically involving sound and tight bass. From my other components you can see I’m a midrange maniac. I also look for great imaging. So, as always, I guess I want it all. I’d love to try a Micro Benz but I can’t seem to find one. Can you recommend sources or alternatives?
April 26, 2018, 12:49 PM #221
April 26, 2018, 01:29 PM #222
April 26, 2018, 01:33 PM #223
Hi Moby, that is a little bit the thing, they’re not easy to find. As I live in Europe, it is a bit easier here.
But if I remember correctly there was a dealer on the Sharks forum who still had stock. I’ll try to locate that posting for you.
April 26, 2018, 08:26 PM #224
Thank you!
April 28, 2018, 12:58 PM #225
Today's cartridge Kiseki Blue
kisekibluestogi.JPGDealer / Manufacture Disclosure:
Jeff Whitlock
April 28, 2018, 06:13 PM #226
Well, I’ve pulled the trigger. I’ve ordered a Soundsmith Paua MKII - a low compliance low output cartridge that matches well with my Tonearm and Phono Pre. It has received tremendous reviews (including by people I know and trust) and can be rebuilt for less than 20% of its retail price. Add to that the fact that the seller credited me with virtually the full amount I paid for my Lyra Delos several years ago in a trade-in and this became a no brainer. Hopefully my extended period of GAS since the beginning of the year is now satisfied.
April 28, 2018, 06:37 PM #227
The Paua is nice, with its 0.4mV output it should be better suited then the 0.6mV delos with the E-03....congrats & enjoy!
Jeff Whitlock
April 28, 2018, 08:47 PM #228
April 28, 2018, 08:47 PM #229
deleted - post was duplicated.
April 29, 2018, 01:40 AM #230
Congrats, Soundsmith is a great choice.
Did you get a chance to hear it in your system before deciding?
April 29, 2018, 09:05 AM #231
Unfortunately not. Since I live in the Rockies, far from an urban area like NYC or LA that has lots of brick and mortar stereo stores, I often have to buy audio equipment blind without audition and based solely on advice and reviews. I'm surprised, frankly, that it works out as well as it does. I'll give a full report once it arrives and has been burned in. The upside is that yesterday I got to see two mountain lions on a neighbor's back deck and a magnificent bald eagle by a local pond. That is stuff you can't buy!
April 29, 2018, 09:11 AM #232
Duplicate post deleted
April 29, 2018, 02:23 PM #233
Today's cartridge SPU Royal N
royal n.JPGDealer / Manufacture Disclosure:
Jeff Whitlock
April 29, 2018, 06:06 PM #234
May 29, 2018, 07:07 PM #235
- May 2018
- Adelaide, South Australia.
- 39
At the moment I have an Audio Technica AT-OC9/III on my Rock, a Shure V15 type III/jico SAS on the Luxman and a Bellex HOMC on the Planar 3.
June 6, 2018, 06:33 PM #236
Today's cartridge GFS......
amggfs.JPGDealer / Manufacture Disclosure:
Jeff Whitlock
July 30, 2018, 08:05 PM #237
- Aug 2014
- Fleming Island, FL
- 77
Windfeld TiGryphon Diablo 300 w/DAC, Rockport Mira II, Wolf Audio Alpha 3SX, DSA Phono 2, Origin Live Sovereign MK3, Enterprise MK4, Conqueror MK4, SoundSmith Hyperion, Miyajima Zero
July 31, 2018, 12:07 PM #238
Koetsu Urushi Vermillon and Rosewood.
EMT XSD15. Ortofon 2M Black.
Envoyé de mon iPhone en utilisant TapatalkShindo, Nagra, Electrocompaniet, Harbeth, AMR, Mc Intosh, Auditorium 23, Rega, DeVore, JC Verdier, WireWorld, Kimber
October 5, 2018, 11:41 PM #239
After using SPU Classic and Royal I set up my Dynavector XV-1S onto the SME 3012-R. Preferring this a lot more.
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
October 6, 2018, 11:18 AM #240
October 7, 2018, 12:01 AM #241
EQ: DEQX HDP-4
October 9, 2018, 03:14 AM #242
October 9, 2018, 07:38 AM #243
EQ: DEQX HDP-4
October 10, 2018, 03:20 AM #244
October 20, 2018, 01:02 AM #245
Sorry bad typo I meant EC188 tubes.
October 29, 2018, 01:59 PM #246
- Nov 2014
- 227
Shelter Harmony still surprising and growing on me in the main rig (over a year later); brand new Shelter Accord doing awesome settling into the headphone rig. Shelter may have become my favorite cartridge maker now?
The stylus shanks are also VERY tiny and use no glue on the aluminum cantilevers, so they seem to be a lot easier to keep clean than large shanks with glue.
March 9, 2019, 01:17 AM #247
- Jun 2016
- 62
I have Ortofon Bronze and Goldring 1042. Liking the Gold a bit better, but not by much.
March 9, 2019, 01:28 AM #248
Anyone tried the EMT JSD P6.0?
March 11, 2019, 11:54 PM #249
- Mar 2019
- 94
Lyra Kleos, replaced my Koetsu Urushi Sky Blue...way more resolution and far more neutral. Hearing things that I hadn’t noticed before on the record, which says a lot to me.
March 12, 2019, 01:17 PM #250
- Sep 2015
- 60
Third from the Lyra line up. Delos first, Titan i and now this on my Schroeder reference;-
Altaira or Gemini CGS on...
