Results 51 to 57 of 57
Thread: My P3ESR's....
January 30, 2017, 10:57 PM #51
Re: My P3ESR's....
I got P3s three weeks ago. Indeed, remarkable speakers. Mine are on Sanus stands filled with sand and blue tack between the plates and speakers.
When I listen to the music I pull them on the carpet into extreme near field listening, bring the chair in between, toe them in and put two blankets from sofa on TV. One really needs to hear them to understand why they sound so special.
...I also ordered a pair of REL T Zeros and can't wait to hear if this will be a British connection made in heaven.
January 31, 2017, 12:10 AM #52
Re: My P3ESR's....
Very nice, glad you are loving the P3's
February 2, 2017, 12:03 AM #53
February 3, 2017, 05:28 PM #54
Re: My P3ESR's....
Just a quick update from my side. I've received T Zeros two days ago and been running them in 24h/day. I am not sure if this was illusion, but it seems they really needed some running in time as the bass appears to be cleaner and tighter now.
I was doubting whether these small subs (-6dB @38Hz) would work well with P3s. Well, let me tell you right now, T Zeros are a great complement to P3s. They really impressed me and made P3s sound much larger (even though they sound larger than they appear without subs too).
There is no marks on the crossover knobs on the subwoofer, but there are 40 points between 30Hz and 120Hz. I set them up on 12th point from 30Hz up. If this 90Hz scale on the crossover is linear, I'd say the 12th point should be some 57Hz.
There is a still a bit of questioning myself if I should have gone with two T5s instead of T Zero. T5 has an 8" driver, and is rated -6dB @32Hz. Yet, I was not sure if these would integrate as good as T Zeros and the footprint in a bit larger (my wife really digs those small T Zeros).
February 3, 2017, 05:38 PM #55
Re: My P3ESR's....
Excellent! Glad you are happy.
February 4, 2017, 11:55 AM #56
Re: My P3ESR's....
Who couldn't be with these little miracles.
Here is a photo with the subs. I put the crossover a few clicks lower and turned the gain a bit up. While I said the integration was easy, obviously there's always room for some improvement too.
This is the final setup as of now.
February 4, 2017, 11:59 AM #57
Re: My P3ESR's....
Wow, everything matches perfectly. Well done!
The new nucleus one is introduced. For just 499 dollar you have a roon server. Does anyone already have experience with it?
Nucleus one
