Results 1 to 30 of 30
  1. #1
    Join Date
    Sep 2013
    Tulsa, Oklahoma
    Posts
    58
    Dynavector XV-1T vs XV-1S
    From another thread there was interest in my experience comparing the Dynavector XV-1T to the XV-1S. So I started this thread to not detract from the other thread's initial topics.
    I just received my XV-1T yesterday and have only about 5 hours on it after set up. It drops right in for the XV-1T (same SRA, same overhang, same AS) but the VTF needs significant adjustment as the XV-1T is 0.6 grams lighter than the XV-1s. Set up was using a Mint Protractor specific for my tonearm. Associated equipment is TW Acustic Raven AC turntable, TW Acustic TW 10.5 tonearm, ARC Ref Phono 2se, ARC Ref 5 se, and ARC Ref 250 mono amps. Loudspeakers are Avalon Eidolon Diamonds and cables are Cardas Golden Reference.
    I set the VTF at 2.005 g for the XV-1t and used 1.975g for the XV-1s. As the XV-1t breaks in I expect that I will decrease the VTF a bit. Loading on the XV-1t was set at both 200 ohms and 500 ohms on the Ref Phono 2 Se and was 100 ohms on the XV-1s (XV-1t internal impedance is 24 ohms vs 6 ohms for the XV-1s). At this point I'm not sure which load I like better for the XV-1t, the 200 or 500 ohm setting. As the cart breaks in, I am betting it will be the 500 ohm setting.
    Now on to the comparison, category by category:
    Soundstaging: Clear winner is the XV-1T, much more refined and has fully fleshed out 3D images inside of a 3D soundstage. There is much more air around the images with the XV-1T. Soundstage width and depth were more expansive with the XV-1T.
    Noisefloor: Both the XV-1T and XV-1s are champs here. Both have very low noise floors and surface noise is all but inaudible from the listening position. I found no discernible difference in my system when comparing the output of both carts (XV-1T 0.35 mV, XV-1S 0.30 mV).
    Dynamics: slight edge to the XV-1T over the XV-1s. Macro - both very similar; micro - slight edge to XV-1T
    Musicality: Pretty much a toss up as both carts are typical Dynavector - a chameleon in that they do everything quite well. Both carts have a nice sweet musical tone to them.
    Bass: Clear winner is the XV-1T; bass much faster. PRAT better. Bass extension similar in the XV-1s, but much tighter and focussed.
    Detail retrieval: Again the clear winner is the XV-1T. Much more texture and detail than the XV-1s. Subtle details I had never heard before were coming through on several of my 'go-to' records. In fact, it was almost spooky the amount of times I was surprised to hear subtleties I had not heard before.
    So now the $4K question: Is the XV-1T worth spending $4K more on than the XV-1s? I would say it depends. If you are an analog guy that plays 95% vinyl and 5% digital or streaming, and your system warrants a megabuck cart, then the XV-1T is absolutely worth the investment and worth the jump from the XV-1s. I personally have spent more money in other areas of my system and not received the improved qualities mentioned above. All that being said, the XV-1s is a FANTASTIC cart and XV-1s owners should be very happy and proud of that cart. At $5500, its a 'steal' in these days of rapidly escalating prices for audio carts. For those who are considering an XV-1T, it's a world class cart that will likely be state of the art for several years along with other carts such as the Ortofon Anna, Zyx Universe II, Clearaudio Goldfinger, and Air Tight PC Supreme to name a few. As the XV-1T breaks in, I will report back on its changes and improvements.
  2. #2
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Re: Dynavector XV-1T vs XV-1S
    Thanks for such a detailed update! With performance that good after only five hours of break in, just wait until you get about fifty hours on it. Enjoy the tunes with your new cartridge and I look forward to your further impressions in due time.
  3. #3
    Senior Member
    Join Date
    Apr 2013
    NJ
    Posts
    2,427
    nice write up... thanks!!!
    Steve
    TUBES & VINYL
    Is there anything else?
    Rega/Ortofon/Viva 300b/KR
    Music Reference 2A3
    Altec/JBL
  4. #4
    Nice write up. I love my XV-1t.
    Source: TechDAS AF1, CA Master Innovation, UHA Phase 12-OPS-Vari-EQ RTR, PS Audio PW Mk 2 Dac & Trans Carts: Koetsu Coralstone & Tiger Eye, Dynavector XV-1t, Lyra Olympos Mono Amps: Allnic H5000 DHT phono, Pass XS pre, Pass XS-150 dual chassis mono's Speakers: Wilson Alexandria X-2.2 Cables: Nordost Odin PC, IC, Speaker Signal Grounding: Entreq Silver Tellus (2) and Atlantis Ground wires Isolation: Stillpoints Ultra series, Table Stable TS-140
  5. #5
    Quote Originally Posted by audio.bill View Post
    +1
    Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
  6. #6
    Senior Member
    Join Date
    May 2013
    Sydney
    Posts
    1,782
    Hi Phil
    Thanks for your thoughts. I am on my third XV-1s and have been thinking of stepping up to the XV-1t when time for a rebuild.
    If the xv-1t has better sounding staging, wow it must be good as the XV-1s is sensational with soundstaging. I am very interested in hearing about the bass after 50 hours. That slightly tubby bass the XV-1s has, in my system, is slightly off the mark, especially in comparison to my Lyra and have been wondering if the XV-1t will bring that or still similar as i love the dyna tone it 3d depth it brings.
    A bit more detail, extension and tighter/faster bass ultimately would be an ideal foil for the Lyra.
    Please update us after 50 of so hours after the suspension etc jells into place.
    cheers
    EQ: ​DEQX HDP-4
    Speakers: Wilson Maxx3
  7. #7
    Join Date
    Sep 2013
    Tulsa, Oklahoma
    Posts
    58
    I'll by happy to update at around 50 hours. Been listening all day - the XV-1T keeps getting better and better. I'm really preferring the 200 ohm load at this time. I'm guessing I'm approaching 15-20 hours......
  8. #8
    Quote Originally Posted by XV-1 View Post
    Hi Phil
    cheers
    Of all the words I would use to describe the bass of the XV-1s cartridge, "tubby" wouldn't be one of them. It doesn't plumb the depths quite as deep as some other cartridges, but what it does, it does damn good IMO. I think it sounds 'right' when reproducing standup acoustic bass as well as kick drums, the left hand register of the piano, organ, and electric bass (listen to the Speakers Corner reissue of Lou Reed's Take a Walk on the Wild Side). The XV-1s doesn't call attention to itself in the bass frequencies which I think is a good thing.
  9. #9
    Join Date
    Sep 2013
    Tulsa, Oklahoma
    Posts
    58
    Quote Originally Posted by mep View Post
    i agree mep, but different systems reveal different findings with some. My bass with the XV-1s was very extended and deep, but at times, seemed a bit 'muddy' despite its impact and extension. The 'muddiness' sometimes made subtle images in the back of the soundstage a bit hard to discern, especially on complex passages. With the XV-1t, this is certainly not an issue at all in my system and room now. But again, its performance, as well as many other components, are system and room dependent, especially when it comes to bass response.
    Phil
  10. #10
    Interesting Phil. I'm using the XV-1s mounted on an SME 312s arm on a SP-10 MKII table in a custom plinth. I'm using a Krell KPE Ref phono stage with the loading set at 100 ohms. In my system and in my room, the bass is very clean and would never be considered as tubby or muddy. I appreciate that your new cartridge is even better than the XV-1s and it should be. I would love to hear it.
  11. #11
    I can describe XV-1t sound as the closest to well sorted tape sound I have heard on vinyl in terms of bass extension, articulation and dynamics. That is not to say it is my favorite cart that I have heard, but it is very close.
  12. #12
    Join Date
    Sep 2013
    Tulsa, Oklahoma
    Posts
    58
    It might be a tubes vs solid state thing in the bass department too. I'm betting the Krell has a tight control on bass. With my previous Rowland gear I think my bass was a little better with the XV-1s too. But with the XV-1t, my bass is out of this world. Tight, palpable, focused and tuneful too.
    I had my XV-1s set at 100 ohm load too. It just sounded best there. I've heard many have increased the load to 300-500 ohms for the XV-it. I have tried both 200 and 500 and right now, to my ears, 200 is the ticket.
  13. #13
    Senior Member
    Join Date
    May 2013
    Sydney
    Posts
    1,782
    The XV-1s bass is not tubby like say a Koetsu Rosewood in absolute terms. Perhaps better wording might be IMO the xv-1 bass is like great tube amp bass - slightly spread in the bass which adds nice weight but not the last word in tightness.
    This is not a criticism, as I am on my 3rd XV-1 and have been using them for the last 13 years and I love the music the XV-1s makes. The bass is tighter on my ss phono, but the overall bass still a little round.
    In comparison to the Lyra Atlas the differences in the bass are a little more obvious.
    Cheers
    EQ: ​DEQX HDP-4
  14. #14
    What is everyone tracking their XV1S at? Remember there was a bit of controversy at one time over the best VTF setting.
  15. #15
    1.88 gm on a Durand Telos
  16. #16
    Didn't HP talk about tracking the XV1S at 2.5 gm.?
  17. #17
    I don't remember HP talking about the XV-1s. I would have to double check my tracking force, but I'm pretty sure I went with what jazdoc told me he uses.
  18. #18
    Senior Member
    Join Date
    May 2013
    Canada
    Posts
    783
    Running my XV-1S at 2.4 gr and loaded at121 ohms. Arm is parallel to the table. Using a Graham Phantom Supreme as arm.
    Dan
    The older I get the more I know how little I know!
  19. #19
    Thom Mackris of Galibier has posted extensively on this topic and I think his advice is wise
    Play with this [tracking force] first. It's something you can do at home and at little to no expense.
    You will need a scale with .01 gram sensitivity. .1 gram will not do. Cartridges of this caliber will speak with a different voice, with as little as a .05 gram change, and the rounding error in a .1 gram sensitivity scale will not give you repeatable results.
    Run the Dynavector and track it anywhere from 1.85 to 2.0 grams. IGNORE the advice about tracking at 2.5 grams. I have found in my personal cartridge (Schröder Reference and Triplanar tonearms on my turntables) has a sweet spot of about 1.87 grams. As I work my way to 1.92, the dynamics and pace suffer.
    Comments you find referencing tracking the XV-1s at 2.5 on this forum and elsewhere are ill-informed, to put it kindly. In 5 different XV-1s based setups, the median tracking force has centered in on 1.90 grams.
    The Dynavector importer agrees with me about this.
    If you surf the archives, you will find numerous posts from both myself as well as Doug Deacon on the topic. In short, you want to track on the razor's edge ... the point slightly heavier than where you mis-track and NO MORE.
    When you track at too heavy a force, not only will you lose dynamics, but the sense of pace will slow down. I kid you not.
  20. #20
    Thanks it made no sense and I wondered if the cartridge was defective, something was wrong with the setup or the cartridge didn't work with the arm being used.
  21. #21
    From Mr. Salvatore for whom I place zero faith in.
    FURTHER NOTES ON THE CORRECT TRACKING FORCE
    One of my "associates" recently sent me a note concerning the proper vertical tracking force for the this cartridge, which he feels is critical for optimization. Here it is, with some minor editing (My bold):
    "There has been some controversy generated around the tracking force required for achieving optimal sonics with the Dynavecter XV–1S cartridge. The manufacturer recommends around 2 grams, while other users, such as Harry Pearson (HP) of The Absolute Sound (TAS), claim that 2.7-2.8 grams is mandatory to realize the full potential of this cartridge. Some owners, and Michael Fremer in his review of the cartridge, boldly state that going above the manufacturer’s tracking recommendation is plain wrong, and that the Dynavecter will not perform properly.
    I have used the XV–1S for 10 months, and have experimented with set-up to a fanatical degree, and I can confidently advise that HP is absolutely correct. With my turntable (VPI HR-X/JMW 12.6), until you hit 2.7 grams of force, the cartridge lacks bass impact and midbass weight, transients are softened and high frequencies are lacking extension and total precision. Of course, the cartridge, being ultra critical about set up, must be meticulously aligned and VTA must be attended to. Furthermore, 2.7 grams of tracking only puts you in the ball park. Hopefully, the tonearm used has minute tracking force adjustability capability, since one must, by ear, finalize the tracking force setting, which in most cases is so subtle as to be unmeasureable. In conclusion...
    The Dynavecter XV -1S, tracking at the manufacturer’s recommended weight, is a fine cartridge that is euphonically colored (to wit, its errors are all of omission as opposed to commission). However, when the cartridge is meticulously set up and tracking in the range of 2.7 grams, it leaps into a new category of performance exhibiting negligible flaws with the best combination of sonic strengths that I have experienced."
    Personal Note- I heard the Dynavector XV-1S extensively in my associate's highly-revealing system, at the VTF he advises above, and I didn't hear any problems associated with an overly heavy VTF. However, all* the people I know who prefer the heavier VTF are also using the JMW 12.6 tonearm. This may be relevant, or it may not. I advise readers to experiment for themselves. There's no harm slowly increasing the tracking force to hear the results. Finally, this VTF "controversy" applies only to the XV-1S, and not the original XV-1.
    *This includes both Harry Pearson, mentioned above, and Harry Weisefeld of VPI.
    December 2007 Update
    A reader informed me that the Dynavector XV-1s cartridge requires 2.7 grams VTF on the Graham Phantom tonearm. In the past, I always assumed that only the VPI Memorial tonearms required this heavier force for optimization. Now I'm proved wrong, so I guess these two basic designs share some particular similarity. (See the Reader's Letters in the Amplifier File - Canary Reference One, for the details, and to judge credibility.)
  22. #22
    Join Date
    Sep 2013
    Tulsa, Oklahoma
    Posts
    58
    Quote Originally Posted by Myles B. Astor View Post
    I'm in the Thom Mackris camp. I've tried running the XV-1s at 2.5-2.6 grams when breaking in and after break in. On my TW 10.5 tonearm and a previous JMW 10.5 i tonearm on an Aries 3 turntable, the sound was dark, muddy and slow-paced. The treble had the life sucked out of it. When using the XV-1s, I settled on a VTF of 2.05g on the JMW 10.5i and a VTF of 1.950g on the TW 10.5. I'm guessing the XV-1t will wind up close to there too on my TW 10.5. Both of these VTF's were not close to mistracking as I couldn't get the XV-1s to mistrack at even 1.800 grams! But at VTF's below 1.925 g, the bass dropped off quite a bit and the highs became more brittle and 'washed out'. I'm sure everyone's mileage may vary, but this is just my experience with the XV-1s and now starting the adventure with the XV-1t.
  23. #23
    Senior Member
    Join Date
    May 2013
    Sydney
    Posts
    1,782
    Used to be 2 for many years. Now around 1.90 - 95 depending on tonearm, mood, summer or winter.
    EQ: ​DEQX HDP-4
  24. #24
    Join Date
    Sep 2013
    Tulsa, Oklahoma
    Posts
    58
    Well, I have around 70 hours on the XV-1t now and I thought I would report back. My current (and probably final) settings are a VTF of 1.905g, SRA of between 91-91.5 degrees, AS set at around 25% (minimal), and a load of 200 ohms.
    The first thing that comes to mind is realism. Compared to theXV-1s, the XV-1t makes everything seem so much more real in space. Especially deep into the soundstage and far laterally outside the speakers. The bass remains full and deep, yet moderately 'tighter' and faster than did the XV-1s. Dynamics have been significantly improved, both macro and micro. It appears the noise floor of the XV-1t is ever so slightly lower than the XV-1s. Overall, I remain very happy with the XV-1t purchase as a replacement for the XV-1s. Both are amazing carts, but the XV-1t is more than a few steps above. As I mentioned in an earlier post, if you are an analog guy that plays almost exclusively vinyl, the XV-1t is definitely worth investigating if you own an XV-1s and are considering a new cart. Law of diminishing returns? That will be up to each individual, but for the extra money I spent for the cart upgrade, the sonic returns far surpassed many other 'upgrades' I have done in the past.
  25. #25
    Senior Member
    Join Date
    Nov 2013
    Massachusetts
    Posts
    747
    Thanks for the update!
    Speakers: Magico M-Project w/MPods
    Amps: CAT Legend -> CAT JL7s
    Analog: Kronos Pro Limited Edition / Black Beauty tonearm / Zyx Universe Premium, Ortofon A95
    Digital: Roon->Vivaldi DAC/Upsampler
    Cables/Power: Kubala Sosna Elation ICs & SCs / Shunyata Denali 6000T & PC's / Furutech outlets
  26. #26
    Senior Member
    Join Date
    May 2013
    Sydney
    Posts
    1,782
    Plus 2, thanks for the update
    EQ: ​DEQX HDP-4
  27. #27
    Senior Member
    Join Date
    Nov 2013
    Massachusetts
    Posts
    747
    I now have a T on the way and I'll update this thread with my thoughts over the S when I get it installed and do some listening.
  28. #28
    Senior Member
    Join Date
    May 2013
    Sydney
    Posts
    1,782
    Quote Originally Posted by madfloyd View Post
    Congrats!
    XV-1t - awesome, I am envious with this superb choice
    Yes please, love to hear your thoughts after some play time.
    EQ: ​DEQX HDP-4
  29. #29
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    Congrats Ian. I've always been a huge fan of Dynavector carts and miss mine!
  30. #30
    Senior Member
    Join Date
    Apr 2013
    NJ
    Posts
    2,427
    sweet!!! congrats!!
    Steve
    TUBES & VINYL
    Music Reference 2A3
    Altec/JBL
Posting Permissions
  • You may not post replies
  • You may not edit your posts
