Results 1 to 25 of 25
April 23, 2013, 10:16 AM #1
Cancelation of ground loop noise.
Hi Guys,
Do any of you have any tricks or tweaks to cancel ground noise without using a cheater plugs.
Josh.Josh.
Cary 308T cd player, Squeezbox Touch, Sonus Faber Cremona M, REL T3 subwoofer, Conrad Johnson ET3SE preamp, Conrad Johnson Clayssic 60 SE, Fosgate Signature Phono Stage, VPI Scoutmaster II + Ortofon Cadenza Blue cartridge, PS AUDIO Dectet Power Center, VPI 16.5.
"I'll play it and tell you what it is later".
Miles Davis
April 23, 2013, 10:31 AM #2
Josh... I hope Joe & Jeff (& others) may chime in here. I have been pretty lucky so far (knock on wood). Good luck buddy!!!
__________________________________________________ _____________________________________________
Jeff
AMP: McIntosh MC402 PRE: McIntosh C2300 Digital: Gold Note DS-10 & PSU-10 EVO TURNTABLE: Dr. Feickert Blackbird PHONO STAGE: Gold Note PH-10 & PSU-10 SPEAKERS: Aerial Acoustics Model 8B’s
“The more you tighten your grip Tarkin the more star systems will slip through your fingers”
April 23, 2013, 11:41 AM #3
Disconnect everything, power cords, IC's speaker cables, etc.....start by re-connecting everything one by one until you run across the component that causes the hum.
Also is everything plugged into the same outlet?
Is the hum volume dependent, meaning when you turn the volume up does the hum get's louder or is it constant no matter what volume level you choose?Dealer / Manufacture Disclosure:
Jeff Whitlock
A/V Solutions / Unity Audio Design
www.avsolutionsca.com
April 23, 2013, 11:50 AM #4Josh.
Miles Davis
April 23, 2013, 01:35 PM #5Dealer / Manufacture Disclosure:
Jeff Whitlock
April 23, 2013, 01:56 PM #6
I have had problems before on my HT system between MC207 & Marantz pre and would get the hum sound. With many hours of hair pulling diagnostic, it turns out the the culprit was the trigger cable from the MC207 to the Pre was causing the hum..
Dewey,
"If everybody is thinking alike, then somebody isn't thinking." - George S. Patton
April 23, 2013, 02:03 PM #7Josh.
Miles Davis
April 23, 2013, 04:37 PM #8
If it's just the phono move your ground wire to a different spot.You do have a ground wire with the RCA's right?
April 23, 2013, 04:45 PM #9Josh.
Miles Davis
April 23, 2013, 04:52 PM #10
April 23, 2013, 04:55 PM #11
Welcome.jpg - - - Skroudo
André - - - Keep it simple system
Amp = Chord CPM-2600
Source = Chord One
Speakers = Acoustat 1+1s highly modified
Life without Acoustat is possible BUT senseless.
April 23, 2013, 09:29 PM #12
Sounds like it also could be in the tonearm cart connections. Try touching the back of the cart, the arm, etc. (you become the ground) ..does it quiet down ? What type of table ? Most of the time (not all) I have found that the type of hum you describe is less of an issue with the ground wire and more in the headshell/tonearm ground wire.
Also, not to state the obvious but just to be sure...Looking at the back of the cart straight on, your wires should be RED Top right, Green Bottom right, white top left, blue bottom left. I don't think that's it because miswire would net no sound in a channel...let us know on the ground TOUCHLast edited by ohbythebay; April 23, 2013 at 09:32 PM.
MAIN RIG: Equipment: Marantz SR4023 as Pre / Velleman K4040 Tube Power Amp / Yamaha M65 Power Amp / Polk Monitor 70's with Polk Sub / ClearAudio Concept table with Musical Surroundings Phonomena II Phono Stage and ClearAudio Concept MC cart /Pioneer PL500 TT with AT440MLa
Be the person your dog thinks you are...
April 24, 2013, 04:18 PM #13
Problem solved, Jeff A/V Solution was right, I had one loose connection behind my cartridge.
I want to thank you all for the help you provided.Josh.
Miles Davis
April 24, 2013, 04:25 PM #14Dealer / Manufacture Disclosure:
Jeff Whitlock
April 24, 2013, 04:27 PM #15
Josh... Glad to hear all is well again!!! Jeff is the TT guru, way to go!!!
Jeff
April 24, 2013, 04:37 PM #16
Without Jeff (A/V Sol.) we'll be swimming in the vast ocean of uncertainty.
* And am I glad to have such a great bunch of Jeff's here.~ Bob ~
"And it Stoned me to my Soul" • Van Morrison
Click ♪ Audiophile Audition
April 24, 2013, 05:01 PM #17
Josh.
Miles Davis
April 24, 2013, 08:38 PM #18
Hey ...I said it too..!!! LOL Glad Jeff helped ya out ..he is awesome !!!
April 24, 2013, 08:50 PM #19Josh.
Miles Davis
April 24, 2013, 10:37 PM #20MAIN RIG: Equipment: Marantz SR4023 as Pre / Velleman K4040 Tube Power Amp / Yamaha M65 Power Amp / Polk Monitor 70's with Polk Sub / ClearAudio Concept table with Musical Surroundings Phonomena II Phono Stage and ClearAudio Concept MC cart /Pioneer PL500 TT with AT440MLa
April 25, 2013, 12:14 AM #21"I must admit I felt a little uneasy
When she bent down to tie the laces of my shoe"
-Bob Dylan Tangled Up In Blue
“The only escape from the miseries of life are music and cats...”
― Albert Schweitzer
“A man is a success if he gets up in the morning and goes to bed at night and in between does what he wants to do.” - Bob Dylan
"When the power of love overcomes the love of power, the world will know peace.”
― Jimi Hendrix
April 25, 2013, 12:37 AM #22
Jeff, AV solution is the MAN. Enjoy!
working progress
April 25, 2013, 12:41 AM #23
Deleted
April 25, 2013, 12:41 AM #24
April 30, 2013, 11:07 PM #25
Re: Cancelation of ground loop noise.
I've had luck with my Wyred4Sound DAC2 and Integra DHC 80.3 with both my Boulder 1010 and previously with a McIntosh C2300. What I did was run a common wire from the ground terminal's intended for phono on the Integra and the preamp and the chasis of the DAC2. This resolved 90 percent of the humm noise I had. Oddly plugging everything into a McIntosh MPC1500 did absolutely nothing to resolve the issue. I found it odd since the MPC1500 is essentially a large isolation transformer. The last 10% was only obtained by using a cheater on the DAC. If I remove the ground wire between all the units, I get the humm back.
Ground loops suck.Ref System: Wilson Alexx on Stillpoint Ultras w/Base, dCS Rossini & Upsampler & Clock, Audio Research REF 160S, REF 6SE, WW Platinum Everywhere, Roon
Office System: B&W N802D2, NAD M10
Living Room System: B&W N804D, NAD M10, Velodyne DD+10
Bedroom: Dynaudio Focus 160, NAD M10, Velodyne DD+10
Looks like a great room and install!
