Results 101 to 150 of 303
September 4, 2014, 06:04 PM #101
Re: If you had to choose only ONE pair of speakers for rest of your life ...
heeere we go... another doubter they sound like sh!t on the stock feet, mine are raised 18" and angled forward slightly so they're horizontal, they've been rebuilt (Sheldon stokes). 57s have QUALITY bass, they just don't plumb the depths and the ultimate lack of sparkle on top is because: 1) your hearing acuity doesn't extend far enough or 2) you have them on stock feet and the treble is hitting your chest not your ears.
think big headphones when listening to 57's they're best suited for near field listening.
September 4, 2014, 06:17 PM #102
microstrip posted independently performed measurements of the ESL 57 which showed pretty flat on-axis frequency response from about 45 Hz to 17-18 kHz; as good or better than many touted modern speakers.
Rob
__________________________
Tascam BR-20; Technics 1506 with tape path upgrades, FM head, DeHavilland 222 tape head pre; Modwright Oppo 205 full tube mod w/LPS; Euphony Summus server, EtherRegen, HDPLEX LPS; MSB Discrete DAC (dual PS, ISLPro, balanced out); Pass Labs XP-12, XA60.8 (pair); Daedalus Audio Apollo 11’s, VMPS Larger Sub; Daedalus/Wywires, Acoustic Zen, Sablon Audio, Wireworld, Shunyata Research cables; Core Power Equi=Power;
Adona rack, Stillpoints, IsoPods, ASC, GIK Acoustics accessories
October 8, 2014, 10:50 PM #103
- Oct 2014
- 2
Based on speakers I've heard multiple times for more than an hour, I'd go with Aerial 10ts.
October 8, 2014, 11:01 PM #104
Welcome to the forum cratz2!
Thank you for joining!Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
October 8, 2014, 11:33 PM #105
- Sep 2014
- Oklahoma City
- 23
I've had lots of speakers, but my current pair might be with me the rest of my life......
Magnepan 3.7
Not that I might not buy some more to have fun with also......
November 22, 2014, 01:52 PM #106
Dynaudio C2 Platinum in Mocca Finish, just ordered a pair should have them next week and I could see keeping these as my main staple speaker. I am also with you on Magnepans, love the 3.7 but since I just bought the Dynaudios the 1.7 I have I don't think I will get rid of either. I am sure I will dabble with many other monitors over the years but those 2 are not going anywhere.
November 24, 2014, 02:35 PM #107
- Jan 2014
- Brazil
- 1
I have a stacked QUAD 57 pair I built in 1978 and still use them to this day. Never wanted to change. I built them using the Mark Levinson HQD as a model (see article on Stereophile), but my tweeter is the T1 Sequerra instead of the Decca he used. In order to play a little louder than a standard QUAD 57, I made a modification in the speakers and it seems, after 36 plus years, none of them have a had a single failure. The mod consists basically on separating the mid frequencies (around 600Hz and above) to be played by the mid panels, and the low frequencies (below 600Hz) for the bass panels. And for the frequencies below 100Hz, a subwoofer does the job. Yes, it needs 4 amplifiers (all tube, except for the subwoofer) and a high level preamp with a frequency divisor (I use passive filters) to separate the frequencies. It is more complicated than the standard power amp + speaker, but the result is incredible. Nothing can play middle frequencies like the old QUAD 57 and high frequencies like a ribbon tweeter. From time to time, I wanted a higher output level (I like jazz and classical) and have experienced quite a few dynamic speakers, only to return to my old QUADs. I use a Futterman H3aa pair (I purchsed it directly from Mr Futterman - he was building these amplifers by hand at the time - mid 80´s) to play low frequencies in the bass panels and the result is jaw dropping. Yes, I also have a pair of QUAD 63, but they never matched the old stacked QUADs.
Cheers,
November 26, 2014, 08:47 PM #108
- Nov 2014
- 83
A lot of pretty great speakers mentioned so far. Interesting to see the diversity of small and large panels, small and large dynamics, horns, and omni-directionals. MBL if you have the space to do them justice can be pretty spectacular. I heard a set of custom horns (big ones) in Hong Kong that was one of the finest speakers I've heard. Better than any production horn I've heard - but they are just so big. I think with these threads I would answer big room and small/medium room - HA - then you can give two answers. I would take the big horns in the big room simply because my preference is for SET amplifiers and I've not heard a SS amp or PP tube amp that I think I could live with. Great speakers will merely tell me more about why I don't care for those amps all that much. So a big ole horn Western Electric kind of deal would probably be it for me. Although I find them all to be generally hideous looking.
For the small/medium room I will go with Audio Note. I bought the AN J's ten years ago finding them to pretty much trounce everything in their size class. Then became a reviewer - heard pretty much everything since then and couldn't say that anything really changed my view. Although at least I heard a lot more significant sounding speakers I still came away saying - yes but it's 3-10 times more expensive. Moving to Hong Kong buying the KEF LS-50 but that wasn't going to be a long term solution - so I wound up with the near entry level AN E/Lexus. I tried to alter course re-listening to Quad 2905, Magnepan 1.7, 20.1, Dynaudio Countours, Focal Utopia, Legacy, Revel B&W, more KEFs, Zu Audio, ATC, Sonus Faber, Paradigm, Teresonic, DeVore, Trenner and Freidl, Gallo, Spendor, Magico, Tannoy, Vivid Audio, SandersSound, Harbeth, Reference 3a, McIntosh, PMC, Canton, TAD, YG Acoustics, Avantgarde, Soundlab, Martin Logan, MBL, Wilson Audio, Wilson Benesch, JBL, Coincident Technologies, Ensemble, KingSound, Acoustic Zen, Von Gaylord, and numerous others. It would be a stretch to say I couldn't live with many of these speakers because I think I could. Especially the Higher efficiency varieties but the AN E for me is like the favorite pair of slippers. What I like about them - their unique presentation - is difficult now to live without. The AN E/Spx Alnico Hemp is the model that I lust for but they will come in time as the entry model is always upgradeable at a later date. In a large room I'd move to big single driver and or horns but in a normal room for me the AN E (specifically the E/Spx Alnico Hemp) is still the king of the hill.
November 26, 2014, 11:17 PM #109
Richard, curious what kind of stands are you using?
November 27, 2014, 01:49 AM #110
- Nov 2014
- 83
I use the AN E stands. I have had numrous recommendations to fill them and with what to fill them and some find it all sounds much better without being filled at all. I should think it would depend on the positioning. Filled works for me. But my room is concrete and I have them up against the back wall which is half covered in acoustic foam. With a wooden home with plaster walls and carpeting then this might change.
November 27, 2014, 02:17 AM #111
- Nov 2014
- 68
for me, and this would still have to be the best speaker i have heard,
Verity Audio lohengrin
November 27, 2014, 09:53 PM #112
- Sep 2013
- 200
I still believe that the ATL approach used by PMC provides a superior sound compared to sealed and bass reflex systems, regardless of brand or price..
McIntosh MC462, MDA200, MCT500 -Apple Music iPad- PMC MB2 Se - Klipsch Palladium P-37F / P-312W- Clarus Crimson
January 9, 2015, 09:47 AM #113
- Jan 2015
- Australia
- 3
Yet to hear better than active ATC 3 ways
January 9, 2015, 10:30 PM #114
For me, it would be the Salon 2's.
They are a perfectly balanced speaker, amazing on and off axis. They just don't do anything wrong, and that's a high compliment.Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
January 9, 2015, 10:45 PM #115
January 9, 2015, 11:01 PM #116
Le Roy
Foundation:
January 9, 2015, 11:05 PM #117
January 9, 2015, 11:11 PM #118
After I hear Ian's M Projects, I have no doubts it will be them.
Acoustical Systems, AMG, Aqua Acoustic Quality, Audeze, Audio Desk, Audible illusions, Audioquest, Aurender, Bryston, CH Precision, Chord Electronics, Constellation Audio, Dynaudiol, Fyne Audio, Grado labs, Ikeda, JL Audio, Kondo, Kronos, Kubala Sosna, Lumin, Luxman, Lyra, Magico, Nordost, PS Audio, Roon, Shunyata, SME, Sugden, Tenor, Tannoy, Vertere, VPI and ZYX.
www.audiobymarkjones.ca
January 10, 2015, 01:49 PM #119
Raidho D4, if they ever appear!
January 10, 2015, 02:15 PM #120
January 15, 2015, 10:41 PM #121
If I didn't have to use them to review gear, I'd go for a big pair of Sound Labs.
January 15, 2015, 10:42 PM #122
January 15, 2015, 10:53 PM #123
I just really love ESL's but not practical for everything. If I was going to write reviews forever, these Dynaudio Evidence Platinums would fill the bill, maybe some GamuT RS9s, or a big pair of Focals. SF Aida's were nice too.
January 15, 2015, 11:10 PM #124
Big Focals..
Definitely.
January 16, 2015, 01:02 AM #125
Honestly, I could live happily ever after with a mint pair of Acoustat 2+2s....
January 16, 2015, 09:59 AM #126
Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
January 16, 2015, 10:44 AM #127
If somebody were to tell me that I'd have to live with a set of Rosso Fiorentino Florentia's from this point moving forward, I suppose I'd find a way to live with em'.
January 16, 2015, 02:37 PM #128
After getting divorced and buying a much larger house (and winning the mega-lottery along the way), I'd go for the MBL Extremes.
B&W803D3; McIntosh MA9000 integrated amp; Esoteric K-03 SACD/CD player; VPI Prime Signature/Ortofon Cadenza Bronze; Sennheiser HD800S and AudezeLCD-XC headphones
January 16, 2015, 03:09 PM #129
Le Roy
Foundation:
January 16, 2015, 03:31 PM #130
I'm not gonna talk about my own speakers cause that's tiring, so I'll have to go with the Voxativ, definitely the best speakers I ever heard. Also the most expensive and not necessarily the most practical, but wow.
Available in Transparent:
Or litteraly as work of art:
Manufacturer of
ICOS Audio, complete active systems, amplifiers, DACs and CD-players
Importer of
Antipodes Audio music servers and cables
In our Paris showroom, music lovers are welcome to experience the multi-awarded Dedicace, a five-way active system equipped with:
- Antipodes DX music server
- Antipodes Audio Kokiri AES cable, Reference InterConnect (2x) and Komako speakers (2.5 pairs)
- Legato Power Cables (3x)
January 16, 2015, 03:31 PM #131
- Jan 2015
- 181
To these ears, I could live with a number of speakers that do justice to music....MacIntosh or MBL certainly doesn't do it for ME. My favorites are the top Vandersteens, or Maggies..Thiels (haven't heard the new Thiels)..even though they sound so different, they bring music to me.
January 16, 2015, 04:16 PM #132
January 16, 2015, 08:23 PM #133
Magico V3..
Sense..
January 16, 2015, 08:38 PM #134
January 16, 2015, 09:00 PM #135
Allen
January 19, 2015, 08:48 AM #136
- Jan 2014
- 101
Zellaton Statements
January 19, 2015, 08:56 AM #137
Do you know the price?
Sense..
January 19, 2015, 09:11 AM #138
Voxativ makes their own drive, in Berlin. They are made of wood, of all matters.
This speaker is actually a flat-ish horn, as you may have guessed from the transparent one. There's only one, fullrange, active drive, with very high sensitivity. When I asked last spring in Munich, the price of the black unit was a low low 192k€ . Stil, to me it was the best sound in the show, if not the best value (they used their own electronics and TOTALDAC digital sources).
This drive unit is active, i.e. the magnet is replaced by a coil, with a battery power supply, and an engine made of permadur...
Dimensions: 47 x 55 x 7.5", i.e. 120 x 140 X 19 cmn, 70kg/155lbs
A really good fullrange speaker is interesting because you can dispense with crossovers altogether. We at ICOS only make a 5 way active system because no fullrange speaker would properly reproduce both treble and bass, and we don't like crossovers and capacitors, but this one feels like a possible game changer. One of these days we'll try their OEM drives see if we can do something good and expensive.
Check out their website:
Loudspeakers - Voxativ LoudspeakersManufacturer of
Importer of
January 19, 2015, 10:24 AM #139
At 100DB goes down to 25HZ with one driver ? Impressive.
Technical data:
Frequency response 25 - 20.000 Hz
Driver VOXATIV AC-Xp
Efficiency 100 dB / 1W / 1 m
Capacity 50 W sinus
Dimensions (W x H x D) 120 x 140 x 19 cm / 47 x 71 x 7,5"
Weight 70 kg / 155 lbsPaul
January 19, 2015, 02:01 PM #140
- Jan 2015
- 181
As for me, when I buy a component, support is just as important as performance. I only buy brands that are already successes in the market.
January 22, 2015, 01:37 PM #141
- Jan 2015
- 11
Wilson Audio Sophia 1
January 24, 2015, 08:48 PM #142
- Jan 2014
- 101
January 24, 2015, 09:05 PM #143
Rob
January 24, 2015, 09:10 PM #144
Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
January 24, 2015, 09:56 PM #145
- Jan 2015
- 181
I had Acoustats many years ago.....one of them caught fire and nearly burned the house down. I understand that was a common complaint.
January 24, 2015, 11:09 PM #146
- Jan 2014
- 101
January 24, 2015, 11:18 PM #147
- Jan 2014
- 101
I sold two used pair back in the early 80's. Last year one of those people had a breakdown on one of the amps and asked me for help. He found me on Facebook. He sent the amp to Roy Esposito and had it fixed. After 32 years of constantly using them, one breakdown. The other person still uses his everyday and never has had a problem.
There is a good reason you never see them used. Nobody wants to sell them. There is a guy in OKC that will modify the amps and make them very reliable and sound even better.
January 24, 2015, 11:43 PM #148
January 25, 2015, 12:14 AM #149
- Jan 2014
- 101
I am very aware of what went wrong with Acoustat, I was the fifth largest dealer in the USA back then. Sure, in the early years of the servo amps Acoustat had problems, but by 1982, Roy Esposito, Acouststs top engineer had figured out the problems and was modding the amps for $300 for the pair if you sent them to Acoustat. The mod made them very reliable.
Acoustats Jim Strickland flew up to my place one time for a visit. He walked in my shop and I had the pair of the used Acoustat Monitor III's I told you about earlier. It looked like he had seen a ghost when he saw those. He looked at me and told me point blank, get rid of them. Acoustat and Strickland knew they had sold out to the devil with those transformers. It was all about the big bucks and nothing else. Acoustat deserved to go out of business.
Roger Modjeski still uses the Acoustats, but uses his own personally designed amp. RM can design it for the Quads also, that will bypass their transformers and make them sound much more open and quicker.
January 25, 2015, 03:05 AM #150
- Nov 2013
- Minnesota
- 1,369
Of the speakers that I have heard- Wilson Alexia's or Magnepan 20.7's
For a speaker that I have not heard- Apogee Grands
The GrandMy Gear- Mains System-Pass X250 amp, BAT VK-51se preamp, Luxman DA-06 DAC, Magnepan 1.6's, Thorens TD-145 TT, Dual Martin Logan Subs, Vintage Luxman T-110 Tuner, Cables-WW Platinum 7 USB, Cardas Parsec XLR, AQ Columbia DBS 72v XLR, Belden 8402 XLR.
Didn't do a triple header - what a pic! That brings back many great memories of riding The C&T railroad to the summit. Would do it again in a heartbeat.
For Mikado Dave
