Results 1 to 12 of 12
October 8, 2018, 08:40 AM #1
- Jan 2017
- Leyden
- 596
Qobus or Tidal which do you recomend
Currently I have neither Tidal, Qubos not Spotify. But thinking about getting either Tidal or Qobus.
Is there any real difference between Qobus or Tidal? Personally I was thinking about Qobus Hifi. The sublime + seems a bit expensive.
Any tips.
I use a Auralic Aries LE as streamer.Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
October 9, 2018, 04:48 AM #2
Re: Qobus or Tidal which do you recomend
I have both Qobuz and Tidal at the moment (through my Aurender N10 which has the MQA update, I don't have a MQA DAC).
The High-res files in Qobuz are not better or worse then the Tidal MQA files. (maybe a full MQA DAC might change that)
Overall I don't have a real preference, both are reliable, Qobuz has some more classical music content.
OlafLast edited by imprezap2; October 9, 2018 at 10:44 AM. Reason: spelling control
Moon 700i V2, YG Acoustics Hailey, Aurender N10, dCS Rossini, Oppo BDP103D (audiopraise board), Ansuz Mainz 8 D2
October 9, 2018, 12:06 PM #3
If and when Qoboz gets integrated into Roon then and only then will I consider it as a viable option.
Jim
October 10, 2018, 05:50 AM #4
- Jan 2017
- Leyden
- 596
October 10, 2018, 08:48 AM #5
Jim
October 10, 2018, 01:21 PM #6
Searching classical music in Tidal is certainly demanding. Often I have to do separate searches of performer, conductor, album and/or composer names to dig out what I’m looking for. Just searching, for example, “Vasks” won’t give me everything by the Latvian composer. If Qobuz nails this then I may have to switch, though I’d lose the fun of the hunt.
Parker
October 10, 2018, 04:45 PM #7
- May 2015
- 206
Source: Taiko Audio Server, Cisco 2960 Switch, Gigafoil, Lampizator Pacific Dac. Amp: Bakoon 13r Speakers: AvantGarde Duo Mezzo XD, Cables: Alan Maher Designs Power, Duelund Speaker, Shunyata Sigma IC's Audioquest Diamond ethernet. Room Treatment Vicoustic.
October 11, 2018, 06:15 AM #8
- Jan 2017
- Leyden
- 596
October 11, 2018, 07:07 AM #9
- Jan 2017
- Leyden
- 596
October 11, 2018, 10:36 AM #10
Yeah, you always have to drill down with Tidal. You just never know which bit to use. I don't know how many times I finally found an album on the search of a fourth or fifth piece of info, whereas if there was adequately thorough metadata any combo of two of those data points should have resulted in the title sought. So I guess I'm hoping Qobuz has more thorough metadata?
November 11, 2018, 09:34 PM #11
Tidal, Qobuz does not exist in the US.
November 14, 2018, 11:10 AM #12
- Jan 2017
- Leyden
- 596
I just got a monthly Qobus Studio subscription. If I like it I might switch to a yearly subscription.
