Results 1 to 14 of 14
June 17, 2018, 11:48 AM #1
- Jan 2017
- 115
Lumin U1 : really blown and not working
Hello
I have been using my lumin u1 for a year. Yesterday , I did the software upgrade to 10.3b
Then the lumin worked
Atferwards , the unit switched off and the PSU was quite hot
I unplugged everything , and switched on again
Music played for 90 to 120 seconds , and again the unit switched off by itself
Who is the culprit ?
The PSU or the Ugrade ?
What to do now ?
Cheers
June 17, 2018, 12:46 PM #2
Re: Lumin U1 : really blown and not working
I believe I did my upgrade about a week ago (didn't really pay attention). I've played stuff on it and it hasn't shut off/
June 17, 2018, 01:00 PM #3
- Jan 2017
- 115
Hello
It seems that the PSU may be the culprit
Will send a mail to wklie
Is there a method to reboot to factory version ?
June 17, 2018, 01:51 PM #4
Please send email to info@luminmusic.com
I'm on vacation now and our team will be able to better followup this case.
Assuming the firmware upgrade does the upgrade normally, I've tested the new firmware is stable. Two beta testers have also been using it for a month before it got a public release.
June 17, 2018, 02:40 PM #5
- Jan 2017
- 115
Thanks a lot
I hope that Lumin will find a quick solution for me (psu exchange ?)
Thanks again Peter , i have mailed Lumin
June 17, 2018, 10:08 PM #6
I also just played my system for a good hour and a half and cranked it. The U1 power supply was cool. I don't use the volume control in the U1
June 17, 2018, 10:49 PM #7
- Jan 2017
- 115
Hello
I guess that this should be a power supply problem .. i am waiting for Lumin to answer , to know how a repair / test / exchange could be done . Voltage regulators can be quite hot i think ..
Hard to be without music ..
cherrs
June 18, 2018, 10:58 AM #8
I feel for you. That's one of the reasons I generally don't sell as much and just rotate stuff to a secondary system. In the past many moons ago, I've had amps in for repair and what I had as a spare amp wouldn't drive my main speakers to reasonable levels so I was left with background music capability only.Main System - Lumin U2, Modwright LS36.5 DM Preamp, VTV Purifi 1ET-7040SA with tube buffer, EMM Labs DAC 2X (ver. 2), Torus RM-20, Thiel CS 3.7s, 2 Rel S/812 subs
June 24, 2018, 12:04 PM #9
- Jan 2017
- 115
Hello
After some days , Lumin asked me to test the PSU , with voltage on the PINS
I'll do so tomorrow
BUT , I have no idea which pin is number 1 -- and which one is NUMBER 8
Well , I hope that I'll find a way to get it repaired or exchanged
Cheers
June 24, 2018, 02:10 PM #10
Hi , i just did a google search , and i hope my link works
8 pin din numbering
Then you will see how the numbering is.
Hope it helps you.Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
June 24, 2018, 02:49 PM #11
- Jan 2017
- 115
thanks
June 24, 2018, 03:05 PM #12
your welcome and only glad if i can help. Hope you get the problem solved.
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
June 24, 2018, 03:12 PM #13
- Jan 2017
- 115
Hello
I did that search , and simply forgot to see the images ..
Tomorrow upon returning home , I'll chevk that
Lumin is not so well distributed in France , and I bought the unit in HK
So i think that the local distributor will not take the guarantee
The other route is to send the PSU to HK , but I'm waiting for a reply from Lumin
Then , I can try to buy a PSU from Kenneth LAU , but .. expensive
So right now , It's huge frustration , and impatience
Many many thanks for your help
I hope to get news from Lumin soon
Cheers
July 8, 2018, 05:17 AM #14
- Jan 2017
- 115
Hello
Some updates regarding the problem
1. Wklie has been very kind and helpful
2. The PSU is not working , and I'll send the unit , which is still in guarantee
I have been wondering about
1. Kenneth Lau PSU as replacement
2. The new Lumin PSU
IS this new PSU compatible with the U1 ?
Cheers
Clarisys Arrives at Puur...
