Results 1 to 39 of 39
  1. #1
    Post Looking for a power cable for my Pass Labs Amp
    Most likely I will get a Pass Labs X 350.8 amp in soon, and I’m looking for a power cable for this amp. May I know what cable work best for this amp? i cannot accept hard cable. Some PC like steel that I really hate. I have a Shunyata Sigma Analogue for my per-amp, it sounds nice but this cable's diameter is too thick for me. THX.
  2. #2
    Re: Looking for a power cable for my Pass Labs Amp
    If Shunyata is out of the question due to size you might want to try the AQ Dragon.
  3. #3
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    if you're not content with the one that comes with it try one of these ..... http://signalcable.com/magicpower.html
    I'm using them on my X260.8's , zero complaints .........
    Cheers ! …. Dave
  4. #4
    Thanks! How about Wireworld Platinum Electra 7? It's a flat cable , very soft. I heard it sounds very nice and match with Pass amp perfectly. But the price seem to be very high...
  5. #5
    The best easy-to-manage AC cable is Siltech Ruby Hill II, IME. I have yet to find a better built quality. Sounds good too of course.
  6. #6
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    Shunyata Alpha EF (extreme flexibility)
  7. #7
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    Quote Originally Posted by MM622 View Post
    it's your money but pricey wire is just that, pricey wire.
    Cheers ! …. Dave
  8. #8
    You don't need OCC silver conductors in your power cable; just get one of the (much) cheaper models which are basically the same cable with copper conductors.
  9. #9
    https://www.amazon.com/gp/product/B0027JRMD0/
    Seriously. No joke. I don't believe in fancy power chords. I have this one for my own amp. You also save a lot of money that you can put into real upgrades.
  10. #10
    Senior Member
    Join Date
    Nov 2013
    Minnesota
    Posts
    1,369
    I just purchased a Cullen Cable power cord for my Pass X250 amp. I should have it in 7-10 days. The cables have good reviews and are reasonably priced starting at $100 and up from there. Most have 3x10g conductors.
    http://www.cullencable.com/
  11. #11
    Both of these have 10AWG conductors and relatively affordable:
    Shunyata Venom-HC
    https://www.thecableco.com/cables/po...cord-sale.html
    Kimber PK10 Base
    https://www.thecableco.com/cables/po...ower-cord.html
  12. #12
    Senior Member
    Join Date
    Apr 2013
    Texas
    Posts
    930
    Second the Shunyata Venom HC (high current).
    Sean
    Lumin T2
    Gryphon Diablo 333
    Magico A3 w/ A-Pods
    AudioQuest Hurricane HC
    HRS E1
  13. #13
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    Quote Originally Posted by Al M. View Post
    I can't imagine that one being any better than a stock PC .......
    Cheers ! …. Dave
  14. #14
    Quote Originally Posted by Mikado463 View Post
    True. It is a stock PC. Yet some stock PCs are so thin that for I'd rather take no chances when I only have to spend an extra $16
    Would I spend time evaluating if the sound makes any difference compared to a thinner stock PC? You bet, I would NOT, not for that kind of money.
    Of course, one might argue that it could have unexpected adverse effects compared to a thinner stock PC, but that would be audiophilia nervosa going overboard, in my opinion.
  15. #15
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    yes , but the Op is talking about Pass Labs.......... not the case !
    Cheers ! …. Dave
  16. #16
    Then even better! Plug in the stock PC and be done with it!
    Saves you $ 16 right there .
  17. #17
    I can’t imagine that one still believes after market ac cables are snake oil. All you have to do is try a viable one like Shunyata.
  18. #18
    Quote Originally Posted by kzhtoo View Post
    Been there, done that.
    And a friend who had all kinds of fancy power cables in his system, including very expensive ones, has reverted to stock cables.
  19. #19
    I almost always could hear. I just replaced Alpha Digital with Hurricane on my Yggy and heard the improvement. Although not so much with replacing Ruby Hill with Hurricane on the integrated.
  20. #20
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    most of us are saying that all are not snake oil, rather the absurd pricing is ridiculous. Listen, if you or anyone else can actually show me what justifies some of these 3-5 thousand dollar PC's I'd love to see it.
    I have a Venom-HC, a supposed $300 msrp I believe, you can buy it all day long for $175. Is it any better than the Signal Cable variety that sells for a third, absolutely not.
    Bottom line is cable discussions on forums like this never accomplish anything. The majority of those that swear by high priced wire, do so with their own subjective bias. I'd be willing to bet that most don't even have a full and complete understanding of Ohm's law.
    In the end if it makes you happy........ it's your money !
    Cheers ! …. Dave
  21. #21
    Yup. I have better things to do with mine. Makes me happy too.
  22. #22
    Just because the ruler you use is different than that of others, it doesn’t make you right nor it isn’t justified for others.
    And that means all other after market ac cables shouldn’t be any better? Absolutely not.
    I wonder who started this?
    Not knowing Ohm’s law has nothing to do with one’s hearing ability. For what is worth, if you use any type of flash memory, chances are they have my design contributions.
  23. #23
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    Are you saying there can be no correlation between laws of Physics and ones cognitive ability to hear ?
    As for your 'ruler statement' ....... LOL, you obviously can't answer my question !
    Cheers ! …. Dave
  24. #24
    Here we go again. I refuse to get sucked into this.
    Note to self: apparently “LOL” is not for everyone.
  25. #25
    Senior Member
    Join Date
    Feb 2016
    west Michigan
    Posts
    713
    OK, so this can now be added to "settled science".
    There are those that can hear a difference and those that cannot.
    Now this thread, if continuing, is for those that can hear a difference.
    My System
    Acoustic Revive RTP-4
    Innuos Pulsar
    Lampizator BALTIC4
    Cary SLP-05
    Pass XA30.5 or
    Line Magnetic 845ia
    Reference 3A Reflector's
    Pr SVS SB3000 Subs
    Core Audio Design Rack
  26. #26
    Yes, this is made by a friend of mine.
    But why don´t you give it a chance?
    http://allforhifi.com/index.php?id_c...oller=category
    If you don´t like you can get your money back.
    To me, is the best power cable i tried (and i tried Supra, QED, Furutech; Stealth; Gigawatt; Nordost - entry level)
  27. #27
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    not the intent, sorry.
    Quote Originally Posted by jadedavid View Post
    jade, fine, so you educate me......... what difference do you hear ?
    Cheers ! …. Dave
  28. #28
    It's not just about a difference, it's if it's any better. And if it's better, is it better in every way, or are there any drawbacks?
  29. #29
    Senior Member
    Join Date
    Feb 2016
    west Michigan
    Posts
    713
    Isn't that what we sort out in every component we purchase?
    My System
    Innuos Pulsar
    Lampizator BALTIC4
    Cary SLP-05
    Pass XA30.5 or
    Line Magnetic 845ia
    Pr SVS SB3000 Subs
  30. #30
    My friend had been asking himself all the time where the midbass was in his system. Once he got rid of his power conditioning and all his fancy power chords, exchanging them for stock, he had his midbass back in all its glory. Kind of a big deal I would think.
  31. #31
    Senior Member
    Join Date
    Feb 2016
    west Michigan
    Posts
    713
    It would seem logical that upon inserting the first piece of gear that negatively altered the tonal balance of the system that you would remove that item. Certainly not continue adding more detrimental pieces of gear.
    At least thats what I would do.
    I'm very happy for your friend that his system is back to it's glory.
    My System
    Innuos Pulsar
    Lampizator BALTIC4
    Cary SLP-05
    Pass XA30.5 or
    Line Magnetic 845ia
    Pr SVS SB3000 Subs
  32. #32
    When there is an item that makes my system sound worse, i always go for another one that could make it sound better.
    In other words: power cables make the difference, just be careful.
  33. #33
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    Quote Originally Posted by Spock View Post
    1 - how do they make 'the difference'
    2 - why should I / we be careful ?
    Cheers ! …. Dave
  34. #34
    Senior Member
    Join Date
    Feb 2016
    west Michigan
    Posts
    713
    You should just try some different cables and see if they make a difference in your system.
    If they do, that's great. If not then at least you have tried and experienced it for yourself
    Above all, enjoy the journey..
    My System
    Innuos Pulsar
    Lampizator BALTIC4
    Cary SLP-05
    Pass XA30.5 or
    Line Magnetic 845ia
    Pr SVS SB3000 Subs
  35. #35
    Jadedavid,
    Thanks for the answer.
    Mikado 463, i don´t want to provoke you but believe me when i say that the influence of the power cables in my system is so big, that is hard to me to understand that they do not make the same in all the systems.
    Now, here it goes a good provocation: do you know what can make equal or maybe more difference than a power cable?
    Fuses!!!
  36. #36
    Senior Member
    Join Date
    Nov 2013
    SE Pa
    Posts
    2,037
    I'm just trying to figure out / understand what differences I should be hearing. I have done one comparison (Signal Cable and the Venom HC ) and could not hear a difference. When I hear folks saying there are night and day differences it makes me wonder why hasn't Nelson Pass and others either adopted or at least endorsed said cables ?
    Cheers ! …. Dave
  37. #37
    Senior Member
    Join Date
    Feb 2016
    west Michigan
    Posts
    713
    So, you have tried power cables. And, you have not heard a difference.
    That's OK. As is appearent on this and other forums, some people don't.
    A recent audio sound bite had some people hearing Yanni while others heard Laurel. It seems we don't all hear the same.
    If something works for you then great. If not then leave it behind you.
    In your case you now have the money you would have spent on Power Cables available to do other upgrades (purchases) or just keep it in your pocket.
    MOST IMPORTANT (a quote from Dick Olsher) "A day without music is like a black and white sunset".
    Enjoy
    My System
    Innuos Pulsar
    Lampizator BALTIC4
    Cary SLP-05
    Pass XA30.5 or
    Line Magnetic 845ia
    Pr SVS SB3000 Subs
  38. #38
    Quote Originally Posted by Kuoppis View Post
    While Shunyata is large diameter...they are surprisingly supple. If Shunyata doesn't suit the OP, then the. AQ storm cables will be like installing a joint of drilling pipe. They are great sounding cords with excellent build, but so stiff and unwieldy that they will be unusable for many people.
  39. #39
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    Dave, for me i heard better definition of the soundstage , the bass was also better defined , things seemed to get better in all ways . And i have to say i was really surprised that power cables and a distributor could make such a difference i was and am amazed . Now i also tried loudspeaker cables and can only say , wouuu , i did not expect that to be so much better than an already good Loudspeaker cable ( Yter , used in Bi Wire configuration )
    Flemming
    Lumin X1
    Rotel Michi S5
    Focus Audio FS788
    LS cable : Yter
    Nordost QB8
    Rack : Finite Elemente Pagode
Posting Permissions
  • You may not post replies
  • You may not edit your posts
