Results 201 to 232 of 232
March 3, 2018, 03:22 PM #201
Re: MQA already dead in the water? No full decoding DAC alternatives...
The whole MQA thing seems to infuriate the left brainers. “If it can’t be proven by measurements, it isn’t good.” The right brain folks just don’t care. Listen, you may like it, don’t listen, don’t care. Nobody is making you buy your 17th copy of Kind of Blue. My Lampi doesn’t do MQA and it sounds great. My MSB does MQA and it sounds great too.
I swear this is reminiscent of the high res (“nobody can hear above 20khz!!”) and DSD arguments.
March 3, 2018, 04:06 PM #202
This might upset some, but now that I have experienced MQA with a reference level DAC, I must say to me MQA sounds best right after vinyl. I have also done head-to-head comparisons with vinyl, and MQA is by no means lagging behind.
March 3, 2018, 05:25 PM #203
I like it at times, whats the next world issue that needs solving
March 3, 2018, 07:00 PM #204
I know I sound like a broken record, but I just don’t see why any music lover wants to buy into the technology-static MQA monopoly attempt. How it sounds is absolutely beside the point, because no matter how good it is today, it can’t possibly be the best sound tomorrow, unless MQA has its way and it is the only sound tomorrow.
Rob
__________________________
Tascam BR-20; Technics 1506 with tape path upgrades, FM head, DeHavilland 222 tape head pre; Modwright Oppo 205 full tube mod w/LPS; Euphony Summus server, EtherRegen, HDPLEX LPS; MSB Discrete DAC (dual PS, ISLPro, balanced out); Pass Labs XP-12, XA60.8 (pair); Daedalus Audio Apollo 11’s, VMPS Larger Sub; Daedalus/Wywires, Acoustic Zen, Sablon Audio, Wireworld, Shunyata Research cables; Core Power Equi=Power;
Adona rack, Stillpoints, IsoPods, ASC, GIK Acoustics accessories
March 3, 2018, 07:04 PM #205
Even though I really like what I hear with MQA, I’m not that fussed if people are against it. If my DAC does it, I enjoy the full unfold. If not, I enjoy the first unfold thanks to Tidal. But I still play loads of PCM and DSD too.
IMO, what needs “fixing” in digital is much better A2D converters and an agreement to drastically limit compression. Those two things will trump all format wars.
March 3, 2018, 07:14 PM #206
For sure about the compression. I find I have to listen to many of today’s lousy masterings at much lower average volume (and therefore much much lower peak volume) than something better recorded. It’s just too painful otherwise. MQA doesn’t fix that, unfortunately.
Rob
March 4, 2018, 04:44 AM #207
Hans
Bowers & Wilkins 805 D3 /alternatively JM Lab Point Source Aria 5 (self modified)/ 2x SVS 3000 SB, Audionet AMP (2x), dCS Bartók used as streamer / DAC / preamp, Pro-Ject RPM 9 with Speedbox S and Orthofon MC Vivo Blue, KEF LS50 Nocturne / Sunfire Atmos(kitchen). Patio: Bluesound Node 2i and Focal CMS50.
RoonServer on Nucleus.
March 4, 2018, 09:06 AM #208
Jim
March 4, 2018, 09:45 AM #209
And on CA:
MQA: A Review of controversies, concerns, and cautions
https://www.computeraudiophile.com/c...cautions-r701/
P.S.:
"Editor's Note 1: MQA ltd was sent a copy of this article several days prior to the scheduled publication date. The company requested a phone conversation, which took place earlier this week. MQA was encouraged to write a response for inclusion with the article below, but it respectfully decline to submit a formal response.
Editor's Note 2: The author of this article is writing under a pseudonym. While he is unknown to the readers, his identity has been verified by Computer Audiophile. He has no vested interest in the audio business, other than being a consumer of music.
Editor's Note 3: The technical assertions made in this article have been thoroughly checked by independent engineers, both in and out of the audio industry. To the best of our knowledge everything technical in this article is factually correct and may be duplicated at any time by anyone with the requisite skills."
- Chris ConnakerTriangle Magellan Concerto 2 < AQ Everest < Vitus Audio SS-010 Mk2 < AQ Dragon HC < AQ WEL Signature XLR < Chord Qutest w UpTone JS-2 & AQ Dragon Source < SOtM tX-USBultra w 75Ohm Master Clock Input, Paul Hynes SR5-12 Turbo XL & AQ Dragon Source < AQ Diamond USB < Aurender N-100H w AQ Dragon Source < Gryphon PowerZone w AQ NRG-Wild < Solid Tech Hybrid < Ansuz Darkz D-TC, Darkz D2, Stillpoints Ultra SS, Omicron Harmonic Stabilizer & Gold SE < Furutech FT-SWS < Synergistic Research Blue Quantum Fuse
March 4, 2018, 09:11 PM #210
Like the original with unauthentic aliasing distortion and eq added...that some may find pleasing.
Good analogy, since SETs add unauthentic even order distortion and eq...that some may find pleasing.
The problem with adding maple syrup sweetness to everything is that it works great with pancakes...and terrible with steak.
YMMV
March 5, 2018, 09:55 AM #211
After listening to hundreds of MQA files I still haven't found one that sounds inferior to its 16/44 version when I have compared them. A few I have no preference.
Jim
March 5, 2018, 03:51 PM #212
I usually prefer the non-MQA version to the MQA.
This is just my personal preference with my Lumin A1.
I would really like to listen to MQA with another DAC (for example the Nyquist) to check if the problem is MQA or Lumin.Francisco
March 5, 2018, 05:37 PM #213
Whether one prefers the unauthentic aliasing distortion/EQ of MQA, or not, will come down to personal subjective preference. Nothing wrong with either.
Unfortunately the perpetrators of this scheme wants it to be the only option for distributed music, including at the original recording level, not after the fact.
cheers,
AJ
March 6, 2018, 08:50 AM #214
Yeah, that would be a problem.
If its only ONE delivery option, then its a win, if its the only, its a loss.NORMAN
March 6, 2018, 08:52 AM #215
March 6, 2018, 09:07 AM #216
My guess is MQA will be just one standard among others, demand will determine what happens.
March 6, 2018, 09:19 AM #217
March 6, 2018, 09:40 AM #218
March 6, 2018, 10:20 AM #219
- Apr 2016
- Calgary, AB
- 316
I'm quite certain that won't happen. If studios start selling downloadable MQA content their goal will be to quit selling all other high-res (the crown jewels). Remember their download sales are pretty minuscule with most people streaming mp3s or still physically buying CDs.
So, unfortunately demand will play very little in it, and causes the "left brainers" to be concerned.
March 6, 2018, 11:19 AM #220
Downloadable MQA content has been around for well over a year now. So that part of your post has come and gone. There are many options as with some content you can select from MQA, 16/44 or 24/96 or 24/192. Not sure where you get your information that people are still buying CD's. Several graphs have been posted showing that CD sales and digital downloads peaked a few years ago and are dropping at an increasing rate. So there isn't much chance that downloadable MQA will ever be more than a niche market that will probably be smaller than vinyl and slightly larger than DSD. Streaming is the current preferred delivery method by the mass consumers. Unless Apple, Amazon and Google get on board I doubt that the studios will put all there eggs in the Tidal basket wit MQA.
Jim
March 6, 2018, 11:51 AM #221
Yep CD sells in the US, downward downward and further downward , I guess I'm the only one still buying
https://www.statista.com/statistics/186772/album-shipments-in-the-us-music-industry-since-1999/
Streaming
https://www.statista.com/statistics/437717/music-streaming-revenue-usa/
LP
https://www.statista.com/statistics/188822/lp-album-sales-in-the-united-states-since-2009/
The Digital Download stats encompass any thing digital, but the bars on the graph do note what is contained in that year be it digital music, ringtones etc,
https://www.statista.com/statistics/...us-since-2008/2chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
March 6, 2018, 12:05 PM #222
- Apr 2016
- Calgary, AB
- 316
I'm talking the big studios not the puny amount of downloadable MQA content currently available by a couple of specialty tiny labels.
Are you saying that lossless downloads have overtaken CD purchases? I consider purchasing MP3s from iTunes a different classification, as they are lossy, they already protects the labels crown jewels.
March 6, 2018, 12:25 PM #223
Jim
March 6, 2018, 12:40 PM #224
- Apr 2016
- Calgary, AB
- 316
March 6, 2018, 12:46 PM #225
- Apr 2016
- Calgary, AB
- 316
On a side note those Onkyo MQA prices are little ridiculous. $16US for a lossy version of the album? That's $20CAD.
March 6, 2018, 12:55 PM #226
Jim
March 6, 2018, 01:07 PM #227
- Apr 2016
- Calgary, AB
- 316
March 6, 2018, 01:19 PM #228
Jim
March 6, 2018, 04:49 PM #229
NORMAN
March 11, 2018, 11:01 AM #230
Jon Iverson's editorial in the latest Stereophile isn't yet online, but know that it takes dead aim at MQA. Long, long overdue IMHO.
Rob
March 11, 2018, 01:03 PM #231
- Nov 2014
- 2,104
So... how does MQA sound compared to hi Rez files?
Anyone can do the blind test referenced to in the article. Here is the link.
http://archimago.blogspot.com/2017/0...-decoding.html
After you have done the test, you can go to Archimago’s blog (from September 2017 I believe) and see what you actually preferred from the blind test.
March 14, 2018, 08:43 AM #232
Well now it is https://www.stereophile.com/content/...fits-and-costs
Hopefully the fanboys don't freak
Upgrade on the way...
