Results 51 to 69 of 69
Thread: Power Cords
December 29, 2017, 11:51 AM #51
- Dec 2017
- 38
Re: Power Cords
How many people have spent more on P.C's than it would have cost to either put in a dedicated sub-panel with it's own ground or better yet gone with -60 | 0 | +60 balanced power?
December 29, 2017, 12:15 PM #52My Systems: http://www.audioshark.org/showthread...481#post158481
December 29, 2017, 01:02 PM #53
- Dec 2017
- 38
December 29, 2017, 01:03 PM #54
Re: Power Cords
December 30, 2017, 12:41 AM #55
Re: Power Cords
Let me take a moment and provide an example why I think having a solid foundation of power, cables, and vibration control lets you replace gear and have the new gear work at its best, or close to it, right from the start.
I replaced my Pass XP-20 preamp Wednesday morning with the new XP-22 preamp. This is the upgrade of the 20 with an improved umbilical cord, volume control, and some other circuit tweaks.
The power and cable foundation for the system is three dedicated 20 amp circuits; one for each amp, and one for the source gear and preamp. The source and preamp are connected to a Shunyata Triton v3-Typhoon power conditioner. The preamp is powered via a Shunyata Sigma Analog power cord. The source inputs are Shunyata Zitron Anaconda XLR, and the output to each amp is a Shunyata Zitron Anaconda XLR.
The vibration foundation is a Mapleshade Samson four shelf maple rack that weighs 300 pounds empty, along with Mapleshade Micropoint Brass Footers for the preamp. The rack sits on a ‘wood’ floor over a concrete slab, which sits on the ground.
With this foundation I was able to install the new preamp, and it has been sounding great since I turned it on, and as it gains hours (60 as of now) it sounds better and better.
Since the XP-22 has a new, longer umbilical cord, I placed the power supply on the floor, and the preamp on the brass footers. With the XP-20 the preamp sat on top of the power supply, and the power supply sat on the brass footers.
Anyway, with this foundation I know I can add any other preamp made (with balanced input/output) and expect it to perform at, or near, its best right from the start. The same applies to the file player and the amps.Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
December 30, 2017, 01:21 AM #56
Re: Power Cords
Speakers: Wilson Alexias
December 30, 2017, 09:42 AM #57
Re: Power Cords
not surprised, standard audiophile answer .......
Just bustin' your stones a wee bit, I get what your saying, it's all common sense, like the home you live in, it all starts with a solid foundation.Cheers ! …. Dave
December 30, 2017, 07:43 PM #58
Re: Power Cords
Yes, I agree. The point I was trying to make is that while I have a new piece of gear I don’t have to get a new power cord, or new interconnects, or anything else, in order for it to work at its best. Sure, it has to burnin for some period of time, but that is true of anything.
Happy New Year.Bud
Sony XA-5400ES SACD
December 30, 2017, 09:27 PM #59
- Dec 2017
- 38
Re: Power Cords
I'll send you two sets of randomly labeled cables. Two burned in and two virgin. You'll have 30 days to perform sighted, ears only, evaluation with no one else conducting parts of the evaluation unless you want to. I'll post a password protected zip that can be downloaded prior. After the results are posted (which set sounds the best) I'll post the password in forum.
$100 to charity winners choice.
December 30, 2017, 10:24 PM #60
Re: Power Cords
Bud
Sony XA-5400ES SACD
December 31, 2017, 09:59 AM #61
- May 2017
- Cleveland, Ohio, USA
- 531
Re: Power Cords
It doesn't even need to be a sub-panel. With a US type system, just run a heavy feeder (say 40 to 60 Amps) to a central point in the listening room and use a small 6 breaker box.
What the heck does 'it's own ground' mean?
Note that a balanced power system comes with lots of added NEC rules.
December 31, 2017, 10:27 AM #62
- Dec 2017
- 38
December 31, 2017, 10:34 AM #63
Re: Power Cords
Not sure where you live but in my area, all grounds terminate to one ground. If you have the neutral and ground bonded at a subpanel, then you'll get neutral return current through the ground wire back to the main panel (since there are now multiple paths). Even worse, if the neutral ever has a fault, everything will continue to work but you'll have all the current on the ground, which also means that you can now be electrocuted by touching the panel chassis, for example. The ground and neutral must be bonded only at one place (in the main panel) to avoid this.Thats how the electricians handled mine.
December 31, 2017, 12:54 PM #64
- Jan 2014
- Massachusetts
- 101
Re: Power Cords
What if new piece NOT Pass, say Convergent Black Path or Robert Koda K10 ... ? It might or might not work with existing cables.
Cables don't exist in a vacuum but in a system of components. You chose cables, amp, speaker ... based on the combinations of sound / tone. Everything has an unique sonic characteristic and a tone control IMO.
December 31, 2017, 05:48 PM #65
Re: Power Cords
might not work ?? ridiculous .........
Cables don't exist in a vacuum but in a system of components. You chose cables, amp, speaker ... based on the combinations of sound / tone.Cheers ! …. Dave
January 1, 2018, 09:57 AM #66
- May 2017
- 531
January 1, 2018, 02:59 PM #67
- Dec 2017
- 38
Re: Power Cords
Sorry, NEC allows for grounding a subpanel in a detached structure.
January 1, 2018, 04:14 PM #68
- May 2017
- 531
January 1, 2018, 05:17 PM #69
Nucleus one
