Results 1,601 to 1,640 of 1640
June 30, 2017, 05:11 PM #1601
- Sep 2016
- 10
June 30, 2017, 06:51 PM #1602
Re: JOB 225 2-channel Power Amplifier ... update ...
My goodies, changes again, Still modest, but effective...(at least on my level).
47 Laboratory Midnight Blue 4733, Audiolab 6000CDT, OPPO BDP103, iFi Zen Blue, Sparkler Audio S301B diva. Cabling: RCA, Linn Blacks,
47 Laboratory 4708 speaker cables. Morrow Audio DIG3 w/KLE Pure Harmony connectors. DH Labs Red Wave A/C power (for the 4733) Yep,that's it. My aim is high, but sometimes I forget to wear my glasses...
July 1, 2017, 06:03 AM #1603
- Sep 2016
- 10
August 24, 2017, 01:51 AM #1604
FYI. Amazon is now selling STA200, a downgrade version of Job 225, at $499. (Edit: just found this is old news.)
STA200 (From Feversound)
Job 225 (From hifipig)
October 7, 2017, 09:28 AM #1605
- Sep 2017
- 5
After reading all the reviews available and this forum, I got my Job 225 and Pre2. Thanks to Joeinid (Joe) for answering my questions. These replace my 23 year old Hafler 9303 Transnova power amp and 915 preamp. The new Job components sound great, couldn't be happier. The only gripe I have is the warranty is only for 1 year parts and labor. I think it should be at least 3 years. My question to those who have the Job 225 and Pre 2, any problems with the component since you bought it?
October 7, 2017, 12:00 PM #1606
Congratulations!!!
Welcome to the forum.
October 7, 2017, 12:03 PM #1607
All my Job gear has been rock solid! Never an issue. I really do not think you have to worry. Job has the Goldmund DNA and is a well vetted product. I believe any issue will pop up quickly and get resolved quickly as well.
November 10, 2017, 09:37 PM #1608
― Neil deGrasse Tyson
November 10, 2017, 09:43 PM #1609
Also, I had a 225 two years ago. I absolutely loved it, but I was just getting back into audio and was at the experimental stage. Now that I have tried a bunch of things, enjoying all the while. I am getting another Goldmund Job 225 amplifier. I am going to use it as a solid state rotation with my Quicksilver amps.
So yea, I think they are a pretty darn good amp. The one I had actually had a Goldmund label right on it (and on the box).McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
November 19, 2017, 04:02 PM #1610
Now that I have the 225 back in my system I can really appreciate just how amazing this amp is. So much so that I have sold the Quicksilvers, this and the ARC will be my amp rotation. The 225 will probably be the primary at this point.
November 19, 2017, 05:27 PM #1611
November 19, 2017, 05:35 PM #1612
Now there is a good one... the First Watt was excellent, very smooth, very open sounding. With the right speakers it would be almost unbeatable.
The Goldmund is incredibly fast, so it has great impact and dynamics. Percussion, cymbals, etc., maybe unbeatable. Multi-dimesion imaging... and considerably more power, so a better match for my KEFs.
December 4, 2017, 06:39 PM #1613
- Jul 2015
- Paris
- 9
Hi all
job 225 or intregated amp is class d or class AB?
thank uAscend Acoustics sierra 2//Modwright KWI 200//Luxman DA-06
Total dac usb//Transparent usb//Stealth pgs08//Kubala sosna Fascination//Kimber pk10 gold//audience powerchord se//Siltech Ruby hill ii//Vibex one7
December 4, 2017, 06:40 PM #1614Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 5, 2017, 05:39 PM #1615
- Jul 2015
- Paris
- 9
Thank you Joe
i will soon buy job intregated
hope it will be ok with my ascend sierra2
December 5, 2017, 05:43 PM #1616
Congratulations. It's a great time to buy because the INTegrated was updated to have the analog input truly analog, meaning no digital conversion and then back to analog. The Job INTegrated and all the Job gear, in my opinion, is absolutely wonderful.
If these are the specs of the Ascend Sierra 2, you should be fine. As long as you don't crank the heck out of them, it will sound great.
http://www.ascendacoustics.com/pages...srm2specs.html
Specifications Typical In-Room Frequency Response 41Hz - 27kHz ± 3dB In-Room Sensitivity 87dB @ 2.83v / 1 meter Frequency Response (Anechoic) 46Hz - 38kHz ± 3dB Sensitivity (Anechoic) 86dB @ 2.83v / 1 meter Impedance Compatibility 8, 6, and 4 ohm rated amps and receivers Minimum Impedance 6 ohms Minimum Recommended Power 45 watts Maximum Continuous Power* 150 watts Maximum Short Term Peak Power* 300 watts
December 7, 2017, 04:45 PM #1617
- Jul 2015
- Paris
- 9
Thank you Joe for the information
December 7, 2017, 04:58 PM #1618
March 27, 2018, 10:54 AM #1619
March 27, 2018, 12:57 PM #1620
The update was probably several months ago or more, I forget. The only change was to allow the analog input remain in the analog domain without going through double conversion. I feel it’s a big one because I always felt that the analog input was a little bleached compared to the digital input fed a straight quality digital signal. If you have need for another analog source, then the new one makes the most sense.
Original units can’t be upgraded and since I use a modified Sonos with mine, I’m not so upset because it sounds amazing.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
July 28, 2019, 05:30 AM #1621
Has Job closed its doors?
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
July 28, 2019, 06:09 AM #1622
August 22, 2019, 02:18 PM #1623
- Aug 2019
- NYC
- 1
Hello,
I've owned a JOB 225 since 2013 but for the past 3+ years I've been having some serious technical issues. Initially it started with just slight noises from the right channel, which ultimately worsened into really LOUD "pops." Now the amp won't even turn on. Interestingly, when it was operational the popping sounds stopped after 20 minutes or so.
Does anyone know any reputable repair options in the NYC area? I'm even considering sending the amp board to Switzerland... It will be expensive but considering the cost of something equivalent, I think it might be worthwhile still.
Thank you in advance.
Les
August 22, 2019, 09:16 PM #1624
Welcome to the forum Les, thank you for joining.
Send an email to service@jobsys.com
They should be able to help.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
November 11, 2019, 03:07 PM #1625
Hi all,
I have Job 225 coming next week. I am very late to the party I know.
With Job Systems being shut it's a bit of a gamble but having read about this amp, when I saw a classified for £700 I just pulled the trigger.
I am actually putting together a system for the first time and I have a few questions.
Attenuation and preamp matching
I will be driving the Job 225 from the RCA pre out of an RME ADI2 DAC. To deal with the high gain I am able to set the reference level output to -5dBu (the default is +7dBu or 1.73 VRMS). Do I still need attenuators from Rothwell audio? If yes, is 10db enough or will I need more? I plan to order the Rothwell River interconnects with Switchcraft plugs.
RME specs:
Analog Outputs
XLR
- Output level switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
- Signal to Noise ratio (SNR) @ +7/+13/+19 dBu: 117 dB RMS unweighted, 120 dBA
- Signal to Noise ratio (SNR) @ +1 dBu: 115,4 dB RMS unweighted, 118,9 dBA
- Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
- Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.9 kHz
- Frequency response @ 192 kHz, -1 dB: 0 Hz – 88 kHz
- Frequency response @ 384 kHz, -1 dB: 0 Hz – 115 kHz
- Frequency response @ 768 kHz, -3 dB: 0 Hz – 109 kHz
- THD @ -1 dBFS: -112 dB, 0.00025 %
- THD+N @ -1 dBFS: -110 dB, 0.00032 %
- THD @ -3 dBFS: -116 dB, 0.00016 %
- Channel separation: > 120 dB
- Output impedance: 200 Ohm balanced, 100 Ohm unbalanced
Chinch
As output XLR, but:
- Output: 6.3 mm TS jack, unbalanced
- Output level 6 dB lower than XLR (-5 dBu to +13 dBu @ 0 dBFS)
- Signal to Noise ratio (SNR) @ +13 dBu: 117 dB RMS unweighted, 120 dBA
- Signal to Noise ratio (SNR) @ +1/+7 dBu: 114/116 dB RMS unweighted, 117/119 dBA
- Signal to Noise ratio (SNR) @ -5 dBu: 109 dB RMS unweighted, 113 dBA
Power cord matching
The general consensus among reviewers seems to be that an aftermarket power cord makes a substantial difference. Can anyone confirm this is the case? If so, what cords are a good match?
I am keen on a Oyaide GPXe v2, but given the price I want to be sure of the benefits.
Fuse swap
I came across a review which suggests to swap the stock fuse with a Telos QBT-18.Has anyone tried this? What is the stock fuse and which specifications should I order if I want to replace it?
Manual
I do not have a copy of the manual. Does anyone have one in PDF and can PM it to me?
Thanks in advance!
November 12, 2019, 05:54 PM #1626
November 17, 2019, 06:45 AM #1627
Thank you!
Bumping thread again if anyone can answer my questions.
I also have an additional one: I have my eyes on a SL Audio e112 sub-woofer that has line in and line out, via an internal Linkwitz–Riley cross over.
Given the Job's sensitivity would it be possible to have the set up as PREAMP > SUB CROSSOVER > JOB 225?
November 17, 2019, 09:46 AM #1628
I have had the Job 225 amplifier a couple times. I always felt it was a great little amp, a real bargain. When I have had it I used Rothwell's with it which seemed to help.
November 17, 2019, 12:16 PM #1629
November 17, 2019, 03:33 PM #1630
- May 2013
- 3,245
I've owned both the Job 225 and it's sibling the Nuforce STA-200 which is even more sensitive. Looking at the options available for gain using the RCA (Cinch) connections you should have no problem finding one of the available settings that will work without the Rothwells. In fact all of them should work except the highest one.
November 19, 2019, 03:20 AM #1631
Not mine, but an interesting offer: Goldmund Job 225 + pre
€ 1.600,00
http://link.marktplaats.nl/m14831472...=socialbuttons
Verstuurd vanaf mijn LG-H870 met TapatalkSynology DS112 - microRendu + LPS-1 - Job INTegrated - Penaudio Cenya
November 19, 2019, 12:43 PM #1632
Too bad that Goldmund has decided to stop producing the Job amplifiers. They are darn good amplifiers and a great value.
November 21, 2019, 11:52 AM #1633
Hi all again,
I finally received the Amp.
The speakers are getting delivered tomorrow so I cannot test it yet.
However the power LED is not turning on when I flip the switch.
I do hear the relay switch.
Does anyone know what could be the problem? Could the led have come loose during transport?
Kind Regards,
Adriano
November 21, 2019, 01:33 PM #1634
Adriano
Maybe you could open up the amp and see if the LED light is hooked up. Maybe the connection came loose.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
November 21, 2019, 05:17 PM #1635
November 21, 2019, 05:29 PM #1636
November 23, 2019, 07:53 PM #1637
Good news. It was indeed the LED that had come loose. No issue with the wires, just the glue that holds the LED in place got unstuck.
I placed the LED back for now but I am not sure how to glue it back on. What kind of glue can be used inside an amp?
The Job225 sound great for now. I have not set up my system as I am about to move into a new flat.
I will experiment with power cables and the fuse swap and report back.
November 23, 2019, 08:10 PM #1638
Congratulations!
So there was glue that held the light in place and it came loose? Maybe to make it easy, just use a piece of black electrical tape and stick it on or get an epoxy glue. Epoxy glue usually comes in a 2 part mix. Some are slow working and some are fast working. I’m sure you only need a dot of glue. Something called Duco cement which is a clear liquid should work too. Ask your local supply store.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
February 16, 2020, 11:55 AM #1639
- Jun 2016
- 25
Could anyone point me to a person/business in the U.S. that could repair the Job equipment? I have a JobInt that has a burnt Mosfet, and don't want to ship it back to Goldmund, if possible. Thanks,
February 16, 2020, 01:18 PM #1640
Please try and contact service@jobsys.com
They might be able to point you in the right direction. Sorry you are having problems.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
I am still having trouble with the metadata with my Lumin L2. Now half of the album cover images of my library have suddenly disappeared from the Lumin app. However when playing a song from an album,...
Lumin L2 not grouping album songs...
