Results 101 to 104 of 104
Thread: Measuring AC Power Line Noise
June 12, 2020, 11:16 AM #101
- May 2017
- Cleveland, Ohio, USA
- 534
Re: Measuring AC Power Line Noise
Hold on. I just wrote:
the Trifield EMI meter measures (higher frequency) noise voltage fields in the air.
So I went to the Trifield page:EM100 - Power Line Monitor - TriField
And that's not how EM100 Power Line Monitor works, it connects directly to the AC line!!!
it:
It immediately displays total line noise in millivolts peak to peak (range 1999.9 mVp-p, resolution 0.1 mVp-p) in the frequency range 10 KHz – 10 MHz
10 kHz is in the noise frequency range of concern.
can't find the users manual for that model.
June 12, 2020, 12:01 PM #102
- Jun 2020
- Virginia
- 3
June 12, 2020, 12:04 PM #103
- Jun 2020
- Virginia
- 3
Thanks for the reply. I built my home and had three dedicated lines with separate ground installed in my music room. When I measured them with the Trifield meter they were only marginally "quieter" than my regular outlets. All my outlets seem to be pretty "quiet," though so I am satisfied.
June 12, 2020, 12:22 PM #104
- May 2017
- 534
Much of the lower frequency current line noise is generated by big power amplifiers with linear power supplies.
While audio components with SMPS (supplies) may generate higher frequency noise or be very quite.
Most nearby modern high tech lighting, appliances, HVAC and other date & entertainment equipment will also have a SMPS and often generate a lot of noise. But you can simply test them for audible noise by turning them on/off one at a time.
Thanks! I got confused by the sentence that "the DAC is just a SW algorithm on an FPGA". The actual conversion to analogue still happens outside the FPGA in the discrete component part... the unique...
