Results 51 to 79 of 79
Thread: Magico SPOD - New!
March 31, 2017, 11:21 AM #51
- Sep 2016
- 901
Re: Magico SPOD - New!
That makes sense as the M3's and MPro have greater resolution and would be more sensitive to distortion compared to the S Mk2 series. Also the combination of their weight and the larger MPod feet come into play.
Given the S Pods are designed to work with weights ranging from the 43kg (S1 Mk1) up to 190.5kg (Q5), they should work well with the S1 Mk1/Mk2 and S3 Mk1/Mk2, however they would be operating in the middle of their weight range with the S5 Mk2's. Hence the improvement might be slightly greater .Last edited by Melbguy1; March 31, 2017 at 12:39 PM. Reason: correction
April 2, 2017, 01:43 PM #52
April 2, 2017, 10:51 PM #53
- Sep 2016
- 901
My next audio purchase will be a set of S Pods . Since my S5 mk2's are still on their coasters I thought I might as well buy them now so I don't have to go through that exercise twice. I'm not sure when that will be, but I will report my findings when we have them installed.
April 5, 2017, 10:48 AM #54
- Apr 2017
- Australia
- 1,763
April 5, 2017, 10:54 AM #55
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
April 5, 2017, 11:05 AM #56
I was about to mention that the MPods with the pin in them will sound different from the regular spikes.
I'm not sure I agree that you need a hydraulic jack to lift them though. They aren't that heavy - at least not compared to my MPros and I can insert the pins in my MPods (isn't necessary a 2 minute task but I can still do it...)Speakers: Magico M-Project w/MPods
Amps: CAT Legend -> CAT JL7s
Analog: Kronos Pro Limited Edition / Black Beauty tonearm / Zyx Universe Premium, Ortofon A95
Digital: Roon->Vivaldi DAC/Upsampler
Cables/Power: Kubala Sosna Elation ICs & SCs / Shunyata Denali 6000T & PC's / Furutech outlets
April 5, 2017, 11:26 AM #57
- Apr 2013
- Valrico, FL
- 408
Hmm... what is the recommended procedure for MPOD pin reinsertion?
Howard
Pass Labs XS 300's, XS Pre | Berkeley Audio Design Alpha DAC Reference Series 3, Alpha USB Series 2 | Aurender W20SE, ACS10 | Magico S7's with MPOD's, QSub 15 x 2 | Shunyata Denali 2000T x 2 with Sigma HC | Shunyata Everest 8000 w/ Omega XC | MIT Heritage and Oracle Interconnects and speaker cables | Critical Mass Maxxum rack
April 5, 2017, 11:41 AM #58
April 5, 2017, 12:49 PM #59
Installed my SPOD's today. IMMEDIATELY noticed a better focused, tighter midrange.
Bass tightened up too.
Will remove the Herbies now to try.
April 5, 2017, 01:44 PM #60
Bud
Sony XA-5400ES SACD
April 5, 2017, 01:47 PM #61Bud
Sony XA-5400ES SACD
April 5, 2017, 02:09 PM #62
- Feb 2017
- 65
The Herbie is the saucer, yes. It's a decoupling carpet glider. Works pretty well considering the price. It was bettered in my system only by the Townshend Seismic Podium. My seismic podium is only rated to 190 lbs, so an S5 mkii isn't going to do anything but fully compress it. Being that Alon seems to like things rigidly coupled to the floor with a damping layer in the footer instead of something like a Stillpoint, I'm thinking the SPOD might be better than the seismic podium.
April 5, 2017, 02:42 PM #63
I use the Herbies to simply help me move the speakers around the store easier. Sonically, better without them.
April 5, 2017, 03:03 PM #64
- Feb 2017
- 65
April 5, 2017, 03:03 PM #65My Systems: http://www.audioshark.org/showthread...481#post158481
April 10, 2017, 04:21 PM #66
Magico SPOD - New!
April 12, 2017, 11:45 PM #67
May 28, 2017, 01:03 AM #68
SPOD users, any update on their benefit?
Bud
Sony XA-5400ES SACD
June 14, 2017, 08:53 AM #69
- Apr 2017
- Australia
- 1,763
As of today my Q3 are now on SPOD. @kzhtoo Improvement is immediate and obvious. More bass articulation, more clarity and focus.
Exactly!
Add more resolution. Well worth the price of admission.
I also own MPOD so it was a no-brainer for me to pull the trigger on the SPOD.
January 9, 2019, 01:54 AM #70
- Apr 2017
- Australia
- 1,763
For the benefit of anybody who might be considering buying used SPOD.
Be aware the Magico SPOD press release "Direct installation on S1Mk II, S3Mk II, S5Mk II, V2, V3, Q1, Q3, Q5" might lead you to assume that SPOD is directly interchangeable between all those speaker models. They are not. The Mk2 speakers have a different thread pitch to the non-Mk2 speakers. So if you buy used SPOD that were installed on Q1/3/5, they will not directly fit S1/3/5Mk2. You will need to use a 3/8-16 Internal, 1/2-13 External, UNC, 1/2" Insert Length adapter such as this on the speaker. Or you will need to extract the threaded stud and adapter that is installed in the top of the SPOD body and replace it with the appropriate stud. This might be tricky as the thread adapter + stud are fastened in with loctite, you might get the stud out but not the adapter.
August 29, 2019, 04:13 AM #71
- Aug 2019
- NL
- 1
August 29, 2019, 10:44 AM #72
Thank you for joining, Invader.
September 1, 2019, 09:23 AM #73
- Oct 2017
- 175
September 1, 2019, 11:01 AM #74
- Apr 2017
- Australia
- 1,763
If it turns out you buy Spods with incompatible studs, they can be changed to the correct studs for your speaker at the factory.
September 1, 2019, 11:21 AM #75
Best to contact Magico. They will have the list of proper thread sizes.
December 8, 2019, 09:25 AM #76
- Jun 2019
- Switzerland
- 34
Hello,
In a few days, I’ll receive a pair of S3 Mk II.
I added a set of SPODs to my order.
I’m looking for the diameter of the floor protection chits?
I would like to add some Teflon glider patches, it’ll make it easier to move the speakers when adjusting placement.
Thanks for the help,
Cheers,
Thomas
December 14, 2019, 11:06 AM #77Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
December 14, 2019, 11:23 AM #78
- Apr 2017
- Australia
- 1,763
December 15, 2019, 03:01 PM #79
I made these for my A3s. Cheap and easy. The Teflon pads have a sticky tape on one side. Just place and press and your ready to go.Speakers: Magico S3 (23')
Streamer: HiFi Rose RS150b
CD/DVD: Oppo 205
VBR is not precise. Please ignore the bit rate display.
Lumin supports Plex
