Results 1 to 19 of 19
Thread: Bel Canto
  1. #1
    Bel Canto
    I'm currently looking to replace my parasound hint. The hint is a wonderful integrert amp, but on my speakers (kef reference 201/2) the vocals are somewhat back in the soundstage. So my "dealer" are recomending Bel Canto DAC 2.7 as both pre/dac and a ref500s as the poweramp. Anybody have any experience with both or either of them?
    Sent fra min SM-A510F via Tapatalk
  2. #2
    Bel Canto
    Welcome, KjetilA.
  3. #3
    Senior Member
    Join Date
    Aug 2016
    North Carolina
    Posts
    203
    Re: Bel Canto
    Yes...I'm a BC dealer. Will you have the chance to try them out to see what difference they make over the Parasound?
    Both are fantastic pieces of gear at their price points.
    Goldprint Audio -- Dealer For: PS Audio -- Leben -- KEF -- Line Magnetic -- DeVore Fidelity -- Joseph Audio -- Sugden -- Rogue Audio -- Manley Labs -- VPI Industries -- Bel Canto -- Alta Audio -- Tannoy -- Rega -- Kimber Kable -- Ortofon -- Chord -- Sonos -- Quadraspire -- Salamander -- SVS Sound -- Torus Power -- Audio Desk -- Gingko -- Auditorium 23 -- Box Furniture -- Krell -- Cary Audio -- Soundsmith -- EMT
    www.goldprintaudio.com
  4. #4
    Re: Bel Canto
    Hi! ☺️
    Well, kind of. My deal is that if I don't like them I can return them and we will try to find another solution. But I hope I don't have to because i then would have to send it back by mail since the store is a 5 hour driving away from me.
    Have you tested bel canto against parasound?
    And how would you describe the icepower compared to the todays standard of class D amplifiers?
  5. #5
    Senior Member
    Join Date
    Nov 2013
    Minnesota
    Posts
    1,369
    Re: Bel Canto
    You may want to just try an external DAC with the Parasound and see if it fixes what you don't like about it.
    I own a Parasound A21. And it is entirely different sound than Bel Canto.
  6. #6
    Re: Bel Canto
    Could you try to describe the difference?
  7. #7
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Re: Bel Canto
    Regarding Bel Canto amps their newest Ref600M mono amps are in an entirely different league of performance compared to their previous series which used the B&O ICE power modules. They're much more relaxed and refined with a higher degree of musicality compared to their earlier efforts.
  8. #8
    Re: Bel Canto
    Ok, but two of those cost four times more than the 500s. The question is, will I get a noticable upgrade in sound from what the parasound hint is able to deliver if I upgrade my system and replace it with dac 2.7 and ref500s?
  9. #9
    Senior Member
    Join Date
    Aug 2016
    North Carolina
    Posts
    203
    Re: Bel Canto
    Quote Originally Posted by KjetilA View Post
    That's really a hard question to answer....and ultimately only you would be able to answer it by listening in your system. There are likely very few members on the board that's had the chance to compare the two options back to back.
    I've heard the 2.7 and 500's a lot, but I've not really spent much time with the Parasound.
  10. #10
    Senior Member
    Join Date
    Apr 2013
    Lakeland, Florida
    Posts
    1,054
    Re: Bel Canto
    I sure love the way my DAC3.7, Pass Labs XP-20 pre & XA160.5 monoblocks sound!!!
    George
  11. #11
    Senior Member
    Join Date
    Aug 2016
    North Carolina
    Posts
    203
    Re: Bel Canto
    Quote Originally Posted by Audioseduction View Post
    The 3.7 and REFLink are a fantastic combo!
  12. #12
    Re: Bel Canto
    Quote Originally Posted by sheltie1 View Post
    Have you heard them both together? How would you rate them? Have you tried the dac 2.7 as a preamp, and if so, what did you think?
  13. #13
    Senior Member
    Join Date
    Nov 2013
    Minnesota
    Posts
    1,369
    Re: Bel Canto
    The Parasound A21 is a great amp in its price range. But it has some drawbacks. It has just a bit of grain to the high end. It could use more air and transparency. And it could use a bit more detail. It has brute force power. Bass is fast and well controlled. It can sound a bit etched at times. If specs told the whole story, this would one fabulous amp but spec's aren't everything. That being said, I still own one but I am letting my son use it as I have replaced it with a Pass amp.
    The Bel Canto's that I heard a little over a year ago, are more transparent with more air and larger sound stage. They were more refined. They were smoother or more liquid sounding from what I remember.
  14. #14
    Re: Bel Canto
    An update regarding the Bel Cantos. I have tested DAC 2.7 and ref500s, but they did not do it for me (and my system) so I sendt them back to the dealer. I just could not hear the major "lift" in the music that was promised by the seller, and could certainly not justify using over 6000$ on them.
  15. #15
    Senior Member
    Join Date
    Nov 2013
    St. Louis, MO, USA
    Posts
    3,067
    Re: Bel Canto
    Are you needing the DAC? My friend is a KEF dealer, one of the best combo I heard with the LS50 was them driven by a Cary SLY-80 integrated. Hagel has a decent integrated around $5800 but I can't remember if it includes DAC, the Cary does not. You might look at an Audio Alchemy set up, still Class D but some of the best I've heard at an affordable price, open, musical & smooth. In my opinion, the KEF need a true neutral to warm sounding amp, if to the other side of neutral or any grain/harshness the KEF will show it and will drive you crazy, or me crazy anyway But if you were willing to spend $6k it gives a lot of options.
    SVS PC13 Ultra
    Sony XBR-75X940D & BDP
  16. #16
    Senior Member
    Join Date
    Mar 2017
    North Carolina
    Posts
    810
    Re: Bel Canto
    Quote Originally Posted by Mr Peabody View Post
    The Hegel H360 does include a good DAC.
  17. #17
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    Re: Bel Canto
    it drives me bonkers when dealers recommend using the dacs as pre amps !!! yes they have volume controls and yes they sound ok as pre amps . BUT they sound HUGELY better with a good pre amp. I have used bel canto stuff for many years and many times have tried my bc 3.5vbs into my class A power amp [msb] . it sounds detailed but it lacks musicality .
    just add an arc pre or a modwright or any pre for that matter and you will get a huge uplift in musicality , soundstage and enjoyment
  18. #18
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,091
    Re: Bel Canto
    Quote Originally Posted by hifinutt View Post
    This dealer doesn't. No substitute for a good preamp.
  19. #19
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    Re: Bel Canto
    brilliant , good to hear . don`t get me wrong BC make fantastic stuff . practically every component I have had has had to be repaired but in over 10 years of ownership NOTHING has gone wrong with any of my bc stuff [ currently fm1, vbs , dac3.5]
Bel Canto
Posting Permissions
  • You may not post replies
  • You may not edit your posts
