Page 2 of 3 FirstFirst 123 LastLast
Results 51 to 100 of 109
  1. #51
    Senior Member
    Join Date
    Apr 2016
    Posts
    139
    Re: Racks - got any favorites?
    Here's some very cool racks out of Poland. The isolation system (although it takes a little time to understand) is ingenious.
    Think of a large radius bowl insert in the bottom of the shelf sitting on a free floating carbon fiber 'bullet' with a smaller radius dome on the top and a larger angle inverted cone on the bottom. This element in turn sits on a steel spike and is free to pivot in all horizontal directions similar, but different to the Symposium products. The shelves themselves are made of 3 layered composite MDF and HDF up to 50mm total thickness with decent looking veneers, and the price is right for what you get (but shipping and import duties may be problematic).
    http://www.rogoz-audio.com/en/produc...io-stands.html
    Kerry
  2. #52
    Senior Member
    Join Date
    May 2013
    Bucks County PA
    Posts
    3,704
    They make some nice looking speaker stands too ^^^^
    Brian
    Main System -
    Rotel RCD-1572 / Rega P3 > Luxman 505UX Mark II > Fyne Audio F502SPs > Synergistic Cables
  3. #53
    Senior Member
    Join Date
    Nov 2013
    Minnesota
    Posts
    1,369
    Quote Originally Posted by matt_zak View Post
    I use Lovan Sovereign Series. They make some nice speaker stands too.
    Lovan has gone out of business.
  4. #54
    Senior Member
    Join Date
    Nov 2014
    Ft. Worth, TX
    Posts
    309
    Crappy iPhone picture, but love my new Timbernation...
    Tannoy Westminster GR and ST-200 Supertweeter, Finale Audio 300B Mono's, Thoress Full Function Preamp, Thoress 845 Mono's, Found Music 2A3 Mono's, , Line Magnetic 219IA, Lumin A1, Lumin U1, EMM Labs DAC-2X, Lampizator Golden Atlantic DAC, Sansui TU-717, Kenwood KT-7500, Belden 8402 IC's, Duelund 16GA speaker wire
  5. #55
    Senior Member
    Join Date
    May 2013
    Silicon Valley
    Posts
    2,838
    Partial to the Mapleshade Samson line, but then again that is the only 'good' rack I have tried. Have one in my stereo, and two in the HT.
    They are solid maple with steel rods. My two channel rack, empty, weighs 500 pounds, which helps with vibration control.
    http://shop.mapleshadestore.com/Equi...epartments/16/
    Bud
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Three 20 amp circuits.
  6. #56
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Bud
    The Samson's are really good racks. They take Michael Green's original Just-a-rack concept to the extreme. I still have one of Michael's Deluxe racks I bought many years ago.
  7. #57
    Senior Member
    Join Date
    Jan 2017
    Leyden
    Posts
    596
    I own a Solidsteel H6 rack. But some of the shelves have started to bend. I might want to replace them. But with what? My first thought would be Birch multiplex or maybe Bamboo multiplex.
    I could go exotic and look for Lexan or simular.
    But I'm not sure. Any Tips? How thick?
    Also thinking about putting some sand or something inside the legs of rack and replacing the spike with maybe the cheapest Ansuz darkz.
    So many options. Any tips would be welcome.
    Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
  8. #58
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Do you want to replace the whole rack or just the shelves?
  9. #59
    Senior Member
    Join Date
    Jan 2017
    Leyden
    Posts
    596
    Just the shelves, a whole new rack would be too expensive.
  10. #60
    Quote Originally Posted by annapolis Raider View Post
    Been using Artesania for years, never even tempted to try anything else.......
    Do you have the Prestige or Exoteryc? Curious how much of a difference there is between the two.
    Allen
  11. #61
    Quote Originally Posted by BayStBroker View Post
    Rix Rax are priced very fairly, especially when you consider that he will customize whatever you want at no extra charge and builds it all by hand. http://www.rixrax.com/ Bobocalune also has a sweet set. Mine is below.
    I contacted Rix Rax and it seems they are winding down that business.
    Allen
  12. #62
    Senior Member
    Join Date
    Apr 2013
    Toronto,Ontario
    Posts
    4,978
    Quote Originally Posted by socfan12 View Post
    Welcome back Allen.
    Paul
  13. #63
    Senior Member
    Join Date
    Aug 2014
    east of Seattle
    Posts
    821
    I'm sort of in an 'anti-rack' spot where I have all my gear setting on Herzan TS series active isolation shelves. my preamp and dac are stacked on a TS-150 and my tt sits on a TS-140.
    I'm using the Adona GTX which is a fine, modestly priced grounded rack. but as long as a rack is solid, the Herzan does not care what it sits on......and active just kicks ass.
    you can spend more than I've spent for active on passive racks, but I would not do that.
    if I wanted a great sounding passive decoupling rack my list of most desirable racks would have Artesania Exoteryc at the top ($10k + or - depending). it seems to eliminate all the limitations of racks by eliminating the actual shelf (and even needing footers) and does not just attempt to isolate, it really does it. but it puts on no airs as pretty. it's a tool. but WAF is a non-issue as I'm in a separate building from my house.
    I owned a large array of the GPA Monaco years ago and got very tired of changing those pads every 6 months. I had boxes and boxes of those pads but was always missing just the right compliance. and turntables had mixed reactions to the GPA Monaco, even the GPA TT I had.
    the prettiest racks I've seen are the Burmester racks. elegant as hell with the right looking gear.....great for system pictures. but they are just pretty.....and more furniture than helping the performance. not my deal.....but YMMV.
  14. #64
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    I think its a really good question
    Quote Originally Posted by Devg View Post
    I have a question - lot of the racks that are recommended are sometimes more than the price of the entire electronics that hold them for some of us
    what is the recommended approach when buying a rack ? for example, if you need a rack that holds $10k worth of electronics, how much should you spend on the rack and what to look for ?
  15. #65
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    And by the way i have Finite Elements Pagode with Cerabase
    But i also like the look and idea of the Artesenia.....Although i dont think its possible to do comparisons at home with different racks on loan from dealers, at least not here in Denmark.
  16. #66
    For real? They were/are my favorite wood racks & absolutely unique and iconic. Super nice guy too .
  17. #67
    I own the Exoteryc 3 + 3. No experience with the Prestige. The purchase of the Artesania was an impulse thing. I was looking at other gear at the time, noticed this rack. The rest is history...... Racks, in general, are getting AWFULLY expensive. There are real differences even among the most expensive ones. I have no idea how someone would navigate through the choices. For me, its 1) Artesania and 1b) GPA. Like Mike L, I also have a Herzan which is a completely new discussion.
    Turntables: Acoustic Signature Invictus Jr. NEO, Grand Prix Monaco V3.0
    Tonearms: Acoustic Signature TA-9000 NEO, Kuzma Safir
    Cartridges: Miyabi Fuuga, Ortofon Century, Murashino Sumile Mono
    Phono Amplifiers: CH Precision P1, Channel D Lino 3.3
    Digital: CH Precision C1.2/D1.5/T1, Innuos Statement Nextgen, Luxman D-10X (Loan)
    Amplifiers: CH Precision L10/M10, Parasound JC1+, Gryphon Diablo 333 (Incoming)
    Speakers : Magnepan 30.7x, Wilson Audio XVX Chronosonic/Subsonics
    Cables: CAD Ground Controls/USB, Cardas Beyond Clear, Gobel Lacorde Statement
    Accessories: Artesania Exoteryc Racks & Damping Plates, Seismion Reactio, Degritter RC, RPG Acoustic Treatments/PSI AVAA, Torus Power/Plixir Elite BAC
  18. #68
    Quote Originally Posted by Melbguy1 View Post
    Unfortunately yes.
    I think TechDas recently OEM'ed Artesania to do their TT racks.
    Anyone know the brand shown in this pic? Love the looks:
    Allen
  19. #69
    Senior Member
    Join Date
    May 2013
    Poland
    Posts
    1,762
    This:
    Adam
    Speakers: Magico M3
  20. #70
    Adam, I intuitively know the M Rack should work well, but I just can't reconcile the look of it. I think it looks too Erector set or Ikea flat pack..
  21. #71
    Senior Member
    Join Date
    May 2013
    Poland
    Posts
    1,762
    No prob, I got you covered:
    YG aluminium rack
    Adam
    Speakers: Magico M3
  22. #72
    IDK, I think it's nice looking. Reminds me a little of the Finite Element Pagode racks.
    I think the rack itself is 500lbs of Copper and Aluminum!
    Allen
  23. #73
    This would be my favourite. Mike Latvis had a prototype of the VXR at AXPONA last year.
    http://avisolation.com/vxr/
  24. #74
    Adam, that rack belongs in 2001: A Space Odyssey, but it does look like a weapon!
  25. #75
    Quote Originally Posted by tunes View Post
    Looks interesting... Any idea how much it would cost (starting price)?
  26. #76
    Quote Originally Posted by kkfan View Post
    Prices range from approx $7k for an amp stand up to about $31k for a 5 level rack! .. so way out of my league . I find my current Taoc ASR racks with upgraded SCB-RS-HC shelves, FE feet and Stillpoints Ultra footers do a great job, hence upgrading my racks is way down my list of priorities. Though if I were in the market today for new racks, I would go for CMS QXK racks.
  27. #77
    Has anyone seen the new Wilson Benesch R1 rack? Price? Don't ask!
  28. #78
    Senior Member
    Join Date
    Sep 2014
    Regina, SK, Canada
    Posts
    232
    We build our own custom racks with maple and machined brass footers and top caps. Here's one installed yesterday for a customer. 4" thick bottom shelf and 2" thick for the other three. Note the Melco N1A feeding the Bel Canto Black ACI600 integrated. He absolutely loves this piece.
    Everest Audio
    www.everestaudio.com
    Facebook
    bel canto, Hegel, Vimberg, Opera, MoFi, Acoustic Energy, JL Audio, Innuos, Vertere, Meze Audio, Origin Live, GutWire, Wireworld, Furutech, IsoAcoustics and more
  29. #79
    Senior Member
    Join Date
    Mar 2016
    Calabasas CA
    Posts
    108
    I keep looking at those HRS racks. Is there anyone here that is or knows of a dealer they would recommend ?
    Kronos Sparta / Miyajima Madake / New Audio Frontiers Stradivari Phono / Taiko Extreme / Aqua Acoustics Formula XHD / Townshend Allegri Reference / New Audio Frontiers Reference 845 Mono SE / Marten Coltrane Soprano / Artesania Audio Exoteryc rack / Daiza Isolation
  30. #80
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Quote Originally Posted by RichardA1 View Post
    I've been thinking of picking up the line. I've had several calls with Mike at HRS.
  31. #81
    Senior Member
    Join Date
    Mar 2016
    Calabasas CA
    Posts
    108
    Great news Mike. I've been looking at the RXR. It looks like you can take your isolation platforms and just place them on to the rack, also upgrade them if you want. Pretty simple and looks nice too.
  32. #82
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Howard (Sandman) and I have been talking racks for weeks. I like your plan.
  33. #83
    I liked the analysis done here, he finds that different racks sound different at different levels. Some sound the best at top level, and some at the bottom. The sound ranges from too tight to lose. Also where you position the feet of the component, whether in the centre or towards the outer edges, matters. http://www.hifi-advice.com/blog/revi...ryc-audiorack/
  34. #84
    Senior Member
    Join Date
    Oct 2013
    Sacramento
    Posts
    1,129
    Quote Originally Posted by bonzo View Post
    Really???? Thanks for that. I was already having trouble sleeping at night worrying about footer placement.
  35. #85
    i have hi fi racks limited -- very happy with all aspects of the product -- including the all wood material and attractive design, which means it is allowed to go in the living room!
    ' hifiracks.co.uk '
  36. #86
    Quote Originally Posted by mhanc View Post
    ' hifiracks.co.uk '
    They do look nice Mhanc & I would dare say should Nhanc the WAF as you suggested .
  37. #87
    Senior Member
    Join Date
    May 2013
    Poland
    Posts
    1,762
    MSB rack
    Adam
    Speakers: Magico M3
  38. #88
    Senior Member
    Join Date
    Apr 2017
    Central FL
    Posts
    793
    There's lots of really nice racks out there (many already mentioned). I talked to the designer of HRS at a Capital Audiofest but was not close to being ready at that juncture. I had Salamander Synergy at the time, which now is in a back-up system. Right before my current move a few years back, I designed the specs and sent it to Klaus at Odyssey audio (as I needed something specific for the screen height - pic below). One of my favorites (which I've seen at shows), is the Kanso furniture - http://kansoaudiofurniture.com/
  39. #89
    Join Date
    May 2017
    Seattle, WA
    Posts
    31
    I built my own suspended audio rack. The basic frame is of birch wood. At the top, I have threaded rods the hanging down. The bracket holding the rods is isolated by Harmonic Resolution pucks. I don't have shelves, but, instead, I have wood staves with holes at both ends for the threaded rods. The components sit between the two staves, front, and back. The TT sits on a marble slab isolated by Harmonic Resolutions pucks. I can put a glass of water on the platter of my TT, jump in front of it and there is no ripple. The nice thing about this rack is the staves holding the components are infinitely adjustable.
  40. #90
    Senior Member
    Join Date
    Apr 2013
    Staten Island, New York
    Posts
    703
    Quote Originally Posted by JPM View Post
    Got any pics???
    Paul
    Tape Deck Otari 5050B II2
    Music Server: Aurender N100H
    SSP: Marantz AV8801 Cables: Wireworld Electra 7 (P) Wireworld Silver Eclipse 7, Shunyata Delta NR (I) Wireworld Silver Eclipse 7 (S)
    Wireworld Platinum Starlight 7 (USB)
  41. #91
    Senior Member
    Join Date
    May 2013
    Poland
    Posts
    1,762
    I've seen it in Munich. aluminium + carbon fibre
    Looked great but the price ... 6k EUR per shelf If I remember correctly.
    Adam
    Speakers: Magico M3
  42. #92
    Junior Member
    Join Date
    Oct 2016
    Bay Area, California
    Posts
    15
    I have tried several racks and landed on (for now):
    Stillpoints ESS rack: great sound and the infinitely adjustable shelf height is very cool. Sound with Ultra SS feet is top quality. Easy to change shelf height if you are swapping gear a lot. Cool machined aluminum look.
    Grand Prix Audio Monaco Modular: sounds amazing and slightly less $ than the ESS, and a completely different aesthetic. Fixed height, but modular shelfs.
    Grand Prix Audio Silverstone F1: My top pick, by far. Out of this world good, but also the most $$$. Variable shelf height, but it takes a bit of effort to change shelf heights.
    Be mindful with any 3 point rack, if you have deep equipment that has the power plug in the center, the plug will sometimes run into the rear rack post.
    I do feel that many people do not make isolation and dampening enough of a priority. Huge gains from a good rack.
    my 2 cents,
    Noah
    I work at:
    Sound Innovations Home Audio
    High End Home Audio in Union City, CA
    Current Home setup:
    Magico M3
    Constellation Pictor w/ DC Filter
    Constellation Centaur II
    Chord DAVE DAC
    Aurender N10
    Valhalla 2 USB
  43. #93
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    FWIW - the most popular rack used at Munich 2017, by a country mile, was:
    http://www.artesaniaaudio.com
  44. #94
    Join Date
    Oct 2015
    Chicago, IL
    Posts
    67
    I currently have a Solidtech Duo3 and use still points under all components. Currently exploring options from Grandprix and Critical Mass as I've outgrown the shelf space on my current rack. Leaning towards the CM Sotto Voce setup with the black sapphire shelves.
    Main System:
    Speakers: Magico S3 MK1 | Amp: Boulder 1160 | Pre-Amp: Ref10 | Digital: DCS Vivaldi 3/4 stack & esoteric K07x | Phono-Pre: ARC Ref 2se | Phono: AMG Viella w\ 12JT & Benz LPS cart.
    Living Room:
    Speakers: KEF LS50 | Amp: Primaluna Prologue Premium | Digital: Lumin D2
  45. #95
    Senior Member
    Join Date
    May 2013
    Poland
    Posts
    1,762
    One can only hope their technical skills are better than their language skills
    I have taken this pic in the loo during Munich High End Show.
    Adam
    Speakers: Magico M3
  46. #96
    Senior Member
    Join Date
    Jul 2013
    Florida
    Posts
    3,848
    There were a few Artesanía racks recently at Axpona. The Vivid room had an impressive Artesania rack with amp stands.
    _______________
    Phono Pre: Pass XP-27
    Speakers: MBL 101E MKII
    Rack: Artesania Exoteryc
  47. #97
    Senior Member
    Join Date
    Sep 2014
    USA
    Posts
    3,381
    Quote Originally Posted by Ritmo View Post
    Yes, these racks were very nice in the Vivid room. It was nice meeting you, Mike, at Axpona!
    Best,
    Ken
  48. #98
    Senior Member
    Join Date
    Jul 2013
    Florida
    Posts
    3,848
    Likewise Ken!
    _______________
  49. #99
    Long time Artesania owner here, will field questions....
  50. #100
    Quote Originally Posted by Elberoth View Post
    They are spanish...but as a fellow spaniard I think it´s no excuse in this day and age to put up a poster with such glaring grammatical errors, I find it bewildering that some spanish audio companies don´t have their website in spanish, only in english and sometimes with spelling mistakes that hurt the eye, it´s like going to the Oscars gala with a shirt full of stains. If you´re amongst the top rack companies in the world charging thousands of Euros for your products, spend a couple hundred and get your stuff professionally translated for the love of god, but hey maybe I´m too picky.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
