Results 1 to 21 of 21
Thread: Avantgarde Zero TA
January 7, 2017, 01:59 PM #1
Avantgarde Zero TA
One of the hot speakers I'm hearing about at CES is the new Avantgarde Zero TA. Add a sweet tube amp and go! $15,500
http://www.avantgarde-acoustic.de/de...sheet_engl.pdf
January 7, 2017, 02:47 PM #2
Re: Avantgarde Zero TA
Thought you would have made it to CES Mike ......
January 7, 2017, 02:55 PM #3
January 7, 2017, 07:58 PM #4
Digital: LH Labs Source (someday...) + LH Labs Geek Pulse SFi
Analogue: Audio Technica OC9ML/ii + Technics 1200SL + Nikko Beta 40 (phono only)
Wyred 4 Sound STP-SE
First Watt F6
Focal 816VW Special Edition
January 8, 2017, 04:50 PM #5
Avantgarde Zero TA
I've got a pair of Avantgarde TA's on order. White this time. Now I need to think of a sweet little amp to pair them with. Would love a 300b integrated with a built in DAC that I could pair with an Aurender N100H. Or maybe Aurender A10 with Pass XA25? Hmmm....
I think these are going to be very popular.
January 8, 2017, 06:59 PM #6
- Oct 2013
- Sacramento
- 1,129
How do they get connected? The text confused me and connection points seem to be under covers.
January 8, 2017, 07:29 PM #7
January 8, 2017, 07:56 PM #8
- Oct 2013
- Sacramento
- 1,129
Thanks Mike. That is what I thought but the Fact Sheet mentioned optional XLR connections.
January 8, 2017, 09:33 PM #9
USB is ONLY connected so they can EQ the bass on the laptop at the show.
January 8, 2017, 09:40 PM #10
- Oct 2013
- Sacramento
- 1,129
Mike, Thanks for the pictures. But why the XLR connection and input selector switch? There is no power delivered via XLR. Does the on-board amplifier power all drivers? I thought it was only for the bass driver. That was the reason for your comment about needing a sweet tube amp.
January 8, 2017, 10:03 PM #11
Avantgarde Zero TA
You definitely need a nice little low watt amp for mid and tweet. XLR for Hi/low level input for woofer. To have the choice...they have always done this. Uno, duo & trio have also.
January 8, 2017, 10:16 PM #12
- Oct 2013
- Sacramento
- 1,129
I get it now (I think). Speaker cables always required for the mid and tweeter. Input for the bass can be either speaker cables or XLR.
January 8, 2017, 10:17 PM #13
Avantgarde Zero TA
January 8, 2017, 10:46 PM #14
Jadis or Pass Mike. Either could be a delicious combo.
_______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
January 9, 2017, 08:10 AM #15
January 9, 2017, 09:40 AM #16
- Feb 2014
- 477
Air Tight ATM-300?
Mike, you should request that they make proper stands (with the knurled knobs for rake adjustment) instead of the current ones, which do not even allow for spikes (only furniture sliders).
January 9, 2017, 09:46 AM #17
January 9, 2017, 09:53 AM #18
- Feb 2014
- 477
Neither did I but one wonders if the performance can be enhanced using similar stands like the UNO XD. The current stands are not as rigid.
January 9, 2017, 10:00 AM #19
January 9, 2017, 06:25 PM #20
- Jan 2014
- Los Angeles
- 1,775
hard not to go tube with AG - try the one with the least amount of noise?
June 3, 2017, 08:26 AM #21
They are making good impression in Portugal Avantgarde dealer, he got one pair to it's own system! I thin that the fact that there is no crossover to mids and the woofer beeing amplified makes all the diference.
https://www.facebook.com/ultimateaud...type=3&theater
