Results 51 to 57 of 57
Thread: Lampizator Golden Atlantic DAC
June 15, 2017, 04:14 PM #51
Re: Lampizator Golden Atlantic DAC
2 Channel Stereo :
June 15, 2017, 05:50 PM #52
- Sep 2014
- 766
He is incorrect that most of the GG magic has worked its way in to GA. That is true if you are listening to simple music. The dynamics, separation, scale, extension, and bass in the GG differentiates itself a lot the moment you put in orchestral. Also the tubes add much more drive and dynamics, so I disagree with his drive points. Tube rolling matches gain, and once the gain matching falls in place with the pre and power (something analog guys do on a regular basis), the drive, dynamics, jump goes up considerably.
June 15, 2017, 07:44 PM #53
Big mistake not to get the DSD512 chipless module, given he is a DSD lover.
He thinks its about the 512 capability (which only has value in upsampling). However, its a more elaborate DSD implementations and beats the DSD256 engine at every DSD playback rate.NORMAN
June 16, 2017, 07:16 PM #54
I'm a little confused about the DSD engines, of which there seem to be three. The default is chip based DSD256. The R2R PCM implementation would seem to be different, but it is hard to see how the resistor ladder would work with single-bit music data (DSD). Finally there is DSD512, which I agree sounds best, even with SACD quality DSD. I've heard it describe as chipless. Does this mean it is a hand-coded FPGA akin to the Ted Smith implementation in the PS Audio Directstream?
Magico M2
AMG V12 (Teatro cart)
Lampizator Atlantic Plus DSD512
Aesthetix Calypso Signature Preamp
Luxman C-900u Preamp
Auorasound VIDA (phono-stage)
Parasound JC 1+ monos
Aurender N100h
Nordost Frey 2
HRS, Rix Rax
June 16, 2017, 07:35 PM #55
Bay, there are just 2. There is a mini-chipless DSD256 engine dependent on the R2R pathway and an optional full blown independent "chipless" that does 512. The difference really is that the optional one is much bigger/more elaborately implemented.
No FPGA decoding, just elaborate filtering and as the website says, no additives, no preservatives!NORMAN
April 4, 2018, 11:27 AM #56
Did I read correctly somewhere that there is actually a preamp section of sorts in the GA, if equipped with the volume control? As compared to the A+ w/ volume control just being a simpler attenuator vc??
April 4, 2018, 05:36 PM #57
While it is technically an active preamplifier, in so far as all passive parts occur before the tube amplification stage, the Golden Atlantic shares the same volume control as the regular Atlantic.
The Pacific however enjoys a new upgraded volume control solution.Purpose Built Listening Room: Intuitive Audio Design Gamma Summit Speakers, Gallo CLS-10 subwoofers (2), LampizatOr Pacific, LampizatOr Super Komputer, Musical Concepts Haffler DH-500 (Ultra Elite package), Theorem Acoustics Wave bridge power conditioner, Cables by Theorem Acoustics, Dynamic Deisgn & cables, Verastarr. Room design by Dale Pitcher.
Family Room Rig: Vapor Audio Stiff Breeze, LampizatOr Golden Atlantic, LampizatOr Super Komputer, Musical Design D-75B (with John Hillig's PA-6 upgrades), Pi Audio Uberbuss, Dynamic Design reference cables, Danacable USB.
Industry Affiliation............North American Distributor of LampizatOr Audio.
www.lampizatorna.com
Clarisys Arrives at Puur...
