Results 51 to 61 of 61
January 31, 2017, 08:08 AM #51
- Oct 2015
- 33
January 31, 2017, 08:45 AM #52
Re: Finally setup my Triode Corporation TRX-M845 Monoblocks ....
February 3, 2017, 08:10 PM #53
- Jul 2015
- 15
One of my Triode TRX-M845 amps went dead last night. Can anyone help with where i can find the location of the fuse and what spec it should be
Thx Brett
February 3, 2017, 08:20 PM #54
- Mar 2015
- 100
yeah that happened to me last week - very easy fixT2
directly below the socket for the power cord - just use a flat blade screwdriver
you need a T5AL 250V
February 4, 2017, 01:26 AM #55
- Sep 2016
- 901
I'm guilty of blowing the fuses in my Vitus cdp also about 6 months ago. Silly me forgot to switch off the power while I was jiggling around the power cable to my player, which in turn caused an arc. But after swapping out of the two slow blow fuses, cleaning the carbon smell off the contacts & a precautionary check with my High End AE, all was well again. Actually I plan on upgrading the fuses to some nice Telos fuses shortly just 'cause i'm a mad audiophile! .
February 4, 2017, 07:30 PM #56
- Jul 2015
- 15
February 25, 2017, 10:46 PM #57
- Jul 2015
- 15
On the 845 tube you have the nipple protruding from the side just above the pins to assist with installing the tube.
Can i still use the tube if the nipple is missing?
February 25, 2017, 11:02 PM #58
- May 2013
- 3,243
It's just a guide pin for ease of installation. No other function.
February 25, 2017, 11:18 PM #59
- Jul 2015
- 15
Thankyou
April 11, 2017, 05:38 AM #60
- Jul 2015
- 15
I see you have your Triodes f/s on Audiogon Joe
April 11, 2017, 08:49 AM #61
Hi Brett,
Yes, thought I'd see if anyone else wants to enjoy these wonderful amps. My solid state gear is on almost all the time. I don't do that with these babies, so I have to plan my listening sessions.Last edited by joeinid; April 11, 2017 at 08:52 AM.
The Esoteric rep from Japan was at the show. He said they were thinking about building a Grandioso level network transport in a way which leads you to believe they were actually doing it. If you...
