Results 1 to 13 of 13
October 6, 2016, 04:27 PM #1
What are your favorite vacuum tube dampers?
I'm researching getting some tube dampers for my BHK amps.
I was recommended to get the Audio Research (part #20004660) tube dampers. Any thoughts?
There's not a lot of clearance/room in the back of the amp but more than enough for rubber rings for sure.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
October 6, 2016, 04:42 PM #2
- May 2013
- 3,242
Re: What are your favorite vacuum tube dampers?
Joe
Try Herbies.
http://herbiesaudiolab.net/preamp.htm
http://herbiesaudiolab.net/rx.htmMain - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
October 6, 2016, 04:43 PM #3
Thanks Jack. I'll have to see if I have enough room in the back of the amps for those.
October 6, 2016, 05:22 PM #4
Joe.......What exactly are you hoping the tube dampers will do for your BHK amplifiers?
Dan
October 6, 2016, 05:28 PM #5
October 6, 2016, 05:40 PM #6
- May 2013
- 3,242
Joe
Since you don't have to worry about little prying hands you can leave the covers off if you have to.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
October 6, 2016, 05:45 PM #7
Joe.......Okee dokee. It will be interesting to discover what "benefit" appears. I know Audio Research uses the silicon dampers on their small tubes. I am curious why there are so many other highly respected tube component manufacturers who choose not to add dampers. I have read a fair amount of personal testimony from individuals who use dampers, some reporting hearing no difference, some reporting a slight improvement in resolution, and some reporting a reduction or clouding of resolution, particularly in relation to where the damper is located on various tubes. I will be waiting to read your impressions.
Dan
October 6, 2016, 05:50 PM #8
Thanks Dan. I've never "added" tube dampers where non existed on previous tube amps.
Herbie's dampers seem better engineered and here is a description, according to Herbie, of the benefits and disadvantages of the various dampers.
http://herbiesaudiolab.net/ultrafq.htm
Q: What's the advantage of Herbie's dampers over other kinds of tube dampers?
http://herbiesaudiolab.net/compare.htmLast edited by joeinid; October 6, 2016 at 05:53 PM.
October 7, 2016, 04:33 AM #9
Joe,
Herbie's all the way. LoLNORMAN
October 7, 2016, 04:33 AM #10
Px4s flanking the RCA 1944 WW2 5r4gy...the special one.
NORMAN
October 7, 2016, 07:54 AM #11
The only tube dampers I have ever heard work are these:
http://www.thetubestore.com/Parts-Ac...ura-Tube-Rings
The only advantage of the Herbies are they are more forgiving of the size of the tube, but I found they just don't fit tight enough to do much good.Dan Santoni
www.dtsaudioelectronics.com
www.blackdoghifi.com
October 7, 2016, 08:43 AM #12
- Feb 2016
- west Michigan
- 713
Everyone has their opinion on tube dampers. It seems to me that teflon/rubber type doughnuts, while effective in minimizing resonances, create a hot ring around the tube where they contact. And to a lesser degree disrupt the natural cooling air flow up the tube envelope. While this probably is not of major concern with small signal tubes, however with rectifiers and power tubes it is a different story. Both of these are avoided with Herbies dampers.
The benefits of tube dampers has been known for a very long time. Particularly, in the early days, to tame microphonics. I have collected an assortment of vintage tube dampers dating back to approx 1930's. Many ideas have been tried.
I personally find the Herbies provide the best of both vibration control of the glass envelope (both internally and externally induced) while maintaining natural air flow for cooling. YMMVMy System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
October 7, 2016, 09:32 AM #13
Herbie rules!
NORMAN
