Results 51 to 93 of 93
Thread: Lumin NOW works with ROON
March 10, 2017, 02:28 AM #51
Re: Lumin NOW works with ROON
For anyone who has already got Roon running with Lumin, it may be a worthwhile experiment to try out the Roon PCM->DSD upsampling - DSD128 for S1, DSD64 for A1 / T1 / D1. See if it sounds better or different or not. Please be aware that Roon by default applies -6dB for this conversion (-3dB in DSD Gain Adjustment and -3dB in Headroom Adjustment), which can be adjusted (note: watch the headroom management indicator if you do that).
For those who want to compare Roon upsampling with Lumin built-in upsampling, please note that after you adjust the Lumin app resampling settings, please play a music using Lumin app, before switching back to Roon, otherwise the changed resampling setting may not take effect.Peter Lie
LUMIN Firmware Lead
March 10, 2017, 06:39 AM #52
March 17, 2017, 06:45 PM #53
Hi Peter.
For three days I have a trial version of Roon with the Core installed on a PC (without audio optimization), which connects to the same switch as the NAS. After a generic cable Cat 7 of about 8 meters arrives until the room where is the Switch Aqvox and of this, a cable of 1,5 meters until the Lumin. I am playing the same audio files, hosted on the NAS! Sometimes from Lumin application therefore using Minimserver / UPnP and others using Roon / RAAT. My question is this; When a file comes from Roon / RAAT and reaches the Lumin, it goes through the same digital circuits before reaching the DAC Wolfson, that when it arrives until the Lumin by Minimserver / UPnP?. I am very intested in the answer, because what I am hearing is very rare.Francisco
March 17, 2017, 10:36 PM #54
Audio data flow on the network:
- NAS MinimServer -> network switches -> Lumin
- NAS file system -> network switch - > Roon Core -> network switches -> Lumin
Within Lumin, the digital paths are not completely the same, but both are lossless bitperfect (unless user selects a resampling):
- With UPnP music it uses an HTTP download mechanism, goes through file type detection and file (e.g. FLAC) decoding, user-selected resampling (only if necessary), then on to PCM or DSD playback.
- With Roon it receives PCM or DSD via the RAAT SDK, goes through user-selected resampling (only if necessary), then on to PCM or DSD playback.
Do you find any SQ difference?
Beware that if you have Tidal in Roon, you may have duplicate albums from both Tidal and your own NAS - you need to be sure that you're streaming your own version to do a proper comparison.Peter Lie
LUMIN Firmware Lead
March 19, 2017, 08:28 PM #55
question..I am playing my system using Roon now and it is superb. I am not sure, however, that i have it set up correctly. rrwmd ...in his post a few days ago showed a picture of his screen showing the Lumin name at the bottom of the screen shot with an icon of the player above it. in that same screen i have the lumin name noted but above mine is a small 'speaker'...is this correct..? also..when i push the blue dot, to the right of some of the tracks i am playing the algorithm ends at the bottom with 'apple airplay' ...is that correct..?..sorry if this is a beginners screw up..
Listening Room: 25' L x 18' W x 23' H..system on the long wall
Speakers: Tidal 'Contriva Diacera-SE
Amps: Chalice Audio 'Grail' SET mono blocks with Psvane WE 845 / 300b tubes
Source: Lumin X-1 Network Music Player
HighFidelity MC-1 Pro Helix conditioner
Cables:
Audience-Studio One RCA interconnect
SilverSmith 'Fidelium' speaker cables
Silent Source 'Music Reference' Power Cords x 3
Innuos 'PhoenixNet' Switch
CAD-CG-1
Audioquest 'fog lifters' under the Fidelium cables
Arya Audio-RevOpods under my Tidal Speakers
REL 212 SE Subwoofer x 2
Nordost V2 ethernet cable
EVP Isolation footers- subs-speakers- Lumin
Tweaks:
Stillpoints Ultra SS under amps
EVP HDR isolators 2" x 8...under my Lumin A1 and PSU
EVP HDR isolators 4" x 16..under my Tidal speakers and my REL 212 SE subs
March 19, 2017, 09:17 PM #56
Please go to Roon Audio Setup, find Lumin under "Networked roon ready" devices, enable it and assign it a zone name. Then find Lumin under "Airplay" and disable it.
Peter Lie
LUMIN Firmware Lead
March 19, 2017, 09:18 PM #57
If Lumin is playing as a Roon Ready device, it'll support Hi-res and DSD playback.
AirPlay (regardless of brand / model) will cause Roon to downsample playback of any music to 16/44.1.Peter Lie
LUMIN Firmware Lead
March 19, 2017, 09:43 PM #58
Peter..thanks..i did what you suggested and pushed the 'disable' option and after that the 'airplay' section now says 'enabled'.....is this correct.?
Cables:
CAD-CG-1
Tweaks:
March 19, 2017, 09:57 PM #59
March 19, 2017, 10:05 PM #60
that is why it is confusing..when i hit the gears and then touch the 'disable' indicator the Airplay/Lumin section then says 'Enabled'....not disabled'''??
Cables:
CAD-CG-1
Tweaks:
March 19, 2017, 10:07 PM #61
In the Roon ready/Lumin A1 section is there supposed to be a red 'Uncertified' label.?
Cables:
CAD-CG-1
Tweaks:
March 19, 2017, 10:30 PM #62
March 19, 2017, 10:32 PM #63
We shipped a D1 for the certification process. It doesn't make sense for us to ship all models to certify, because many models run the same firmware binary. We're working with Roon Labs to clear up the certification display, but these things take time. Please do not worry about the red label.
Peter Lie
LUMIN Firmware Lead
March 19, 2017, 10:33 PM #64
WOW..that is confusing..thanks..it does say 'Enable'..not 'enabled'..great..thanks Peter..dave
Cables:
CAD-CG-1
Tweaks:
March 20, 2017, 11:16 PM #65
I've talked to Roon Labs and they'll improve the setup flow for newly discovered Roon Ready devices in the future.
Peter Lie
LUMIN Firmware Lead
March 25, 2017, 05:22 PM #66
- Oct 2015
- 33
March 25, 2017, 08:19 PM #67
Hi.
Since I sent that post, I have received my new Melco and a mini PC to have Roon core connected to the Aqvox switch. I am traveling for a few days, when I return and do a quiet listening, I will publish my impressions.Francisco
March 28, 2017, 06:59 AM #68
- Jun 2015
- 22
Hello,
For the past few days I have tried Roon on a dedicated Windows PC running Server R2. I have to say that I agree with Elem79, regarding comparisons between Roon and Lumin software. Although Roon recommend a dedicated QNAP NAS server, I would want some reassurance that this would sound better than my Lumin L1 with Kenneth Lau PSU.
I presume Lumin have done comparisons between a Roon NAS server and their own L1; it would be interesting to know their thoughts.
March 28, 2017, 09:39 AM #69
Welcome to the forum Peter, thank you for joining.
March 28, 2017, 11:59 AM #70
If I'm not mistaken, I think Roon Labs is encouraging people to use Intel NUC running ROCK instead of NAS:
http://kb.roonlabs.com/Roon_Optimized_Core_Kit
Discussions about what hardware sounds best for running Roon:
https://community.roonlabs.com/t/sou...grams/22674/75
This may come as a surprise, but SQ evaluation is not really part of my job. For Roon Ready certification, it is a requirement that devices playing from Roon give a sound quality equivalent to their native means of playback. Even if I were to hear anything different (I didn't), I would not be able to say it.
From a firmware point of view, it's the same lossless audio bits that go into the playback hardware. From a CPU and network processing point perspective, there is indeed higher CPU utilization and more network traffic when using Roon.
When comparing a high CPU power Roon server against L1 + LPS, the former is likely disadvantaged due to typically noisy PC power supply, considering that the NUC is probably not much more expensive than your LPS.
Roon Labs CTO says it'd be fine as long as you are "isolating it properly" - "Isolating audio gear from RFI/EMI is important regardless of anything else. This is why high quality power supplies and tools for filtering/isolating ethernet, USB, and line power make a difference."
I'm always interested in hearing users' thoughts regarding SQ.Peter Lie
LUMIN Firmware Lead
March 28, 2017, 03:30 PM #71
- Jun 2015
- 22
Thank you for this Peter. To elaborate more on the PC I used, it is part of a two PC system I used with JPlay as my playback software. It has separate HDPlex linear power supplies. JPlay was my reference playback software for quite some time until I heard a Lumin A1. I was so impressed I bought the S1.
April 12, 2017, 11:18 PM #72
April 22, 2017, 11:30 AM #73
Hi Peter.
Do you know why Roon does not upsampling to 384 and 352.8 and only does it to 192 and 176.4, when Lumin can handle the higher frequencies?Francisco
April 29, 2017, 12:17 PM #74
That's a limitation with the current Lumin models (except U1).
(Just got back from vacation)Peter Lie
LUMIN Firmware Lead
May 17, 2017, 06:11 PM #75
Hi Peter.
1. If I understood Lumin well (except U1) they can accept PCM files 352.8 and 384 for UPnP but not for RAAT. I would be curious to know the reason, if you can explain it.
2. It has an approximate date, in which Lumin decodes the MQA files
RegardsFrancisco
May 17, 2017, 10:50 PM #76
I'm sorry but that's a hardware limitation, and I cannot provide a date for public firmware release - this is something out of our control and more work needs to be done by both MQA Ltd. and us. On a slightly positive note, Lumin is demoing S1 playing MQA at Munich, after receiving blessing from MQA Ltd. for S1 audio quality for MQA playback.
Lumin U1 also supports 352.8kHz and 384kHz, as long as the DAC is connected via USB and the DAC itself supports these sampling rates.Peter Lie
LUMIN Firmware Lead
May 18, 2017, 12:21 AM #77
- May 2013
- 3,242
Peter
I assume you are aware the Auralic, one of the original MQA partners, has now released their own version of "MQA" decoding.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
May 18, 2017, 02:12 AM #78
Yes, I'm aware of that. It's likely to be its own upsampling tuned for MQA music, since they claim that "This process is not an MQA-created or MQA-licensed process" in their firmware release notes. They were indeed the original partner, but then this happened:
https://www.computeraudiophile.com/f...comment=555554Peter Lie
LUMIN Firmware Lead
June 12, 2017, 12:48 AM #79
For those who are using Roon, please upgrade Roon Core to Build 234, and Lumin to Firmware 8.04. The new Lumin firmware contains optimizations for Roon Build 234, and may possibly improve SQ.
Feedback on SQ for this upgrade is much appreciated. Thanks.Peter Lie
LUMIN Firmware Lead
June 12, 2017, 03:16 PM #80
- Jan 2017
- Illinois
- 148
If we are not Roon users, would we hear a SQ difference?
AMP/Preamp/Speakers: Kef LS50 Wireless, Lumin D1, Cayin scd50T sacd, Technics 1200 Denon DL160, Jolida D9, HP Laptop, LH Labs VI Infinity, Cables: Wireworld Eclipse & Silver IC, Platinum USB. W4S recovery.
June 12, 2017, 07:38 PM #81
peter..where do you upgrade to 8.04..i only see the 8.02..
Cables:
CAD-CG-1
Tweaks:
June 12, 2017, 09:21 PM #82
June 12, 2017, 09:22 PM #83
June 12, 2017, 09:25 PM #84
Peter...'kill the Lumin app and run it again'....not sure I understand?
Cables:
CAD-CG-1
Tweaks:
June 12, 2017, 09:38 PM #85
If Lumin app does not prompt you to firmware upgrade, double click the iPad Home button, swipe away the Lumin app to kill it. Then launch Lumin app.
Peter Lie
LUMIN Firmware Lead
June 12, 2017, 10:03 PM #86
Peter..it still says 8.02 in the firmware section
Cables:
CAD-CG-1
Tweaks:
June 12, 2017, 10:32 PM #87
June 14, 2017, 12:00 AM #88
Peter..it is set to 'yes' on check for firmware. Still says 8.02...
Cables:
CAD-CG-1
Tweaks:
June 14, 2017, 02:12 AM #89
Have you killed the app and restarted the app as post #85?
Peter Lie
LUMIN Firmware Lead
June 14, 2017, 07:42 AM #90
Peter. Yes. I double clicked the home button and flipped the page away and restarted the app.. i.e. I then restarted the app by tapping it open. The firmware indicator still says 8.02... dave
June 14, 2017, 10:55 AM #91
Please:
1. Power cycle the Lumin A1
2. Reboot the iPad
3. Use iPad and browse www.luminmusic.com to make sure it is accessible to your setup
4. Launch Lumin app
5. Normally the app should prompt you to upgradePeter Lie
LUMIN Firmware Lead
June 14, 2017, 06:53 PM #92
Peter...that worked. Thanks a lot..dave
Cables:
CAD-CG-1
Tweaks:
June 17, 2017, 02:03 PM #93
Music,to me,sounds better through the Lumin app than through the Roon app. Roon seems to somehow slightly soften the presentation.
Cables:
CAD-CG-1
Tweaks:
I'm suffering issues with getting 1 boulder amp to talk to another boulder amp. I will agreed sound is pretty good.
Boulder 866 app
