Results 1 to 23 of 23
Thread: Balanced headphone suggestions
August 22, 2016, 09:37 PM #1
I have KEF M500 headphones which are very comfortable and neutral sounding. Very nice to use portable with my Pono.
I am just starting to think about a step up headphone. I have used the McIntosh, but found them a little uncomfortable and I was not particularly fond of the total closed back design. I also had a pair of Audeze EL-8, but again felt they were not real comfortable for long time listening, a couple hours or more.
I am thinking about a balanced design (if I do get something fairly sure I want to use a balanced cable), with comfort as a very important criteria. Obviously sound quality is important. Thinking about Christmas suggestions for my wife . Therefore I would say max budget would in the $2k range, hopefully a little less.
Any suggestions on some good cans to consider?McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
August 22, 2016, 10:36 PM #2
Re: Balanced headphone suggwstions
Randy - The MrSpeakers Ether line is right in your price range and have been getting universally great reviews. Might be worth your consideration if you can hear them.
August 22, 2016, 11:32 PM #3
Focal has some wonderful new headphone. The Elear is in your budget.
http://www.focal.com/headphones/#elearMy Systems: http://www.audioshark.org/showthread...481#post158481
August 23, 2016, 02:18 AM #4
Thanks for both suggestions! Have either of you had the chance to listen to either the MrSpeakers or Focal line?
Does the Focal offer a Balanced cable. I don't see anything mentioned on their web-sight.
The Ether line also looks interesting.... looks like the Balanced cable is an option.
Wondering how either of these compare against the Sennheiser HD800S?McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
August 23, 2016, 09:24 AM #5
I've heard the MrSpeakers Ether and Ether-C and found them stunningly good, they made a lasting impression on me but I'm not really a headphone listener. I didn't have a chance to compare them to the HD800S but I recall reading a review that found the Ethers a definite step ahead. Good luck with your search!
August 23, 2016, 10:14 AM #6
Thank you Bill.... It is the very initial stages (unlike most other things I have bought )... I know I want an upgrade and three major criteria for are; balanced cabling, comfort, and sound quality.
August 23, 2016, 11:20 AM #7
I should have also mentioned that I found the MrSpeakers headphones to be some of the most comfortable I've ever tried, but of course YMMV definitely applies.
August 23, 2016, 11:23 AM #8
Re: Balanced headphone suggestions
August 23, 2016, 12:12 PM #9
Nice, but those are a tad out of my range Mike . Maybe I missed it, but I did not see anything about balanced connection???
August 24, 2016, 01:53 AM #10
The best I've heard recently were the Hifiman HE-1000, but they are rather pricey. There is now however also a slightly more affordable version, which I however have not heard.
For lesser money the open PM-1 and closed PM-3 are worth their money. I have the latter ones for travelling and telcos.
August 27, 2016, 02:44 AM #11
How about Sennheiser? Much research keeps coming back to these. Any opinions? How about HD800S versus HD700? Looking at over $1600 compared to about $770 with balanced cable... reviews seem to love the HD800S, but most talk very highly about the HD700.
August 27, 2016, 05:06 AM #12
Have the HD800, which probably are the highest resolution cans out there. W/o a little TLC they tend to be a little too bright, but with an appropriate HP amp incl. power treatment, good DAC and a replacement cable (Cardas is very good) they really deliver resolution and detail aplenty and a very well defined bass (latter requires the aforementioned treatments to shine). They are a little like Magico speakers: Drive them appropriately and they are superb; plug them into you integrated amp's HP outlet and you will not have fun. But in terms of details and a spatial sound they are unbeatable.
Have not heard the HD800S, but I understand they make the bass a bit easier to handle. Between the HD700 and the HD800 there still is a class difference.
August 27, 2016, 10:43 AM #13
The big ticket item is going is be the balanced headphone amp that does justice to either the HD800 , I just couldn't swing the extra for a Woo WA22 so I went with the WA6se instead,. It drives the HD800 with ease vast soundstage, clear. . But we always seem to go back to me old HD600 and the HD650 as headphones that just seem to work with all types of music. My dealer has the Mr Speaker Ether c and that will most like be my next pair as they are very comfortable for those long sessions.
August 27, 2016, 11:06 AM #14
How are the cable connections on the HD650? The pictures look like they are using those slot type connector. Do they hold well? I had a pair of Audeze EL-8 and they were not the most comfortable to me, but the slot type cable really was kind of a pain.
I ask this because no matter which I choose the plan is to add a balanced cable.
I have the KEF M500 which are very nice sound and very comfortable headphones. They work great for mobile use (with the Ayres Pono) but I want something a little better for my in home music listening.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
August 27, 2016, 11:10 AM #15
August 27, 2016, 11:21 AM #16
Sure they do .... the HD650 can be had at about $380-$390 and the balanced cable is $240 from what I am seeing at this point.
August 27, 2016, 01:52 PM #17
August 27, 2016, 01:56 PM #18
I am playing around with the NuPrime DAC-10H. Seems like a pretty darn nice unit and a very highly rated headphone amplifier. The KEF's sound excellent with it!
August 27, 2016, 04:20 PM #192chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
August 27, 2016, 06:04 PM #20
August 27, 2016, 08:10 PM #21
.... yea, I can't justify spending more on headphones then my speakers.....
August 28, 2016, 12:27 AM #22
I am seriously thinking the Sennheiser HD800S. I have yet to read anything bad about them, other than price. And from what I understand they are including their Balanced cable that sells for $380 in the box with them... I want comfort, accuracy, sound stage, and balanced cabling....
So, please tell me why these are not the perfect choice...McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
August 28, 2016, 09:51 AM #23
Nucleus one
