Results 1 to 27 of 27
July 21, 2016, 08:55 PM #1
The PS Audio Dectet is fantastic!
After reading Dan's review on another site for the PS Audio Dectet, I decided to purchase one of these 10 outlet units this past winter when they were having their half price sale. Aside from a six month wait for the restock, I'm glad that I went this route.
In my basement room when my wife and built out the space and wired (along with my Dad the PE who instructed and helped with the proper wiring method) our room for outlets and lights, we were sure to place the rooms' duplex and four-plex wall power outlets on a separate breaker run than the overhead recessed and track lighting. When I finally decided to use part of the space for my listening room, I then ran a dedicated 20amp circuit for the stereo gear. Since that time I never had a single "outlet strip" that would allow the plugging in of all my gear so I was always spanning the gear plug ins between the dedicated 20amp run and the rest of the room's dedicated outlets.
Since having the PS Audio Dectet installed whereby I can finally plug in my power amps into a single zone on the Dectet (bank of two), my analog power into another Dectet zone (bank of four) and my digital power into yet another Dectet zone (bank of four), the noise floor has been reduced even further than it was prior to the Dectet addition. This is especially noticed with my vinyl rig which always had a little tiny bit of ground hum that I could not eliminate. After the addition of the Dectet, that ground hum is gone entirely and my vinyl rig is running on a noise floor as quiet as the Lumin or Oppo BDP-95 player starts with.
I don't notice any lack of dynamics or any other downside to having everything plugged into the Dectet now, quite the opposite. Everything sounds better now since it's starting from such a black background.
Perhaps the Dectet is doing nothing more than allowing me to plug EVERYTHING into a single, dedicated 20amp outlet and I might have gotten the same result with any other 10-outlet strip? Who knows? I don't really care at this point as this thing is working extremely well for me....and, it also allows me to unplug all my gear with one plug from the wall during our stormy season if needed.
I like it and highly recommend it.Avanti Audio
July 21, 2016, 10:37 PM #2
Re: The PS Audio Dectet is fantastic!
July 21, 2016, 10:41 PM #3
Thanks for posting a picture of the Dectet, Joe!
It's a solid unit with vice-like grip for the Edison plugs one will use with it.Avanti Audio
July 21, 2016, 10:52 PM #4
Looks great Mike. I'll check it out.
July 22, 2016, 03:00 AM #5
I have one at home on my desktop/DJ setup. Fantastic product but I think their regenerators are better.
July 22, 2016, 11:38 AM #6
Avanti Audio
July 22, 2016, 12:55 PM #7
Mike.......I am glad my PS Audio Dectet review proved worthwhile in your decision to give it a try. I like the Dectet and use it in my studio system to extend power from my PurePower 2000 AC regenerator in one rack to my preamp and source components in a second rack. Filtration is handled in the Dectet through large core high permeability magnetic devices wound with solid heavy gauge oxygen free copper wire providing both common mode and differential mode filtering. This allows digital components, analog components and amplifiers to have independent isolated power. The Dectet Power Center also provides microprocessor controlled under-voltage and over-voltage protection, shutting power off to the Dectet if adverse power conditions are present, as well as surge protection. The three star-wired Iso-Zones are securely terminated to the receptacles and the wires are neatly routed and connected directly to the circuit board. The extruded aluminum case, receptacle sub-plate and the steel trim plate are all grounded forming a complete shield around the Dectet Power Center’s circuit board and outlets. This is an impressively built product inside and out. It is a well designed and manufactured product that is far superior to any typical six outlet power bar.
Dan
July 22, 2016, 01:24 PM #8
- Feb 2014
- 1,861
I am looking for a solution for an office system which will be a vintage Denon S10 system. Shall look into the Dectet further.
Speakeasy
July 22, 2016, 06:59 PM #9
Mike.......I would also suggest you use a quality power cord with the PS Audio Dectet. The generic 14/3 power cord provided by the factory is a throw-away starter cord, nothing more. I am using a two meter Wireworld Silver Electra power cord with my Dectet with excellent results. Even the PS Audio Dectet owner's manual advises using a premium power cable. Naturally they recommend their premium power cables and outlets. This is what the Dectet manual says:
We strongly recommend the use of a PS Audio PerfectWave Power™ AC cable and a PS Power Port™ AC receptacle to feed the Power Center electricity. While the supplied power cable is adequate for the task, it is not going to provide the best performance. Choosing any PerfectWave Power cable will make a significant performance improvement over the stock power cable.
Dan
July 22, 2016, 07:05 PM #10
Avanti Audio
July 22, 2016, 07:17 PM #11
Mike.......Looking good.
Dan
July 22, 2016, 11:36 PM #12
Thanks Dan! Things are sounding mighty fine around here.
Avanti Audio
July 23, 2016, 08:48 AM #13
- Feb 2016
- west Michigan
- 713
Many years ago I tried a PS Audio Duet. It was the worst experience that I have ever had with a power conditioning product. It completely sucked the life out of my system. I thought that perhaps it was a synergy issue with my gear so I took it to a friends and tried it in his system. Same results there.
From the review and post here, it sounds like PS Audio has improved their entry level product. Good news. Thanks for the update.My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
July 23, 2016, 01:48 PM #14
July 23, 2016, 01:57 PM #15
July 23, 2016, 03:43 PM #16
Not necessary. I have 2 huge dedicated toroidal isolation transformers one for each mono block that can provide more instant peak power then you’re standard 20amp circuit. Additionally they also provide cleaner, blacker noise floor & more stable power then from a bare 20amp wall receptacle.
George
July 23, 2016, 05:53 PM #17
Le Roy
Foundation:
July 23, 2016, 05:59 PM #18
Straight from the wall is a misinterpreted explanation taken out of context that covers most conditioners/regenerators/transformers etc. for the simple reason that George explains above. If you have enough reserve in backup, the result will be optimal, unless the product is below par.
July 23, 2016, 06:22 PM #19
SET's and OTL's can also benefit from a power conditioner/regenerator and they don't draw enough amps to tax any conditioner.
July 23, 2016, 09:01 PM #20
Avanti Audio
July 24, 2016, 11:25 AM #21
July 9, 2018, 02:15 PM #22
I just received a Dectet maybe a month ago; once my Cullen power cords arrive I will deploy it.
McInotsh MC75 (2) amps
Audiophonics LPA-S400ET Class D amp
Marchand XB44 crossover
McIntosh C2500 pre
Luxman 505Ux integrated to drive "B" Speakers
EAT C Sharp with Ortofon Cadenza Blue
TEAC SD1000/Yamaha SACD Blu Ray player
Sonus Faber Olympica I
dual Rythmik sealed subs
AKG and Sennheiser phones, Feliks headphone amp
Vintage Pioneer table and Kenwood 3 head tape deck
Nitty Gritty RCM, and DeGritter
McIntosh, AQ, Nordost, and Cullen Cables
Mytek Brooklyn DAC+/Sonare Ultra Rendu, SGC I transporter 5
Tidal and Roon
August 24, 2018, 08:40 AM #23
- Sep 2016
- 25
August 24, 2018, 08:45 AM #24
Yes. worry free. All is well. I am not even thinking about cables or power so these items are real.
McIntosh C2500 pre
Tidal and Roon
August 24, 2018, 09:06 AM #25
- Sep 2016
- 25
August 24, 2018, 09:15 AM #26
I am so pleased with the system as it has evolved; it is becoming very difficult to hear differences now. A less than perfectly manufactured record is now
the only time I sit up and take notice. That "chirp" noise that can often be heard as the stylus tracks an imperfect groove.McInotsh MC75 (2) amps
McIntosh C2500 pre
Tidal and Roon
August 24, 2018, 09:38 AM #27
- Sep 2016
- 25
Thank you
Congrats Mike! Great sounding and beautifully finished gear. Heard them at FL Expo in 2022 and 2023 front ended by Lampizator - very enjoyable.
Tobian SoundSystems
