July 17, 2016, 10:44 AM #1
New Ayre QX-5 Twenty DAC? Any updates?
I know there was a QX-5 demo at Audio Consultants in Evanston, Illinois. Did anyone attend? Any updates? Looks like it will be a spectacular DAC.
July 17, 2016, 11:15 AM #2
Re: New Ayre QX-5 Twenty DAC? Any updates?
July 17, 2016, 11:31 AM #3
Joe - There's a lengthy thread about this DAC on Computer Audiophile including comments from the Audio Consultants demo here. There are additional details about the DAC earlier in the thread and followup comments after the linked post, including comments from 'scottsol' who works at AC. Hope that you find this helpful!
July 17, 2016, 11:35 AM #4
Thanks! I've been scouring the various forums and hope there's someone here who can give their personal opinion of the QX-5. All reviews seem great so far.
August 9, 2016, 08:51 AM #5
I have another question about "ROON Ready" : From what I understand, to use ROON with the QX-5, you need to have on the same network a PC (or a modern powerful NAS) running ROON Server. So, what "ROON Ready" means ? Why a DAC needs to be "ROON Ready" if ROON run on a server, we just need the DAC to be a "STREAMING" DAC that has an Ethernet port ?
So, this "ROON Ready" designation has nothing to do with ROON itself, it is just that the DAC can stream & read files from a NAS through Ethernet ? correct ?
August 10, 2016, 07:58 PM #6
Has anybody heard it yet?
Jock
August 11, 2016, 02:51 AM #7
You can find the short answer on the ROON website:
"ROON Ready network players have Roon’s high-resolution streaming technology built in.
Roon will discover them on your network, deliver the highest possible quality audio, and even allow volume control right from the Roon user interface!"
https://roonlabs.com/partners.htmlPERFECT SENSE
www.perfect-sense.se
Showroom in Stockholm, Sweden | info@perfect-sense.se | 08 518 368 00 | Follow us on Facebook
August 11, 2016, 03:37 AM #8
August 11, 2016, 04:12 AM #9
PERFECT SENSE
August 11, 2016, 04:16 AM #10
August 11, 2016, 04:25 AM #11
I believe it's much more complicated than that unfortunately. You would need a specific OS for the hardware (the Ayre QX-5 in this case) to make this a reality. The most simple and cost effective solution is to get a NAS which can run the ROON core, from where you can stream directly to the QX-5 over Ethernet.
PERFECT SENSE
August 11, 2016, 05:06 AM #12
I guess a SonicTransporter (with 2Tb SSD or 8 Tb HD and ROON server Pre-installed ) will be the simplest solution...
August 11, 2016, 05:12 AM #13
PERFECT SENSE
August 11, 2016, 11:31 AM #14
reading the manual, I see that on the QX-5, the ethernet port and the 2 USB port all 3 use the same input N°10, so... I wonder if it is possible to have the QX-5 connected to the network (where I have a NAS attached) and also at the same time with a USB Stick in the USB port, and then for music playing, being able to switch between local music (USB) using mconnect and the music stored on the NAS (using ROON) ?
September 1, 2016, 09:47 AM #15
- Jun 2016
- 6
Yes, you can have multiple sources attached via input 10.
The correct app for the QX-5 is MConnect Control which is a version specifically designed for the QX-5.
On the computer audiophile thread you can now follow Blackstone's QX-5 adventure as he picked his up last night.
September 1, 2016, 09:52 AM #16
June 3, 2017, 10:16 AM #17
Anymore feedbacks about the qx5?
How does it perform via USB (fed with a PC/Mac or streamer) vs the ethernet connection?
And the other digital inputs to a transport? SPDIF vs AES/EBU?Music ON / World OFF
June 3, 2017, 10:20 AM #18
It's really a top performer and holds its own against the competition in the store and I find the connection type is not overly important sonically. I guess if pushed, the Ethernet sounds a tiny bit better, but I like the Aurender app, so USB for me.
One word of caution: long break in. 800-1000 hours is not unreasonable.My Systems: http://www.audioshark.org/showthread...481#post158481
June 3, 2017, 10:31 AM #19
Thanks for your insight.
Who does the Ethernet connection works? We simple connect it to a router and the device can see the library (stored on a NAS for instance) with the ROON server on a MacBook?
If so, why do you need an Aurender (or any other streaming device)?
800 to 1000h is just insane...Music ON / World OFF
June 3, 2017, 10:32 AM #20
June 3, 2017, 10:39 AM #21
The QX-5 Twenty is my only dac at this point. I use one of the spdif inputs for my modified Sonos. I have the network input fed by a cat 5e cable and the usb is fed by my Lumin U1.
Break in does indeed take a long time but it's well worth it.
Coming from other dacs, it's apparent that the QX5 is very natural and easy to listen to.
I don't want to use the word analog sounding because after hearing my friend Bruce's table and cart setup, no digital sounds analog. His vinyl setup sounds amazing. But, my Ayre has been the wonderful for me. It sounds as right as it could be, to me. It does not immediately blow you away, which to me is good because those kind of pieces don't last. The QX5 grows and grows on me everyday. It's dead quiet and sounds musical to me.
June 3, 2017, 10:44 AM #22
June 3, 2017, 10:45 AM #23
The mConnect app is ok, nothing great but works. It can be a little wonky at times but the sound is worth it. The QX5 shows up on the network. I has not used the wifi antenna to augment the dac, I don't feel I need it. I am considering the Melco server to feed the ethernet connection. It should be an excellent combo. Feeding it Aurender will be awesome too.
I love roon, bit don't like having a computer in my room. I guess you could set it up in an adjacent room to keep the noise down.
June 3, 2017, 11:24 AM #24
Joe, congrats on the QX-5! Didn't know you have one. Sounds like a wonderful piece.
June 3, 2017, 11:57 AM #25
Thank you. It's a great dac. I've become an Ayre fan for sure.
June 3, 2017, 03:32 PM #26
Jock
June 13, 2017, 04:30 PM #27
I have a QX-5 Twenty and VX-5 Twenty inbound. I am looking forward to experiencing first hand what everyone is raving about.
Simaudio 680D > Simaudio 600i > Audioquest Fire > Audioquest William Tell Zero > Aerial 7T > Audioquest Niagara 1200> Transparent Performance power cords > BBA Rigidrack
June 13, 2017, 04:38 PM #28
Congrats. Local dealer?
June 14, 2017, 10:21 AM #29
Congrats!
Jock
July 30, 2017, 10:31 AM #30
I've been playing with this DAC all weekend in my system at home. Definitely a great performer. Very musical.
July 30, 2017, 01:31 PM #31
- Oct 2015
- New York City Metro Area
- 443
July 30, 2017, 03:58 PM #32
Any update on your Ayre combo? Give them plenty of time to break in and they will reward you for your patience. I'm curious about your thoughts.
As good as the QX5 is, I still always prefer a preamp in my system. A preamp really helps bring the musicality to a system.
July 31, 2017, 05:35 AM #33
- Oct 2015
- 443
August 11, 2017, 04:01 PM #34
In case of interest: there's John Atkinson's review of the QX-5/20 in the latest Stereophile. He also used it to create the analog master tapes for the vinyl version of Sasha Matson's "Tight Lines".
Quote: "After I'd resolved the issues of system synergy, there was no doubt in my mind: Ayre Acoustics' QX-5 Twenty is one of the finest sounding, most versatile, digital audio products I've had the pleasure of using... Class A+ with a bullet!
Interesting read.
August 11, 2017, 04:37 PM #35
Wow!
Jock
August 11, 2017, 04:38 PM #36
August 11, 2017, 04:40 PM #37
August 11, 2017, 04:54 PM #38
August 11, 2017, 04:54 PM #39
August 11, 2017, 05:04 PM #40
August 11, 2017, 05:09 PM #41
Run Roon on your Mac/PC (assuming it meets the very modest minimum requirements). Make sure the Mac/PC is connected to the network via Cat 5/6. Then, run another Cat 5/6 cable to the back of the QX-5 Twenty. Control the QX-5 Twenty with Roon on your iPad. Done.
Let me know if you have any questions.My Systems: http://www.audioshark.org/showthread...481#post158481
August 11, 2017, 09:23 PM #42
- Aug 2017
- 16
If you're streaming Tidal would it be better to use the Mconnect app and go straight to the QX5 from the internet rather than bringing in your Mac/PC and Roon into the chain? I would think that simplifying the signal path would be better.
Do you find that using an audiophile ethernet cable is an improvement over a generic cable? I would think that a unit like the QX5 would clean up whatever issues might be present on the ethernet input.
August 11, 2017, 09:26 PM #43
Welcome to the forum infonut, thank you for joining.
Altaira or Gemini CGS on...
